ER-3682 Supersonic August 20, 2011 Share August 20, 2011 Hi Friends,i am helping a friend,he is driving an Audi A6 with the 2L turbo engine,which is i think the same engine used in the V.W. Golf GTI,recently his car used about 1L of engine oil every 1500km,which i think is a bit too much,his mileage is 65,000km,no leak is detected,agent says it is normal,did any V.W./Audi owners here have this problem,thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Lowel Clutched August 20, 2011 Share August 20, 2011 What engine oil is he using? Link to post Share on other sites More sharing options...
Ithunk 1st Gear August 20, 2011 Share August 20, 2011 Hi Friends,i am helping a friend,he is driving an Audi A6 with the 2L turbo engine,which is i think the same engine used in the V.W. Golf GTI,recently his car used about 1L of engine oil every 1500km,which i think is a bit too much,his mileage is 65,000km,no leak is detected,agent says it is normal,did any V.W./Audi owners here have this problem,thanks. yes this is an issue....mechanics and workshops may diagnose problems differently....could be a leak could be something else jus check the dipstick to be sure...but yr friend driving such a vehicle i think will not get down and dirty with all that lol anyway the dipstick is an indicator... Link to post Share on other sites More sharing options...
ER-3682 Supersonic August 20, 2011 Author Share August 20, 2011 What engine oil is he using? Even using 10w60,100% Syn oil. Link to post Share on other sites More sharing options...
Lowel Clutched August 21, 2011 Share August 21, 2011 Something is not right for sure la. Of course agent will say it is normal. Cos they don't want to spend the $ and time to find the root cause. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged August 21, 2011 Share August 21, 2011 your friend got mob the engine or not?? Link to post Share on other sites More sharing options...
ER-3682 Supersonic August 21, 2011 Author Share August 21, 2011 your friend got mob the engine or not?? Just K&N drop in filter & E.C.U. reflashed. Link to post Share on other sites More sharing options...
Satria_neo Clutched August 22, 2011 Share August 22, 2011 Hmm...... If I am not wrong, I think I did read about similar issues with some BMW engines. High EO consumption but Agent says its normal. Link to post Share on other sites More sharing options...
Hogster Neutral Newbie August 22, 2011 Share August 22, 2011 It is a problem. My BIL's friend also driving an Audi got this oil lost issue. Agent changed the valves, after sometime, same problem, they might change the engine if worse comes to worse. Link to post Share on other sites More sharing options...
Hoppie24 1st Gear August 22, 2011 Share August 22, 2011 Just K&N drop in filter & E.C.U. reflashed. reflashed means high boost, if still under agent warranty, please go bang table. Link to post Share on other sites More sharing options...
Cluboxed 1st Gear August 22, 2011 Share August 22, 2011 Yah its true...i have heard feedbacks b4 like this for Audi/BMW.. Link to post Share on other sites More sharing options...
Jasonjst 3rd Gear August 22, 2011 Share August 22, 2011 Hi Friends,i am helping a friend,he is driving an Audi A6 with the 2L turbo engine,which is i think the same engine used in the V.W. Golf GTI,recently his car used about 1L of engine oil every 1500km,which i think is a bit too much,his mileage is 65,000km,no leak is detected,agent says it is normal,did any V.W./Audi owners here have this problem,thanks. The pisons clearance is like few hundreds mircons ? Use 60 grade oil also burn away 1L of oil for 1500km ? Might as well run on engine oil. Cant be normal lah , agent trying to con you . 15yrs cars also wont burn away that much of EO leh . Link to post Share on other sites More sharing options...
Delrosa81 Neutral Newbie August 22, 2011 Share August 22, 2011 Hi Friends,i am helping a friend,he is driving an Audi A6 with the 2L turbo engine,which is i think the same engine used in the V.W. Golf GTI,recently his car used about 1L of engine oil every 1500km,which i think is a bit too much,his mileage is 65,000km,no leak is detected,agent says it is normal,did any V.W./Audi owners here have this problem,thanks. If after each engine oil change, the on board computer prompts the driver to top up 1 litre of engine oil say like 5000 to 6000km travelled, this is normal. If just travelled 1500km, then something might be wrong. Good to send in for a once over again just to make sure. Link to post Share on other sites More sharing options...
ER-3682 Supersonic August 22, 2011 Author Share August 22, 2011 Thanks guys,i will ask him go back agent & ask what cane be done. Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 22, 2011 Share August 22, 2011 Just get the AD to do compression test and if unable to pinpoint the problem proceed to do the cylinder lead down test. Very simple not rocket science. Link to post Share on other sites More sharing options...
Izzist Neutral Newbie November 18, 2011 Share November 18, 2011 Hi i'm encountering same problem. Almost every 2,000km the engine oil indicator blinks for my A6(2009') and when i return to service centre the Service Advisor proudly state this is normal. Been back almost 3 times for servicing since i took over this car 2mths ago. Wouldn't Consider an Audi in the Future. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear November 18, 2011 Share November 18, 2011 I have no idea Germans can be so talented. Link to post Share on other sites More sharing options...
Tanhangkiang 3rd Gear November 18, 2011 Share November 18, 2011 Maybe the cheap engine oil from shop and save could help, stock up few bottle just in case. http://www.mycarforum.com/index.php?showto...71442&st=20 ↡ Advertisement Link to post Share on other sites More sharing options...
Xpeng is Coming to Town
Engine Mounting
Engine Mounting
Any recommendations for a good dashcam for new drivers?
2025 Audi A6 (C9)
2025 Audi A6 (C9)
