Yeobh 4th Gear April 1, 2013 Share April 1, 2013 Should not jump into conclusion and blame on engine oil, there are other factors to consider. ↡ Advertisement Link to post Share on other sites More sharing options...
Solar Turbocharged April 1, 2013 Share April 1, 2013 I would want to believe in both becos one manufactured the car and the other maintains it! :) Hmm... BTW, my bad I didn't mention my car's boost has been raised from stock 0.6 max to 1.2 max with an uprated turbo. Do you guys recon the 10w30 recommended by manufacturer still applicable? if stock, yes, just follow the book. perhaps increase the weight as it gets older. my previous LGT was running on w30 for years without any issue only at its 5th birthday onwards i started using w40 but if u upgraded something, yes, maybe thicker oil as precaution. Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 1, 2013 Share April 1, 2013 i have been told by workshop mech to use w50 for my turbo-charged car. F it...i have been using w40 all this while..and the engine runs great... It depends on whcih turbo car you drive. WRX only needs 5-30 while non turbo Mercedes 200 needs 5-40. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear April 1, 2013 Share April 1, 2013 Should not jump into conclusion and blame on engine oil, there are other factors to consider. Still monitoring the situation of course, hope it not the case cause W20 really shiok. Link to post Share on other sites More sharing options...
Orixy 2nd Gear April 2, 2013 Share April 2, 2013 Still monitoring the situation of course, hope it not the case cause W20 really shiok. Hi, can share with us how do you monitor the situation? Tks Link to post Share on other sites More sharing options...
Trex101 3rd Gear April 2, 2013 Share April 2, 2013 Still monitoring the situation of course, hope it not the case cause W20 really shiok. Cranking problem are usually cause by battery or fuel filter, check both. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear April 3, 2013 Share April 3, 2013 Cranking problem are usually cause by battery or fuel filter, check both. This few days didn't seem to see this problem. But how battery or fuel filter can cause this even engine start hot? Link to post Share on other sites More sharing options...
Ckchong8 1st Gear April 3, 2013 Share April 3, 2013 Hi, can share with us how do you monitor the situation? Tks The problem appeared when the engine start hot. So spending a few days travel a certain distance Stop the engine and restart to see whether this symtom persist. This few days seem fine yet to see any of the repeated cracking issue. ↡ Advertisement Link to post Share on other sites More sharing options...
Math Question
Math Question
Question on Transfer of Car Ownership
Question for Car Servicing
COE renewal question
Question of polyclinics
Noob questions on property
PSLE Maths question. How to solve?
