Eric76 1st Gear January 16, 2013 Share January 16, 2013 going to change oil aft 3 yrs servicing by AD....wanna try the M1 and find out got many types, 0w-30, 5w-30, 5w-40....one question on the SAE rating, understand the last number is rep the highest air temp of the surrounding weather the oil can tahan, so as sg tropical temp almost always exceed 30, does that mean we should not use oil rated 30 and below? but seems like a lot of bros using leh, how come... ↡ Advertisement Link to post Share on other sites More sharing options...
Ruzmidah 2nd Gear January 16, 2013 Share January 16, 2013 From what I know . eg: 0w30 = thickness = 30 = 0 = something like the freezing point. In Sunny singapore the 1st digit "0" not important as our weather is quite stable (ie, not sub zero temp) We only need to look at the last 2 digits (ie "30") . Link to post Share on other sites More sharing options...
Sabian Turbocharged January 16, 2013 Share January 16, 2013 I have using 5w-30 on my Japanese bread & butter car for almost 8 years. But I keep to the servicing schedule. Link to post Share on other sites More sharing options...
TVT Supercharged January 16, 2013 Share January 16, 2013 The first digit '0w' or '5w' is not significant as it relates to cold start in colder countries. The last 2 digits relates to the oil thickness. The bigger the number, the thicker the oil. Usually higher performance cars and older cars will use thicker oil to protect the engine. Younger cars using 30 or 40 should be just fine. Link to post Share on other sites More sharing options...
Baphomet 3rd Gear January 17, 2013 Share January 17, 2013 i normally uses 0w30...recently changed to 5w40....engine seems rougher and lacking in power and fuel consumption increases... Link to post Share on other sites More sharing options...
Lattesurf Neutral Newbie January 17, 2013 Share January 17, 2013 As others have mentioned, the SAE number before the W is for cold weathers, not applicable in SG unless it snows. Number after W is the viscosity (thickness) of the oil. Larger number = Thicker viscosity. When oil is hot, it becomes thinner. What it means is that at high temperatures, the oil will only thin upto the rated number after W. eg W30, W40. Usually older cars and some performance cars will need higher SAE rating for better protection. But thicker also means more resistance to the engine and results in higher FC and sluggishness. Probably more evident in small cc cars. Large cc cars shouldn't feel much difference. Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 17, 2013 Share January 17, 2013 You need to choose the oil based on the car you drive. Some Hondas use 5w20 while some Alfas 10w60 Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 17, 2013 Share January 17, 2013 (edited) Car designers and application test engineers have conduct much more studies and testing than what you have thought about oil viscosity. So no need to worry so much , just follow what is recommended in the car user handbook. Edited January 17, 2013 by Yeobh Link to post Share on other sites More sharing options...
Eric76 1st Gear January 17, 2013 Author Share January 17, 2013 As others have mentioned, the SAE number before the W is for cold weathers, not applicable in SG unless it snows. Number after W is the viscosity (thickness) of the oil. Larger number = Thicker viscosity. When oil is hot, it becomes thinner. What it means is that at high temperatures, the oil will only thin upto the rated number after W. eg W30, W40. Usually older cars and some performance cars will need higher SAE rating for better protection. But thicker also means more resistance to the engine and results in higher FC and sluggishness. Probably more evident in small cc cars. Large cc cars shouldn't feel much difference. tks all really learned sth, thk will go and try w30 as my car still quite new Link to post Share on other sites More sharing options...
5936 1st Gear January 17, 2013 Share January 17, 2013 I agree to what bro Yeoh said. Follow recommendations on your manual with regular svc. EO subject can be very complicated if one choose to go into it's details. Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 17, 2013 Share January 17, 2013 I really don't understand how people can base their oil on air temp and not what is recommended for their car by the manufacturer. Link to post Share on other sites More sharing options...
