Budacco Neutral Newbie March 11, 2012 Share March 11, 2012 haha today last day go grab! ↡ Advertisement Link to post Share on other sites More sharing options...
Mllcg 3rd Gear March 11, 2012 Share March 11, 2012 Either RAM modules or paged memory in your HDD got problem. 1.) Run memtest and/or resit memory modules again 2.) Use HDD utilities e.g. Defraggler to check health of your HDD. memtest clear. resit already. i cant defrag. the drive is "dirty". I can clean it and unset then the moment i click defrag, it becomes "dirty" again.. how? Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 11, 2012 Share March 11, 2012 memtest clear. resit already. i cant defrag. the drive is "dirty". I can clean it and unset then the moment i click defrag, it becomes "dirty" again.. how? how long you run memtest? memtest how it works is that, if it encounters an error, you can confirm there is one. On the other hand, if it doesn't encounter an error, it doesn't necessarily mean you are definitely okay. it could well mean that memtest has yet to encounter an error. what you mean by dirty? anyway use this and print screen result. CrystalMark Link to post Share on other sites More sharing options...
Mllcg 3rd Gear March 11, 2012 Share March 11, 2012 (edited) how long you run memtest? memtest how it works is that, if it encounters an error, you can confirm there is one. On the other hand, if it doesn't encounter an error, it doesn't necessarily mean you are definitely okay. it could well mean that memtest has yet to encounter an error. what you mean by dirty? anyway use this and print screen result. CrystalMark dirty bit from C:. Edited March 11, 2012 by Mllcg Link to post Share on other sites More sharing options...
Mllcg 3rd Gear March 11, 2012 Share March 11, 2012 dirty bit from C:. uploaded SS.. Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 11, 2012 Share March 11, 2012 uploaded SS.. the problem: too many failed/bad sectors which cannot be used to store data. Usually HDDs have spare sectors i.e. redundancy sectors to replace those that are written off. However,for smooth and quick operations, contiguous storage is very much preferred meaning files are stored in a single block consisting of sectors next to each other. so, you have a hard disk which resembles a patchwork with many "holes" that are unusable. problem, is paged memory or virtual memory i.e. portion of hard drive space allocated to act as RAM when your real RAM runs out, needs contiguous space. therefore, you experience your BSOD because i believe Windows is forced to shift the space which paged memory resides everytime you start it up which in turn means that Windows sometimes try to access an area of your hard drive which it thinks is the paging memory but in effect, isn't. And BAM, kernel panic. My experience tells me that your HDD may uplorry soon. Mine died about half a year after i saw it went on caution. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear March 11, 2012 Share March 11, 2012 (edited) the problem: too many failed/bad sectors which cannot be used to store data. Usually HDDs have spare sectors i.e. redundancy sectors to replace those that are written off. However,for smooth and quick operations, contiguous storage is very much preferred meaning files are stored in a single block consisting of sectors next to each other. so, you have a hard disk which resembles a patchwork with many "holes" that are unusable. problem, is paged memory or virtual memory i.e. portion of hard drive space allocated to act as RAM when your real RAM runs out, needs contiguous space. therefore, you experience your BSOD because i believe Windows is forced to shift the space which paged memory resides everytime you start it up which in turn means that Windows sometimes try to access an area of your hard drive which it thinks is the paging memory but in effect, isn't. And BAM, kernel panic. My experience tells me that your HDD may uplorry soon. Mine died about half a year after i saw it went on caution. if i shift my OS to an SSD, can i still use this HDD? i got too much games to reinstall. or will the hdd still die? btw, where are the bad sectors? the 4th option that is yellowed out? and i did a chkdsk, showed 0kb in bad sectors Edited March 11, 2012 by Mllcg Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 11, 2012 Share March 11, 2012 if i shift my OS to an SSD, can i still use this HDD? i got too much games to reinstall. or will the hdd still die? btw, where are the bad sectors? the 4th option that is yellowed out? and i did a chkdsk, showed 0kb in bad sectors 1.) you can still do so but generally sector recount implies that there is a high chance there is a background factor causing sectors to fail thereby forcing the HDD to use its redundant sectors to replace them. So be prepared that this HDD will fail in time to come. 2.) it tells you there are 36 sectors on the regular platter(s) that have failed and are replaced. 3.) chkdsk simply does a check on sectors that are shown to it. Remember that the HDD has already done a sector reallocation meaning the Hard Disk will ask chkdsk to check the redundant sectors which are okay rather than the original sectors which are gone. Therefore, if one use chkdsk, one will never know. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear March 11, 2012 Share March 11, 2012 1.) you can still do so but generally sector recount implies that there is a high chance there is a background factor causing sectors to fail thereby forcing the HDD to use its redundant sectors to replace them. So be prepared that this HDD will fail in time to come. 2.) it tells you there are 36 sectors on the regular platter(s) that have failed and are replaced. 3.) chkdsk simply does a check on sectors that are shown to it. Remember that the HDD has already done a sector reallocation meaning the Hard Disk will ask chkdsk to check the redundant sectors which are okay rather than the original sectors which are gone. Therefore, if one use chkdsk, one will never know. so 36 replaced, other 64 cannot? so if i use another disk for OS, chances of failing will be less? but still there? Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 11, 2012 Share March 11, 2012 so 36 replaced, other 64 cannot? so if i use another disk for OS, chances of failing will be less? but still there? bad sectors fail liao nothing you can do about it. I think max replacement sectors avail is 100. Anyway before you even hit 100 sectors, you will probably encounter shitty fragmentation because sectors tend to fail randomly give you shitty fragmentation. high chance it will continue to deteriorate. btw, excessive defragmentation can exacerbate such problems too. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear March 11, 2012 Share March 11, 2012 bad sectors fail liao nothing you can do about it. I think max replacement sectors avail is 100. Anyway before you even hit 100 sectors, you will probably encounter shitty fragmentation because sectors tend to fail randomly give you shitty fragmentation. high chance it will continue to deteriorate. btw, excessive defragmentation can exacerbate such problems too. so my "missing shortcuts", changed file extentions are all caused by this bad sector problem and is irreversible? Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 11, 2012 Share March 11, 2012 so my "missing shortcuts", changed file extentions are all caused by this bad sector problem and is irreversible? i dont think bad sector problems will cause those things actually. if you got bad sectors and they are replaced by good ones already, there is no reason anything will be affected other than performance. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear March 11, 2012 Share March 11, 2012 i dont think bad sector problems will cause those things actually. if you got bad sectors and they are replaced by good ones already, there is no reason anything will be affected other than performance. then whats causing them? some of my .jpg files have become .file... after blue screen, sth sure disappears and changes. ↡ Advertisement Link to post Share on other sites More sharing options...
Car Show 2024
Car Show 2024
Heart Attack Slide Show
AFF susuki cup 2012
AFF susuki cup 2012
Woman Carry Woman Paris Fashion Show, very Bizarre
What's Your Favourite Anime Show?
Volkswagen Santana to retire by 2012
Higher starting pay for SMU's 2012 cohort of fresh grads
Mediacorp Suria apologises for subtitling error during baking show
