GoofRider Neutral Newbie August 1, 2013 Share August 1, 2013 Saw a Sg plate Exora with R3 parts suchs as light pulley,R3 air intake and R3 rims at my usual Larkin workshop but owner not seen,Exora is CPS black normal plate SJZ1xxx with fog lights and oval muffler.Any bro owner here? R3 light crank pulley and intake.. nice.. wonder how much it cost.. ↡ Advertisement Link to post Share on other sites More sharing options...
Nasiroo25 Neutral Newbie August 4, 2013 Share August 4, 2013 im back after a very very long time. been enjoying my ride for the past 1.5 yrs still trying to keep it look as new since the day I got. have a issue recently and I remember seeing it highlighted in this forum. after switching off engine can still hear some engine running nosie, not sure where its coming from... I will switch my engine on again then rev a few times and switch off then totally silent.... only 1.5yrs old got this problem . 1 Link to post Share on other sites More sharing options...
GoofRider Neutral Newbie August 5, 2013 Share August 5, 2013 im back after a very very long time. been enjoying my ride for the past 1.5 yrs still trying to keep it look as new since the day I got. have a issue recently and I remember seeing it highlighted in this forum. after switching off engine can still hear some engine running nosie, not sure where its coming from... I will switch my engine on again then rev a few times and switch off then totally silent.... only 1.5yrs old got this problem . I belive the sound is from the fan. When u off ur engine and the engine is still 'hot' to the sensor, the fan will continue to turn till a appropriate temperature to be eventual stop.. It happen to me. Maybe what u can do is on your engine and on ur aircon.check if both fans is turning. I found out one of my fan kaput.. so I change.. Link to post Share on other sites More sharing options...
TVT Supercharged August 5, 2013 Share August 5, 2013 im back after a very very long time. been enjoying my ride for the past 1.5 yrs still trying to keep it look as new since the day I got. have a issue recently and I remember seeing it highlighted in this forum. after switching off engine can still hear some engine running nosie, not sure where its coming from... I will switch my engine on again then rev a few times and switch off then totally silent.... only 1.5yrs old got this problem . It should be the radiator fan. It will auto off after about 10 mins. To confirm this, when the sound occur again, lift up your bonnet and look inside to see if the fan is still turning. Link to post Share on other sites More sharing options...
Panhard 1st Gear August 12, 2013 Share August 12, 2013 I belive the sound is from the fan. When u off ur engine and the engine is still 'hot' to the sensor, the fan will continue to turn till a appropriate temperature to be eventual stop.. It happen to me. Maybe what u can do is on your engine and on ur aircon.check if both fans is turning. I found out one of my fan kaput.. so I change.. How much you paid for the fan? Link to post Share on other sites More sharing options...
GoofRider Neutral Newbie August 13, 2013 Share August 13, 2013 How much you paid for the fan? Alamak bro cant remember. . Hehe.. Do it in jb.. Link to post Share on other sites More sharing options...
Shorty Turbocharged August 27, 2013 Share August 27, 2013 any bro out there changed battery b4? can advise me where n how much. my cranking getting weaker...guess it's time to change. Link to post Share on other sites More sharing options...
Noirmubin Clutched August 30, 2013 Share August 30, 2013 any bro out there changed battery b4? can advise me where n how much. my cranking getting weaker...guess it's time to change. I change once, Bro. Car just couldn't start at my house MSCP in the morning. Saw the battery light indicator on. Car's already 3.5yrs. Gotta call the 24hrs online "Dial-A-Battery" here in mycarforum. The chap's good. Arrive about 12 plus in the afternoon. Kena pay 100plus (cant recall exactly how much). Battery now got written "Dec 12". 1 Link to post Share on other sites More sharing options...
Mandrew 1st Gear August 30, 2013 Share August 30, 2013 any bro out there changed battery b4? can advise me where n how much. my cranking getting weaker...guess it's time to change. I have changed mine to Amaron 90D23L Battery which is a bit more powerful than the Stock Battery (60AH) last year. If I'm not wrong, paid $140 from EPS (Cash and Carry) Link to post Share on other sites More sharing options...
Panhard 1st Gear August 31, 2013 Share August 31, 2013 Once you hear cranking weaker better replace battery esp.if already more than 2 or 3 years old. Because one day without warning will just not crank at all. Just had my radiator fan (bigger one) replaced, motor shorted & caused fuse to blow. That explains why I was having the engine check light appearing. Had it replaced with an oem fan motor (brand-yuki) Taiwan made. Part cost $170/- labour $25/-. Link to post Share on other sites More sharing options...
Human Clutched September 2, 2013 Share September 2, 2013 change mine last month Amaron 60ah. supplier fixed for me at $145. Link to post Share on other sites More sharing options...
Coolpica 4th Gear September 9, 2013 Share September 9, 2013 Exora CFE would be moved to Cat B under new LTA COE criteria. LTA New COE Criteria Would u still buy a Exora under Cat B COE? Demise of Exora is on the wall? Link to post Share on other sites More sharing options...
Shorty Turbocharged September 9, 2013 Share September 9, 2013 Exora CFE would be moved to Cat B under new LTA COE criteria. LTA New COE Criteria Would u still buy a Exora under Cat B COE? Demise of Exora is on the wall? it could lead to a significant change in coe prices... Link to post Share on other sites More sharing options...
Panhard 1st Gear September 10, 2013 Share September 10, 2013 There is hope..... The cps version is below 130hp Link to post Share on other sites More sharing options...
Remierwan 1st Gear September 10, 2013 Share September 10, 2013 Exora CFE would be moved to Cat B under new LTA COE criteria. LTA New COE Criteria Would u still buy a Exora under Cat B COE? Demise of Exora is on the wall? How many models of Exora are there? Any model below 130bhp? 1 Link to post Share on other sites More sharing options...
Colin03 4th Gear September 10, 2013 Share September 10, 2013 Just wonder what are the other models affected under this new scheme , anyone can advise. 1 Link to post Share on other sites More sharing options...
Coolpica 4th Gear September 14, 2013 Share September 14, 2013 Personally felt that CPS version underpowered and thus leading to high FC. Guess turbo charged engine for Exora is more suitable. Link to post Share on other sites More sharing options...
JohnJubolovic77 Clutched September 22, 2013 Share September 22, 2013 To all Proton Campro Singapore owners,Tired of your drive by wire lag and low current flow? Well I've done installing 3 copper ground cables RM105,Did throttle respond RM50,Cleaning and service of throttle body RM50 and do pedal response RM50 for my saga Blm 1.3 At.Result is better current flow more cooling aircon, brighter headlights and best of all no lag of response even when aircon compressor kicks in My Jb friend will do for you be it at Larkin,Skudai or even Angsana..Any enquiries pls what's app me @ 91460056 Next month I will do my exora cps and we shall see how,cause my saga Blm 1.3 AT already get 60%!result and next time will fit another 2 more cables with anti rust bracket ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Proton eMas 5 previewed – rebadged Geome Xingyuan, RWD, 250 to 325 km WLTP
Vincar to distribute Proton’s first electric vehicle in Singapore
Proton overseas
Proton overseas
New Proton Perdona.
New Proton Perdona.
Proton To Introduce smart Electric Vehicles In Malaysia
2022 Proton Persona 1.6 Premium
2022 Persona & Iriz facelift
27 year old Malaysian save money driving a 21-year-old Proton Saga
