Kb27 Supersonic December 11, 2014 Share December 11, 2014 the pix u showin is diy type or pro one? i saw smthg similar at diy store. I have a professional booster cable and cost $90. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 11, 2014 Share December 11, 2014 the pix u showin is diy type or pro one? i saw smthg similar at diy store. Professional Mech Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 11, 2014 Share December 11, 2014 MF = no way to check battery condition until it went flat. the Eco-R battery is classified under MF type but it does allow one to check or top up the electrolyte. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged December 11, 2014 Share December 11, 2014 I have a professional booster cable and cost $90. how many amp? those 200amp i saw at diy cost below 30, 400amp cost below 40. Professional Mech ok tks. so it safe to buy if i know my car / batt amp. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 11, 2014 Share December 11, 2014 (edited) the Eco-R battery is classified under MF type but it does allow one to check or top up the electrolyte. It's maintenance free but still can top up battery water? Then might as well buy a maintenance battery in the first place, much cheaper I suppose. Either get a totally maintenance free battery or get a battery that need maintenance. Maybe it's just me. Edited December 11, 2014 by Fcw75 Link to post Share on other sites More sharing options...
Hamburger Hypersonic December 11, 2014 Share December 11, 2014 how many amp? those 200amp i saw at diy cost below 30, 400amp cost below 40. ok tks. so it safe to buy if i know my car / batt amp. trust me, these are cables that will prove they wont work when you most needed them. i HAD one of that and ...argh!!!!!! Link to post Share on other sites More sharing options...
Kb27 Supersonic December 11, 2014 Share December 11, 2014 how many amp? those 200amp i saw at diy cost below 30, 400amp cost below 40. The amp number is nonsense. They should be advertising the wire gauge instead. If you get a 8 awg wire, they can rate it as 200 amp or 600 amp, up to them. Those below $30 type are usually 10 awg wire. I bought from http://www.chophockhong.com.sg/ It's only rated 200 amp, but the wire size is really big, something like 0 awg. Awg number the lower the thicker is the wire. It can jump start diesel lorries. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 11, 2014 Share December 11, 2014 It's maintenance free but still can top up battery water? Then might as well buy a maintenance battery in the first place, much cheaper I suppose. Either get a totally maintenance free battery or get a battery that need maintenance. Maybe it's just me. "The ECO-R battery is also equipped with a vent valve, which enables the refill of water so as to maintain the correct electrolyte level, thus preventing battery explosion due to low electrolyte levels, increasing the battery's service lifespan." extracted from http://www.sgcarmart.com/news/events_features.php?AID=2953&PN=2 i believe this is mandatory under Japan's automotive law to prevent an accident due to battery explosion. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 11, 2014 Share December 11, 2014 I using this one, for many years already. Start car, van and even forklift...haha. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 11, 2014 Share December 11, 2014 i made use of 8 AWG cable for grounding. would such cable be safe for jump-starting a car? Link to post Share on other sites More sharing options...
Kb27 Supersonic December 11, 2014 Share December 11, 2014 i made use of 8 AWG cable for grounding. would such cable be safe for jump-starting a car? It depends on the length of the wire. Thicker wire has less resistance or voltage drop. The longer the wire the more the voltage drop. Those lithium jump starter only has 10 awg wire, but they are very short, about 6 inch, so they can jump start a car. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged December 11, 2014 Share December 11, 2014 trust me, these are cables that will prove they wont work when you most needed them. i HAD one of that and ...argh!!!!!! tks i'll avoid at all cost. It depends on the length of the wire. Thicker wire has less resistance or voltage drop. The longer the wire the more the voltage drop. Those lithium jump starter only has 10 awg wire, but they are very short, about 6 inch, so they can jump start a car. tks, i'll take note of that. Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear January 10, 2015 Share January 10, 2015 What should the resting voltage of a 12v. car battery be , 2 hours after driving the car ? I think when bought new , the voltage is 12.70 volts. What resting voltage would be a hint the batt. is about to fail , and should be replaced ? Or can this only be determined by a cranking/amp test at a dealership or battery seller ? I realize age and heat are a factor too , but some seem to last years longer than others. I'm also not sure the Brand name assures longer life either. On some batteries you can't even check the electrolite level or top it off Recently i add on 2 lcd monitor which is 9inch big. Will it eat lots of current? I was trying to add on some led light myself.. but not sure if the load will be too much Link to post Share on other sites More sharing options...
