Ahrex Clutched July 25, 2012 Share July 25, 2012 Hi all, I wanna ask about the cold air intake thing.. issit juz plug and play? i see some selling quite cheap leh like below link.. do i need to get anything else? i have searched thru and kinda understand wat CAI is for.. my car is 2nd hand and there is a hole on the passenger side front bumper so i suspect the previous owner also put CAI.. i see the whole for a few months liao abit sian so feel like putting something there.. haha..http://www.mycarforum.com/index.php?autoco...p;product=29774my question is that is it juz put this one can already? i dun need to change exhaust or anything right.. if that is the case den its quite cheap and i think i will go do it.. haha.. if got any added pickup power or better FC is good.. if dun have also neva mind..i am driving a vios btw and i hope to hear the expert opinions from bros n sis here.. thanks in advance!!! ↡ Advertisement Link to post Share on other sites More sharing options...
Maldini03 1st Gear July 25, 2012 Share July 25, 2012 bro, if you dun mind what for fixing the CAI? imo, i think it is ineffective/ Link to post Share on other sites More sharing options...
Gee 1st Gear July 25, 2012 Share July 25, 2012 Certainly won't help your FC that's for sure. You can always plug the hole with the CAI funnel without the CAI itself. Get the look safe the FC. Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 25, 2012 Share July 25, 2012 I just fitted the "HKS-R Suction",oh yes it works. Link to post Share on other sites More sharing options...
Tayspiderx 3rd Gear July 25, 2012 Share July 25, 2012 Din TS try to ask the seller to seal up the hole before transfer? Link to post Share on other sites More sharing options...
SimplyTWL 1st Gear July 26, 2012 Share July 26, 2012 Hi all, I wanna ask about the cold air intake thing.. issit juz plug and play? i see some selling quite cheap leh like below link.. do i need to get anything else? i have searched thru and kinda understand wat CAI is for.. my car is 2nd hand and there is a hole on the passenger side front bumper so i suspect the previous owner also put CAI.. i see the whole for a few months liao abit sian so feel like putting something there.. haha.. http://www.mycarforum.com/index.php?autoco...p;product=29774 my question is that is it juz put this one can already? i dun need to change exhaust or anything right.. if that is the case den its quite cheap and i think i will go do it.. haha.. if got any added pickup power or better FC is good.. if dun have also neva mind.. i am driving a vios btw and i hope to hear the expert opinions from bros n sis here.. thanks in advance!!! Hey bro, u driving FL vios? Btw, whether FL/Belta setting up the CAI need some DIY to connect it up. Else you can try asking the gurus in VOGS.. Link to post Share on other sites More sharing options...
Hotamp 3rd Gear July 26, 2012 Share July 26, 2012 seen a video on youtube once which shows a car being hooked up to a machine while the person tested a few CAI inturn on the car......conclusion is that, installing CAI doesnt seems to have much effect on the performance of the engine. Link to post Share on other sites More sharing options...
Jamesc Hypersonic July 26, 2012 Share July 26, 2012 If you mount your CAI low just be careful about driving into floods. Link to post Share on other sites More sharing options...
Dfx16 6th Gear July 26, 2012 Share July 26, 2012 I came across this sometime back Take a look quite informative http://zc21s.blogspot.sg/2011/11/below-is-...ver-past-2.html Link to post Share on other sites More sharing options...
Slowpoke 3rd Gear July 26, 2012 Share July 26, 2012 Link to post Share on other sites More sharing options...
Ahrex Clutched July 26, 2012 Author Share July 26, 2012 i driving pre fl vios.. install this cai will suck in water? how bout when washing car? really no use? cos that time i got rent a car.. toyota wish.. like got cai also.. the pickup was quite fast.. haha.. feels shiok.. anyway if really is useless, maybe i will juz buy the funnel n put to plug the hole bah.. Link to post Share on other sites More sharing options...
