Samudra1 Neutral Newbie December 8, 2012 Share December 8, 2012 Anyone got workshop to recommend to change the oxygen sensor? there is no such thing as oxygen sensor----not that sophicated. car engine only need ordinary air. ↡ Advertisement Link to post Share on other sites More sharing options...
Phmaksg Clutched December 8, 2012 Share December 8, 2012 Anyone got workshop to recommend to change the oxygen sensor? I juz have my Oxygen sensor replaced for my Sylphy early this week for total of $2xx at Autoaid at Toh Guan Enterprise. Link to post Share on other sites More sharing options...
Ngsengpoh Neutral Newbie December 8, 2012 Author Share December 8, 2012 there is no such thing as oxygen sensor----not that sophicated. car engine only need ordinary air. Oxygen sensor or we call it O2 sensor is place at the exhaust. Maybe u may google it and check it out. Link to post Share on other sites More sharing options...
Kianbeng Clutched December 8, 2012 Share December 8, 2012 MAF sensor replacement can DIY . OIxygen sensor a bit more labour involved. I changed MAF and O2 sensors, DIY. But of course, different makes, different prices.... Actually these are all quite easy to change. MAF is at the intake hose usually after the air filter box. O2, for some cars have 2. before and after CAT. Usually just a screw in part with a socket for the wires. Link to post Share on other sites More sharing options...
Kianbeng Clutched December 8, 2012 Share December 8, 2012 there is no such thing as oxygen sensor----not that sophicated. car engine only need ordinary air. O2 sensor = Oxygen sensor. I think since 1980s already got O2 sensors in many cars. Bro, cars are much more sophisticated than you think they are. Link to post Share on other sites More sharing options...
kqkhlj Clutched December 8, 2012 Share December 8, 2012 maybe sensor dirty, try cleaning it before buying the part. if limited knowledge, go and find those bros in this forum, treat them roti prata and coffee will do... they are quite helpful... Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 9, 2012 Share December 9, 2012 O2 sensor = Oxygen sensor. I think since 1980s already got O2 sensors in many cars. Bro, cars are much more sophisticated than you think they are. U see his nick. Prob fm jungles of indonesia. Most still using bullock cart. Cars n trucks there all fm WW2. Those no air filter even. Link to post Share on other sites More sharing options...
Pisces69 6th Gear December 9, 2012 Share December 9, 2012 Thks bro, kelvin quote me $320 include labour. Start wh a can of carb cleaner only 5 bucks. Also check wiring connection if loose. Simple things first n u save a bundle. Why u so rush to spend 300 plus hard earned dollars. Link to post Share on other sites More sharing options...
Ngsengpoh Neutral Newbie December 9, 2012 Author Share December 9, 2012 Start wh a can of carb cleaner only 5 bucks. Also check wiring connection if loose. Simple things first n u save a bundle. Why u so rush to spend 300 plus hard earned dollars. Yesterday TC there had cleaned for me during the second trip and also reset for second time. But the light came on within an hour. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 9, 2012 Share December 9, 2012 Fault code reader indicates o2 sensor maybe at fault, it's not 100% ,maybe it can be due to connection and other problems created upstream from O2 to on-board computer. The next task is to do a O2 simulation test ( off course with a O2 simulator) to confirm the O2 is unable to switch from close to open loop. Until then, do not wast yr money, many shop mech alway shoot from their hips, after all it's the customers money and time. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 9, 2012 Share December 9, 2012 You will be surprise to see the latest Landrovers and other US off road vehicles operating out in many oil palm plantations. Watch Indonesia and Philippines, these two countries will be the rising stars among the ASEAN countries and whole of Asia Pacific regions. Burma will come along but need another decade to "clean up " and do catch up. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 9, 2012 Share December 9, 2012 Link to post Share on other sites More sharing options...
Ngsengpoh Neutral Newbie December 9, 2012 Author Share December 9, 2012 Fault code reader indicates o2 sensor maybe at fault, it's not 100% ,maybe it can be due to connection and other problems created upstream from O2 to on-board computer. The next task is to do a O2 simulation test ( off course with a O2 simulator) to confirm the O2 is unable to switch from close to open loop. Until then, do not wast yr money, many shop mech alway shoot from their hips, after all it's the customers money and time. Bro O2 simulation test can be done at any workshop? Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 9, 2012 Share December 9, 2012 (edited) I am not sure whether there is any shop has this tester. Shops in Singapore hardly invest in diagnostic tools. Edited December 9, 2012 by Yeobh Link to post Share on other sites More sharing options...
Ngsengpoh Neutral Newbie December 9, 2012 Author Share December 9, 2012 I am not sure whether there is any shop has this tester. Shops in Singapore hardly invest in diagnostic tools. Ok nvm. Tomorrow I'll be going to the workshop to get it done. For the safety of my children. Cause most of the time using the car to fetch them. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 9, 2012 Share December 9, 2012 Don't worry, the most the car will just go into limp mode - that means that you will be unable to drive at cruising speed. Once you managed to stop, the car will refuse to start again , that's all. If the O2 sensors are faulty, yr fuel consumption will go up, as the fuel monitoring system is unable to switch from rich to lead. Just monitor you fuel consumption over few weeks, chances you have have the telltale sign of a faulty O2 sensor. Link to post Share on other sites More sharing options...
Ngsengpoh Neutral Newbie December 9, 2012 Author Share December 9, 2012 Anyone been to Yong Motor at AMK autopoint? How's the workmanship and price there? Link to post Share on other sites More sharing options...
Guangson Neutral Newbie December 9, 2012 Share December 9, 2012 Was Jam at traffic at causway yesterday. and my engine lights also light up. Am driving a sylphy 2.0 Need to go workshop to check for it already on monday. ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone watches MMA?
Anyone watches MMA?
Green fingers anyone?
Anyone try Cathay Pacific before?
New Zealand - anyone?
