Aerosmith 2nd Gear October 2, 2013 Share October 2, 2013 i have 2 problems. 1. moving at low speeds below 30km/hr got some funny sound that sounds like whistling. read up online, seems like a common problem, either an undercarriage loose screw or tensioner problem. 2. when braking from high speeds >90km/hr, steering wheel will vibrate terribly, most probably a brake pad uneven or something. seems it is a common issue again. is there a workshop good with nissan vehicles like the sylphy? don't want Tan Chong cause so expensive. anyone driving sylphy suffer same issue? ↡ Advertisement Link to post Share on other sites More sharing options...
Tohto Hypersonic October 2, 2013 Share October 2, 2013 AutoSaver Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear October 2, 2013 Share October 2, 2013 i have 2 problems. 1. moving at low speeds below 30km/hr got some funny sound that sounds like whistling. read up online, seems like a common problem, either an undercarriage loose screw or tensioner problem. 2. when braking from high speeds >90km/hr, steering wheel will vibrate terribly, most probably a brake pad uneven or something. seems it is a common issue again. is there a workshop good with nissan vehicles like the sylphy? don't want Tan Chong cause so expensive. anyone driving sylphy suffer same issue? Changed the rotors and it will be solved.. you can try AutoAid or AutoSaver.. Link to post Share on other sites More sharing options...
Vid Hypersonic October 2, 2013 Share October 2, 2013 i have 2 problems. 1. moving at low speeds below 30km/hr got some funny sound that sounds like whistling. read up online, seems like a common problem, either an undercarriage loose screw or tensioner problem. 2. when braking from high speeds >90km/hr, steering wheel will vibrate terribly, most probably a brake pad uneven or something. seems it is a common issue again. is there a workshop good with nissan vehicles like the sylphy? don't want Tan Chong cause so expensive. anyone driving sylphy suffer same issue? Like one bro said, can go Autoaid in Toh Guan. They specialize in Nissan cars. Link to post Share on other sites More sharing options...
Jonpaul0104 2nd Gear October 2, 2013 Share October 2, 2013 i have 2 problems. 1. moving at low speeds below 30km/hr got some funny sound that sounds like whistling. read up online, seems like a common problem, either an undercarriage loose screw or tensioner problem. 2. when braking from high speeds >90km/hr, steering wheel will vibrate terribly, most probably a brake pad uneven or something. seems it is a common issue again. is there a workshop good with nissan vehicles like the sylphy? don't want Tan Chong cause so expensive. anyone driving sylphy suffer same issue? Visit Latio forum for the recommended workshop Latio Forum Link to post Share on other sites More sharing options...
Mcfguy 1st Gear October 2, 2013 Share October 2, 2013 Changed the rotors and it will be solved.. you can try AutoAid or AutoSaver.. What causes the rotor to give this type of problem? Is it hit curb or something similar? Link to post Share on other sites More sharing options...
Rustyz 5th Gear October 2, 2013 Share October 2, 2013 Changed the rotors and it will be solved.. you can try AutoAid or AutoSaver.. Some WS would just skim the rotors ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan Preventive Maintenance Programme
Nissan QashQai 2014 Part 2
Harddisk Diagnostic Test Software - Any good & free ones to recommend?
Any good private driving instructor to recommend?
Where to get Workshop Manual