FastFixer February 17, 2015 Share February 17, 2015 What should the resting voltage of a 12v. car battery be , 2 hours after driving the car ? I think when bought new , the voltage is 12.70 volts. What resting voltage would be a hint the batt. is about to fail , and should be replaced ? Or can this only be determined by a cranking/amp test at a dealership or battery seller ? I realize age and heat are a factor too , but some seem to last years longer than others. I'm also not sure the Brand name assures longer life either. On some batteries you can't even check the electrolite level or top it off Recently i add on 2 lcd monitor which is 9inch big. Will it eat lots of current? I was trying to add on some led light myself.. but not sure if the load will be too much The car battery is only used to start the car. Once the car has started - the battery's job ends and it will be recharged (as necessary) by the alternator (ie. charging system). That's how cars are designed. Given this, it does not really matter that its "2 hours after driving the car". :) For the resting voltage, a very healthy voltage reading would be between 12.4 and 12.6v. If you have "parasites" (ie. car camera, lights and other items requiring constant battery), you may find a lower voltage. If the voltage goes below 10v, get a new car battery before you car dies suddenly. Of course we recommend FastFix www.fastfix.com.sg (Hotline: 81145500). Since the car hasn't died yet, go to them and save the onsite fee ($40). You will get a very good deal from them. Yes, one more thing: it is not really the voltage that determines if the car battery is able to start the car, it is the "CCA" (cold cranking ampere) -- this refers to the amount of current that the battery can supply for 30sec at 1.2V, what is needed to crank the engine. All battery sellers have the device to test this. As for age, we recommend that a car battery be changed every 2-years in Singapore due to our hot weather. This will save you from the hassle, anxiety and frustration of a dead battery. And you will even save money because you won't need an onsite rescue! For the LCD monitors and other electrical items - they'll be OK as long as they do not consume electricity when your car is off - else they are what we call "parasites": bad for your car battery. Hope this helps! 1 Link to post Share on other sites More sharing options...
Kippei 3rd Gear February 17, 2015 Share February 17, 2015 I installed this http://www.amazon.com/Pulsetech-PowerPulse-12-Volt-Battery-Maintenance/dp/B004I6QREK/ref=sr_1_1?s=automotive&ie=UTF8&qid=1424186942&sr=1-1&keywords=pulsetech Lets see how long my battery last. Link to post Share on other sites More sharing options...
Chiongkakis Clutched February 18, 2015 Share February 18, 2015 My amaron last 4 yrs+ alrd....... still running well. 4 yrs is amazing.. how did u do that? Link to post Share on other sites More sharing options...
Adrianli Hypersonic February 18, 2015 Share February 18, 2015 Not sure if this is selling here, Panasonic Life WINK. It monitors the car battery and indicates when it is time to change. For accuracy, u have to install it when the battery is new. Cant find any reviews in english, its a japanese product. http://panasonic.jp/car/battery/lifewink/lw01.html https://www.youtube.com/watch?v=AfMpZWldiP0 Link to post Share on other sites More sharing options...
Kb27 Supersonic February 18, 2015 Share February 18, 2015 4 yrs is amazing.. how did u do that? First, take care of your battery. 1. Reduce its load during cranking - Switch off aircon/lights before cranking. If you have manual gear, clutched in before cranking. 2. Reduce parasitic loads - loads that are using the battery when engine is switched off, like forgetting to switch off lights, or cameras that are switched on while parked 3. Avoid deep discharge, when engine is switched off - playing radio while waiting for someone or washing car, vacuuming, all these actions deep discharged the battery. 4. If you're able to do, regularly charged the battery off an AC supply every 6 months or so. Equalizing charge is needed. Finally, get a reliable brand of battery, that's Amaron in my books. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
My EV journey to the i4
Tool to change Spark Plug
Battery for Honda Vezel
Change Disc Rotors
Change Disc Rotors