Orixy 2nd Gear March 31, 2013 Share March 31, 2013 Car designers and application test engineers have conduct much more studies and testing than what you have thought about oil viscosity. So no need to worry so much , just follow what is recommended in the car user handbook. I drive a parallel imported JDM car and the driver's manual (in full Japanese language) indicated use of 10w30 for ambient temps between -20 to 40 Celsius. My mechanic recons that the 10w30 will be fine for a cold country like Japan but 5w40 would be for better protection in a tropical country like Singapore. He also said that since my car is turbo-charged, a thicker viscosity oil will offer better protection for the turbo. Which should I believe? Thanks in advance for any inputs on this. Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 31, 2013 Share March 31, 2013 A simpler question to answer.... you believe a R&D engineer in EO or a workshop mechanics????? Link to post Share on other sites More sharing options...
Longg8 Clutched March 31, 2013 Share March 31, 2013 I drive a parallel imported JDM car and the driver's manual (in full Japanese language) indicated use of 10w30 for ambient temps between -20 to 40 Celsius. My mechanic recons that the 10w30 will be fine for a cold country like Japan but 5w40 would be for better protection in a tropical country like Singapore. He also said that since my car is turbo-charged, a thicker viscosity oil will offer better protection for the turbo. Which should I believe? Thanks in advance for any inputs on this. i have been told by workshop mech to use w50 for my turbo-charged car. F it...i have been using w40 all this while..and the engine runs great... Link to post Share on other sites More sharing options...
ER-3682 Supersonic March 31, 2013 Share March 31, 2013 I drive a parallel imported JDM car and the driver's manual (in full Japanese language) indicated use of 10w30 for ambient temps between -20 to 40 Celsius. My mechanic recons that the 10w30 will be fine for a cold country like Japan but 5w40 would be for better protection in a tropical country like Singapore. He also said that since my car is turbo-charged, a thicker viscosity oil will offer better protection for the turbo. Which should I believe? Thanks in advance for any inputs on this. Depends on you wants to track the car.?Or for normal driving.?Tracking the car,need 'thicker' oil,normal driving,follows owner's manual. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear April 1, 2013 Share April 1, 2013 Car designers and application test engineers have conduct much more studies and testing than what you have thought about oil viscosity. So no need to worry so much , just follow what is recommended in the car user handbook. Was using all along w30 or 40 the pickup seem very sluggish, currently based on manual go back to W20. Some said that the engine will loud but i feel it very silence and pickup excellence. One question, could w20 have wear n tear problem if i running long distance which the oil getting thinner when it getting hotter ? What are the symtom to this, one thing for sure when i start my engine hot the crank repeatedly thrie times Then only start. Didnt have this issue for the W30 n W40, my ride 4 1/2 yrs. Thks Link to post Share on other sites More sharing options...
Cephas 3rd Gear April 1, 2013 Share April 1, 2013 The viscosity of a fluid is a measure of its resistance to gradual deformation by shear stress or tensile stress. For liquids, it corresponds to the informal notion of "thickness". For example, honey has a higher viscosity than water.[1] Viscosity is due to friction between neighboring parcels of the fluid that are moving at different velocities. When fluid is forced through a tube, the fluid generally moves faster near the axis and very little near the walls, therefore some stress (such as a pressure difference between the two ends of the tube) is needed to overcome the friction between layers and keep the fluid moving. For the same velocity pattern, the stress is proportional to the fluid's viscosity. A fluid that has no resistance to shear stress is known as an ideal fluid or inviscid fluid. In the real world, zero viscosity is observed only at very low temperatures, in superfluids. Otherwise all fluids have positive viscosity. If the viscosity is very high, such as in pitch, the fluid will seem to be a solid in the short term. In common usage, a liquid whose viscosity is less than that of water is known as a mobile liquid, while a substance with a viscosity substantially greater than water is simply called a viscous liquid. From Wiki. Link to post Share on other sites More sharing options...
Orixy 2nd Gear April 1, 2013 Share April 1, 2013 A simpler question to answer.... you believe a R&D engineer in EO or a workshop mechanics????? I would want to believe in both becos one manufactured the car and the other maintains it! :) Hmm... BTW, my bad I didn't mention my car's boost has been raised from stock 0.6 max to 1.2 max with an uprated turbo. Do you guys recon the 10w30 recommended by manufacturer still applicable? ↡ Advertisement Link to post Share on other sites More sharing options...
Math Question
Math Question
Question on Transfer of Car Ownership
Question for Car Servicing
COE renewal question
Question of polyclinics
Noob questions on property
PSLE Maths question. How to solve?
