Rayoflight 5th Gear June 10, 2019 Share June 10, 2019 Might as well get R56 JCW. For COE car, it is likely to be R50 which is more problematic. Ok did quite abit of reading that n14 really got alot of problems. Alright look see look see again ↡ Advertisement Link to post Share on other sites More sharing options...
Vratenza Supersonic June 10, 2019 Share June 10, 2019 Sometimes one need to experience it for him/herself before believing..... 2 1 Link to post Share on other sites More sharing options...
Mercury1 Turbocharged June 10, 2019 Share June 10, 2019 I had the N18 engine version and it was quite reliable for me, I think if you really want to get probably stock version non cab is best. Those modded up once high chance will have some issues down the road, I agree with David the double sunroof actually enough to feel as good as a cab. Ok did quite abit of reading that n14 really got alot of problems.Alright look see look see again Link to post Share on other sites More sharing options...
Rayoflight 5th Gear June 13, 2019 Share June 13, 2019 Sometimes one need to experience it for him/herself before believing..... i also scared.. buying a coe-ed car can also mean hugging it till death do us part. Difficult to resell unless highly sought after model. Link to post Share on other sites More sharing options...
Vratenza Supersonic June 13, 2019 Share June 13, 2019 Not only need to worry about engine bay, the interior fit, parts and finishing will drive you crazy... i also scared.. buying a coe-ed car can also mean hugging it till death do us part. Difficult to resell unless highly sought after model. 1 Link to post Share on other sites More sharing options...
Dinosaur33 3rd Gear June 13, 2019 Share June 13, 2019 (edited) I had the N18 engine version and it was quite reliable for me, I think if you really want to get probably stock version non cab is best. Those modded up once high chance will have some issues down the road, I agree with David the double sunroof actually enough to feel as good as a cab.Thank you for the tips and advice.i also scared.. buying a coe-ed car can also mean hugging it till death do us part. Difficult to resell unless highly sought after model.Just my 2 cents worth of comments if you don't mind. If I were in your position, I would ask myself, is this going to be a primary car for myself? If this is a secondary car/weekend car/leisure car, do I have the extra cash to service/restore/repair the car to it's good condition should it breakdown? On top of that, am I willing to absorb depreciation of the value of the vehicle, even if it meant I need to dispose off in the future. After all these questions, I think you will get your answer. Not only need to worry about engine bay, the interior fit, parts and finishing will drive you crazy...This point, I can vouch for it. No point buying a car when everything is haywire all the time. It brings more frustration to you only. Edited June 13, 2019 by Dinosaur33 2 Link to post Share on other sites More sharing options...
Discoburg Supersonic June 22, 2019 Share June 22, 2019 Another mini with same roof top Union Jack design. 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 6, 2019 Share July 6, 2019 (edited) https://www.facebook.com/TargaRacingHK/videos/835192203547919/?t=2 Edited July 6, 2019 by Davidtch 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 5, 2019 Share November 5, 2019 After losing wheel badge, I got these: Left side: Right side: Link to post Share on other sites More sharing options...
Sdf4786k Twincharged November 6, 2019 Share November 6, 2019 On 6/13/2019 at 1:17 PM, Vratenza said: Not only need to worry about engine bay, the interior fit, parts and finishing will drive you crazy... would the engine build of a BMW 1 series be a better bet. I understand the list of the problem goes from the cramp engine bay belt changes to the water pump and coolant leak to oil leak . But not as problematic as a RX8. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged November 6, 2019 Share November 6, 2019 On 4/7/2019 at 11:12 AM, Voodooman said: My mechanic's view: Usual BMW issues plus higher wear and tear rate due to the compact engine bay = not for high mileage drivers. are the parts inter-changeable for the engine as the BMW is rear wheel drive vs front wheel drive.? I imagine engine parts should be the same except for the transmission and the JCW variant. Is it true that the JCW is using the N14 instead of the newer incarnation for 2012.? Link to post Share on other sites More sharing options...
Vratenza Supersonic November 6, 2019 Share November 6, 2019 1 hour ago, Sdf4786k said: would the engine build of a BMW 1 series be a better bet. I understand the list of the problem goes from the cramp engine bay belt changes to the water pump and coolant leak to oil leak . But not as problematic as a RX8. The bwm platform is way better.... But still cannot beat physics. My current 2017 mcs is OK mechanically but still have pretty high wear and tear. Engine mount change at 2yrs. Brake pads and rotors change at 2.8yrs. 1 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged November 6, 2019 Share November 6, 2019 4 minutes ago, Vratenza said: The bwm platform is way better.... But still cannot beat physics. My current 2017 mcs is OK mechanically but still have pretty high wear and tear. Engine mount change at 2yrs. Brake pads and rotors change at 2.8yrs. 2017 is the 2.0 T? same as the 228 230 engine. I supposed it should be very much improved upon. Link to post Share on other sites More sharing options...
Vratenza Supersonic November 6, 2019 Share November 6, 2019 (edited) 29 minutes ago, Sdf4786k said: 2017 is the 2.0 T? same as the 228 230 engine. I supposed it should be very much improved upon. Yes, engine cover is the same... Just change logo to mini... even the tranny is the well-received BMW 8AT. Edited November 6, 2019 by Vratenza Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 6, 2019 Share November 6, 2019 From 2018, it is on DCT similar all FWD BMW. 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged November 6, 2019 Share November 6, 2019 (edited) 5 hours ago, Davidtch said: From 2018, it is on DCT similar all FWD BMW. just like the EA888.3 from VW/audi/skoda. As long as you running it with DQ381/DQ500, you good to go. Edited November 6, 2019 by Sdf4786k 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 6, 2019 Share November 6, 2019 2 minutes ago, Sdf4786k said: just like the EA888.3 from VW/audi/skoda. As long as you running it with DQ381/DQ500, you good to go. Getrag 7DCT300. I think wet clutch 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged November 6, 2019 Share November 6, 2019 3 hours ago, Davidtch said: Getrag 7DCT300. I think wet clutch Getrag 7DCT300 only renualt and some other atas euro using.. ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Mini Cooper
Renting a Mini bus to go Malaysia
Selling a 2017 Nissan Pulsar to buy a used 2016 Mini
Mini JCW GP Roll Over Shortly After Owner Takes Delivery
Next-Gen Mini Cooper Gets Special EV Sounds, Infotainment Modes, OTA Updates
The Best Cooling Measures: Ice Cream! 😂
