Hasram Clutched October 31, 2013 Share October 31, 2013 Today while i was driving my honda stream, i then stop while waiting the green light. as i was abt to move, i then realised thqt my engine had died n the batt n water red light was on. This was the second time happened aft a month ago. Luckily I am able to start it again. My amaron batt is abt 10mths old.My car aldy 5yrs old. May I seek your expert advise on wat had happened? thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Badieboy 1st Gear October 31, 2013 Share October 31, 2013 when engine stalls those lights will be on. if you can crank most probably it is not your battery. how long have you not cleaned your throttle body and idle air control valve? 1 Link to post Share on other sites More sharing options...
Jimmylim 4th Gear October 31, 2013 Share October 31, 2013 had that last week. went to workshop and do minor throttle cleaning and it's back to normal. simple task. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged October 31, 2013 Share October 31, 2013 (edited) alternator problem? i have the same issue, stop at traffic light and engine die off. cant even start again. I was on the way to agent to change alternator. In the end, call for flatbed. Edited October 31, 2013 by Mcf777 Link to post Share on other sites More sharing options...
Kb27 Supersonic October 31, 2013 Share October 31, 2013 (edited) Idling air passage or throttle body choke. Edited October 31, 2013 by Kb27 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 31, 2013 Share October 31, 2013 Check the alternator. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear October 31, 2013 Share October 31, 2013 how often do we need to clean throttle body? what are the signs of a dirty throtlle body? Link to post Share on other sites More sharing options...
Carnoob Supercharged October 31, 2013 Share October 31, 2013 I don' think it's the battery. My friend's stream was also having similar problem, the engine some times cut off when he was going uphill or downhill and it was very dangerous. He mentioned he changed a sensor or some sort and he had not have the problem since. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 31, 2013 Share October 31, 2013 Today while i was driving my honda stream, i then stop while waiting the green light. as i was abt to move, i then realised thqt my engine had died n the batt n water red light was on. This was the second time happened aft a month ago. Luckily I am able to start it again. My amaron batt is abt 10mths old.My car aldy 5yrs old. May I seek your expert advise on wat had happened? thanks How come u make first post only n u can straight away start a New Topic? Has the rules changed???? Link to post Share on other sites More sharing options...
Holdenutessv Turbocharged October 31, 2013 Share October 31, 2013 fuel pump? Link to post Share on other sites More sharing options...
Dalenico 1st Gear October 31, 2013 Share October 31, 2013 I don' think it's the battery. My friend's stream was also having similar problem, the engine some times cut off when he was going uphill or downhill and it was very dangerous. He mentioned he changed a sensor or some sort and he had not have the problem since. MAF, similar problem for stream Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear November 6, 2013 Share November 6, 2013 Don't be surprised....if the car's immobiliser is faulty....such symptom does happen. Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear November 9, 2013 Share November 9, 2013 the last time something like this happened to me was fuel pump. was pretty scary on the expressway. Link to post Share on other sites More sharing options...
Glyuen 3rd Gear November 9, 2013 Share November 9, 2013 Did u pump shell petrol recently at a particular kiosk? Link to post Share on other sites More sharing options...
HX26786 Neutral Newbie November 9, 2013 Share November 9, 2013 Maybe due to exhuast sensor.. recently i have similar experiences when i driving my 7yrs old Mazda went to the workshop and said that a lot of Mazda cars have the same problem. You can check it out with your familiar workshop. Link to post Share on other sites More sharing options...
Zxcvb Turbocharged November 9, 2013 Share November 9, 2013 Could also be oxygen sensor, had the same problem went back authorised dealer diagnosed and change that for me. Link to post Share on other sites More sharing options...
Gogg3r Clutched November 18, 2013 Share November 18, 2013 Bro, my Hyundai Getz also the same problem for the past 5 years. On off engine not happy, it will just die off. I also got CEL for some unknown thing sometimes, but 6 different workshops cannot find the problem also. Go to forums and ask around for advice, I changed so many things until I lost track. Now I got boxes of sensors which were replaced off my car and I still cannot isolate the issue. What I'm trying to say is, follow the advice given at your own risk and pocket size. My solution to your problem? Just drive slower and safer only. Cheers! Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 18, 2013 Share November 18, 2013 Bro, my Hyundai Getz also the same problem for the past 5 years. On off engine not happy, it will just die off. I also got CEL for some unknown thing sometimes, but 6 different workshops cannot find the problem also. Go to forums and ask around for advice, I changed so many things until I lost track. Now I got boxes of sensors which were replaced off my car and I still cannot isolate the issue. What I'm trying to say is, follow the advice given at your own risk and pocket size. My solution to your problem? Just drive slower and safer only. Cheers! Did u check yr electronic coil pack/distributor? ↡ Advertisement Link to post Share on other sites More sharing options...
Manmohan Singh, former Indian prime minister, dies at 92
Sudden death due to cardiac arrest
Ngee Ann Poly lecturer, 59, dies 1 day after brother, 56, dies of cancer, leaving their mum behind
SCHNELL Engine Oil 5W40
