Proton Exora#2
SGXora
For those who service or change parts in jb, pls recommend a gd shop. Going for my 40k soon n also need to change brake pad. Is 40k a major servicing or normal?...
Shorty theres handful,Wan fast auto garage at permas jaya,Knights garage inc at tun aminah skudai.All Campro professional and their participation in drag racing proves it
anyone done 40k servicing already? what do i hv to change? i hv some idea...correct me if i'm wrong. following which i think i need to change:
- engine oil
- spark plug
- ATF
anything else? i hv changed power steering fluid 6mths ago only.
Ive two Campro,one is Iafm another cps,Right now the iafm im using BHP 8000 fully synthetic bought for RM188 and using NGK Platinum plugs costing RM70.The CPS using Liqui Moly fully synthetic cost RM220 and using NGK Iridium plugs for RM145
- engine oil
- spark plug
- ATF
It is advisable to replace the following if you have not done so:
1) Brake Fluid
2) Radiator coolant
3) Spark plugs
Took the plunge n changed to 17" rims. Expecting fuel consumption to become worse.
[thumbsup]
It won't be that worse if you upgraded from 16 to 17".
But if the original is 15", then maybe.....
Also understand that it also depends on the RIM weight....
I'm using the normal heavy ones, and Japanese ones are light weight but expensive....
Recently I was parking at my Multi-storey Car park and while reversing the Wheel went over the side ramp....
And somehow my Continental CPC5 tyre bursted out.... [bigcry] and cannot be repaired so had to go for a New one [bigcry]
Edited by Mandrew
my stock was 15"...so will definitely feel the difference. n no way can i afford those lightweight rims. hehe. wanted to change to 16"...but very very limited designs for 16". n this shop offer me same price for 16 n 17. so i jus took 17.
wah ur cpc5 quite high end one leh...
Edited by Shorty
Wow... that's good.... I thought it's going to be a huge amount... Thanks.
Just done the 20k servicing for my CFE..... it was around S$150...
Understand that the 40k and 60k service is very expensive here in SG....
I noticed that the Proton exclusive Service Centre is not there anymore in TTS (that space is been handed over back to Delgro) and they do it together at their common area.
Saw a few Exoras there for service and repairs...
Sharing for your info.....
I shared before regarding a jerking problem and also during reversing for my CFE... very initially..
The issue got resolved after changing the fuel valve and after the update of ECU & TCU ....
(initially the update was not done properly which caused some other issues like a intermittent slipping of gear [for the gearless] sort of vibration with a sound when in very slow drive especially during traffic jam.)
Somehow these 'solved' issues stared coming back recently.... and during this 20k service they updated the ECU again and the problem got resolved again. Not sure how come the issue came back again....
Not sure whether it got back to its earlier stage as my Battery got flat ... (had to jump start as I was out of station and did not start the car for about 1 month)...
Anyways... they asked me to monitor.....
might wanna change back to 15"or try get 16" rims. dunno y not comfortable using 17"...or is it jus in my mind. after so long use small rims, using this 17" feel so different. who interested let me know.
Facing new issue for my CFE......
Getting very strong Petrol smell inside the Car after running few KM.
Initially I thought it is due to the Full tank I filled in, but then this is repeatedly occurring after the Petrol gauge reduced by 1 tab.
No visible leak outside or no sudden increase in Petrol consumption...
Will be taking to SC soon....
Any of your ride showing the same problem?
Regards
I've been driving the Exora CPS for the past 3+ years, and the issue of external smell getting into the car when it is stationary has always been there since day 1, despite the air circulation button on the car set to closed (ie no outside air to be let in). It gets especially bad when the car is stopped at a tracffic junction with a bus, truck or heavy vehicle beside me. My family memebers would complain of the strong smoke smell, and I would have to wind the windows down thereafter to circulate the air.
I've reported this to the Proton service centre each time it was there for scheduled servicing, but they still could not find the problem. Kind of given up on this issue already. My previous rides never had such problems. [:(]
Regards
Took my ride to TTS y'day.
They went through a thorough check and couldn't find any Petrol leak.
They suspect that it might have contributed from the Petrol Cap area so done the Sealant and gave back to me after a few trial runs....
Saw from other forum 2 members sharing that they also faced this issue and got solved after SC put the sealant.
So far no issues..... still monitoring.
My FC averages around 8 to 8.5km/l, with 60% city/40% highway. For 80 to 90% highway sometimes I can get around 10km/l. The best achieved was around 11km/l with half a day's drive on the expressway in JB.