Bigbadguy 1st Gear July 26, 2012 Share July 26, 2012 Cold air intake is good if u can get it straight into the TB. by twisting and turning the pipe to make it fit the hole will only make the engine harder to sux up air and in return make ur car performance worse, And looking at the design of the pipe, the inner surface is not even smooth. Ur vios stock intake is the best design. straight and intake opening facing away from the engine. U want power? go for the straight open pod design where u leave the pod behind the headlight, and the most impt part is ---> Get a piggy back to tune it, Just by adding a CAI or changing to open pod will not increase power. If poorly done, might even reduce the power of ur car. And don't expect too much gain even after u tune it, Max is abt 5hp for setting the right AFR and 5-8 Hp by tuning the ignition timing (Depend tuning for ron 95 or ron 98), so in all its abt 10-13 Hp gain, Figures differ depending on tuner, Happy Modding, Link to post Share on other sites More sharing options...
Vtoolshop Neutral Newbie July 26, 2012 Share July 26, 2012 It may be some difficulty Link to post Share on other sites More sharing options...
Ahrex Clutched July 26, 2012 Author Share July 26, 2012 Cold air intake is good if u can get it straight into the TB. by twisting and turning the pipe to make it fit the hole will only make the engine harder to sux up air and in return make ur car performance worse, And looking at the design of the pipe, the inner surface is not even smooth. Ur vios stock intake is the best design. straight and intake opening facing away from the engine. U want power? go for the straight open pod design where u leave the pod behind the headlight, and the most impt part is ---> Get a piggy back to tune it, Just by adding a CAI or changing to open pod will not increase power. If poorly done, might even reduce the power of ur car. And don't expect too much gain even after u tune it, Max is abt 5hp for setting the right AFR and 5-8 Hp by tuning the ignition timing (Depend tuning for ron 95 or ron 98), so in all its abt 10-13 Hp gain, Figures differ depending on tuner, Happy Modding, thanks for the details bro.. so cai is only gd if i get it straight into the throttle body? any workshop can do that? actually if dun have also nvm la.. i only see the hole very sian.. so wanna patch up with a cai funnel.. of course if it helps den good la.. if it doesn;t den i will juz put the funnel bah.. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear July 26, 2012 Share July 26, 2012 if you want to install CAI, you need experience mechanic to do a good job. things like the layout and materials are very important. want to do CAI, do a proper one and price must be secondary. during hot sunny day, you cannot expect hot air in and turn into cold air to the engine. CAI will feel significant difference during night or cooling day. if you ask me, CAI will definitely work but most importantly, it is still your car performance holds the main factor. Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 26, 2012 Share July 26, 2012 bottom line.............. dont reinvent the wheel to make it any rounder... Link to post Share on other sites More sharing options...
Phluvcat 6th Gear July 26, 2012 Share July 26, 2012 if you want to install CAI, you need experience mechanic to do a good job. things like the layout and materials are very important. want to do CAI, do a proper one and price must be secondary. during hot sunny day, you cannot expect hot air in and turn into cold air to the engine. CAI will feel significant difference during night or cooling day. if you ask me, CAI will definitely work but most importantly, it is still your car performance holds the main factor. by your logic, you are very right, my car feels very sluggish during hot days but a different thing all together when the temperature drops. hot days, power only comes in a high revs from like 3500 to 4000 onwards, else cool days just below 3000 can feel it. so hot days drive is sibeh sian one, like pushing a chow turtle. Link to post Share on other sites More sharing options...
Satrianeo_2012 Clutched July 29, 2012 Share July 29, 2012 by your logic, you are very right, my car feels very sluggish during hot days but a different thing all together when the temperature drops. hot days, power only comes in a high revs from like 3500 to 4000 onwards, else cool days just below 3000 can feel it. so hot days drive is sibeh sian one, like pushing a chow turtle. If thats the case, then your CAI may not be working well. Many people just put a big open pod filter in the engine bay sucking in 80+C air coming out from the radiator. Thats totally wrong. A properly done up CAI has to take in cool air from outside the engine bay + all pipes properly insulated from the engine bay heat. This is why stock configuration works best. ↡ Advertisement Link to post Share on other sites More sharing options...
HKS Power Charger
HKS Power Charger
K&N or HKS airfilter.?
Hks 3 layer dry replacement filter
Best octane booster in local market
Coilovers exprience sharing
Looking for a HKS F Con V Pro V3.2 or 3.3
Looking for a used unit of a HKS F-Con Navigator Pro
