Rogersk8ter 1st Gear July 4, 2011 Share July 4, 2011 My w/s told me my front left drive shaft needs replacement. He said can wait till both left n right worn out n replace together. is this a gd ideal? shd i go ahead n replace the left first? mit grandis 5yo. any gd w/s n how much for the repair? tks. ↡ Advertisement Link to post Share on other sites More sharing options...
Mrkiasume Neutral Newbie July 4, 2011 Share July 4, 2011 something similar to me also. Whats the cost? and what will happen if its not replaced? Link to post Share on other sites More sharing options...
Ngck 3rd Gear July 4, 2011 Share July 4, 2011 My w/s told me my front left drive shaft needs replacement. He said can wait till both left n right worn out n replace together. is this a gd ideal? shd i go ahead n replace the left first? mit grandis 5yo. any gd w/s n how much for the repair? tks. drive shaft or just the CV joint boot cover? Drive shaft = a few hundred dollars.... CV joint boot cover just replace the rubber cover about 50-60 per side. parts and labour better change earlier to avoid more complication... Link to post Share on other sites More sharing options...
Ngck 3rd Gear July 4, 2011 Share July 4, 2011 something similar to me also. Whats the cost? and what will happen if its not replaced? for CV joint. Dirt and sand get in and damage the joint... have to replace the whole drive shaft Link to post Share on other sites More sharing options...
Mrkiasume Neutral Newbie July 4, 2011 Share July 4, 2011 for CV joint. Dirt and sand get in and damage the joint... have to replace the whole drive shaft what happens if the drive shaft is damaged but i dont change it? cos there's this problem where my wheel alignment is perfectly straight. however my car still pulls left. Link to post Share on other sites More sharing options...
Yewheng Twincharged July 4, 2011 Share July 4, 2011 (edited) Edited July 4, 2011 by Yewheng Link to post Share on other sites More sharing options...
Ngck 3rd Gear July 6, 2011 Share July 6, 2011 what happens if the drive shaft is damaged but i dont change it? cos there's this problem where my wheel alignment is perfectly straight. however my car still pulls left. better get it check.... safety issues... Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 7, 2011 Share July 7, 2011 this is very misleading. My friend's car when turning goes tok tok tok caused by his faulty shaft. he want to max his $ so he asked the WS and the WS say no change also no problem. 1 month later, while doing a slow traffic light u turn, his steering wheel refused to turn back and he had an accident with the front car. after analyzed, discovered he couldn't turn because his shaft snapped! so a living eg, they do snap when under pressure, those who say no, they are just lucky it did not happen to them. He was lucky it did not snap when he was on the highway 5 minutes ago. in the end he spent more to repair the accident vs changing his shaft at the first place Link to post Share on other sites More sharing options...
Ronleech 2nd Gear July 7, 2011 Share July 7, 2011 (edited) this is very misleading. My friend's car when turning goes tok tok tok caused by his faulty shaft. he want to max his $ so he asked the WS and the WS say no change also no problem. 1 month later, while doing a slow traffic light u turn, his steering wheel refused to turn back and he had an accident with the front car. after analyzed, discovered he couldn't turn because his shaft snapped! so a living eg, they do snap when under pressure, those who say no, they are just lucky it did not happen to them. He was lucky it did not snap when he was on the highway 5 minutes ago. in the end he spent more to repair the accident vs changing his shaft at the first place That is the issue...damaged CV will jam the steering when it bearing fail cosing it to jam and stuck... no one know how long can a damaged CV can last....few days some fews month and up to year.... when CV spoil, better get it change fast... If i am not wrong...replace CV will cos at least 500 Edited July 7, 2011 by Ronleech Link to post Share on other sites More sharing options...
Rogersk8ter 1st Gear July 7, 2011 Author Share July 7, 2011 i just chk with supplier.......$750 just for the part. one side alone. Link to post Share on other sites More sharing options...
Mingsect 5th Gear July 8, 2011 Share July 8, 2011 go check with elite driveshaft, they does cv boot too. mostly they using oem items so should be cheaper.. Link to post Share on other sites More sharing options...
Forhod Clutched July 9, 2011 Share July 9, 2011 go check with elite driveshaft, they does cv boot too. mostly they using oem items so should be cheaper.. +1 for Elite, friendly boss and good price. Look for Jason. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 9, 2011 Share July 9, 2011 Replacing damaged CV boot is time consuming if done in the old fashion way. Here use of air spreader does cut down the installation time to a great degree. Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 9, 2011 Share July 9, 2011 i just chk with supplier.......$750 just for the part. one side alone. Wah Gold CV joints. 1st time I heard. Link to post Share on other sites More sharing options...
Happily1986 5th Gear July 9, 2011 Share July 9, 2011 i just chk with supplier.......$750 just for the part. one side alone. pray tell what supplier is this? Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 9, 2011 Share July 9, 2011 i just chk with supplier.......$750 just for the part. one side alone. These are brand new,not Re-con drive shaft. Link to post Share on other sites More sharing options...
Happily1986 5th Gear July 10, 2011 Share July 10, 2011 These are brand new,not Re-con drive shaft. drive shaft and CV joints different part. Link to post Share on other sites More sharing options...
Jasonjst 3rd Gear July 10, 2011 Share July 10, 2011 What is life span of CV jt under normal driving condition in SG ? 5yrs or 10yrs ? ↡ Advertisement Link to post Share on other sites More sharing options...
Driving in Europe
Driving in Europe
Strange Mural at Holland Drive Food Center
Cars We Don't Get to Drive in Singapore
