Apple-Tree 6th Gear October 29, 2016 Share October 29, 2016 Er ....... no leh, car cam is a low power device lor, probably 1W or so lor. These day, no many battery got water lor, all paste lor ...... cannot hydrometer loh. That is the reason why battery don't last long lor, the water in paste go electrolysis'ed lor ..... I am tempting to pour some water into my Amaron when it is about to die. See if can tahan a bit longer. There is another way a battery can become "weak". If you use car cam during parked, when your engine is not running, you're discharging the battery. If left too long in a discharged state, you're creating sulphation. Normally, the car alternator reverse the battery discharged state and charge the battery. But if left too long in a discharged state, the alternator can't reverse the sulphation. Essentially, the sulphate ions get stuck on the lead plate and does not return to the acid during charging. So now, you have a weak acid (more watery) and thus a weak electrolyte. The battery becomes sluggish and may have problem starting the engine. The way to check the electrolyte is by using a hydrometer. ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 18, 2017 Share May 18, 2017 Amaron really lasting. Mine lasts 2 years 7 mths before I decide to change. Need to crank a few times before engine can start. 4 Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear May 18, 2017 Share May 18, 2017 Amaron really lasting. Mine lasts 2 years 7 mths before I decide to change. Need to crank a few times before engine can start. IMG_7471.JPG previously i was using din74 1 Link to post Share on other sites More sharing options...
Jellandross Supersonic May 18, 2017 Share May 18, 2017 Amaron really lasting. Mine lasts 2 years 7 mths before I decide to change. Need to crank a few times before engine can start. IMG_7471.JPG My Amaron lasted 3 years. No horse run. 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 18, 2017 Share May 18, 2017 My Amaron lasted 3 years. No horse run.No wonder their slogan is Last long......really long. Link to post Share on other sites More sharing options...
Kb27 Supersonic May 18, 2017 Share May 18, 2017 Amaron also depends on "luck". I had customers that use the battery for 4~5 yrs before it totally trashed. Not many brand can boast of this. Some I changed at 2 yrs, the CCA is still close to new. It could easily last another year, maybe more. Again, most other brands at 2 yrs, the CCA is very low, close to being dead. If not, died on you on the roads. But some Amarons doesn't do so well. 2 yrs and it's dead. But min, it's always 2 yrs consistently. 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 18, 2017 Share May 18, 2017 Yep, the Amarons I have used have never last less than 2 years. Good stuff. This one I changed today the CCA was already 200+. The new one was 600+. 1 Link to post Share on other sites More sharing options...
Cypher 4th Gear May 20, 2017 Share May 20, 2017 Amaron Pro series are good. One incident that struck me was when my mech told me my battery was only 9v and I didn't noticed any difference when cranking the engine. The "Green" HiLife one can't last beyond 1 year for my case. Link to post Share on other sites More sharing options...
BoneStock 5th Gear May 21, 2017 Share May 21, 2017 Amaron also depends on "luck". I had customers that use the battery for 4~5 yrs before it totally trashed. Not many brand can boast of this. Some I changed at 2 yrs, the CCA is still close to new. It could easily last another year, maybe more. Again, most other brands at 2 yrs, the CCA is very low, close to being dead. If not, died on you on the roads. But some Amarons doesn't do so well. 2 yrs and it's dead. But min, it's always 2 yrs consistently. Thats right. My current Amaron is over 2 years and still going strong. I usually change my batts around the 2.5 year mark. Prefer Amarons also but my previous mech only carried Philippines made Motolite. Even this can last at least 2.5 years. I always change batt together with tyres. 5 Link to post Share on other sites More sharing options...
Dafansu Turbocharged May 21, 2017 Share May 21, 2017 Thats right. My current Amaron is over 2 years and still going strong. I usually change my batts around the 2.5 year mark. Prefer Amarons also but my previous mech only carried Philippines made Motolite. Even this can last at least 2.5 years. I always change batt together with tyres. almost same as me, about 2.5 years change tyres and battery. 1 Link to post Share on other sites More sharing options...
doraemon69sg 1st Gear June 7, 2017 Share June 7, 2017 -> Fcw75 Wow! Amaron 85D23 only $120 on Oct 2015? I changed at Autoserv Sengkang Amaron 85D23L for $160 on Dec 2015, huge difference of $40, 33.3% more expensive but not very sure any difference between 85D23 and 85D23L? Link to post Share on other sites More sharing options...
Kippei 3rd Gear June 7, 2017 Share June 7, 2017 -> Fcw75 Wow! Amaron 85D23 only $120 on Oct 2015? I changed at Autoserv Sengkang Amaron 85D23L for $160 on Dec 2015, huge difference of $40, 33.3% more expensive but not very sure any difference between 85D23 and 85D23L? The location of the positive post. Left side or right side Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 7, 2017 Share June 7, 2017 -> Fcw75 Wow! Amaron 85D23 only $120 on Oct 2015? I changed at Autoserv Sengkang Amaron 85D23L for $160 on Dec 2015, huge difference of $40, 33.3% more expensive but not very sure any difference between 85D23 and 85D23L? I changed 85D23L at Guan Lee on 13/3/17, price still at $120. Link to post Share on other sites More sharing options...
Kb27 Supersonic June 7, 2017 Share June 7, 2017 -> Fcw75 Wow! Amaron 85D23 only $120 on Oct 2015? I changed at Autoserv Sengkang Amaron 85D23L for $160 on Dec 2015, huge difference of $40, 33.3% more expensive but not very sure any difference between 85D23 and 85D23L? There are 2 types. 85D23L - L = left 85D23R - R = right The difference is the position of the positive and negative post. Most cars are using L. A few use R. 1 Link to post Share on other sites More sharing options...
doraemon69sg 1st Gear June 8, 2017 Share June 8, 2017 I changed 85D23L at Guan Lee on 13/3/17, price still at $120.Thanks! Bro. I think I have been ripped off by the workshop. Link to post Share on other sites More sharing options...
Freeder Hypersonic June 8, 2017 Share June 8, 2017 (edited) Amaron batteries are made to last.. Mine already 3.5 yrs old n voltage level still ard 13.9... They are made for the harsh conditions in India Edited June 8, 2017 by Freeder 13 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 8, 2017 Share June 8, 2017 Amaron batteries are made to last.. Mine already 3.5 yrs old n voltage level still ard 13.9... They are made for the harsh conditions in Indiað Unbelievable..... 13.9? That's probably when the alternator is charging. Do check the CCA too. 1 Link to post Share on other sites More sharing options...
Ahzq17 1st Gear September 12, 2017 Share September 12, 2017 Amaron batteries don't last as Long as last time already. Quality is dropping. ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
From Servicing to Roadside Assistance 🚗 - Drive Worry-Free with Sgcarmart for $99
Battery for Honda Vezel
