Fuelsaver Supercharged January 26, 2015 Share January 26, 2015 How do you all learn? I've been trying to learn some stuff here and there to avoid workshop BS. My main weakness is the lack of mechanical ability :) Not confident of pulling apart parts to have a look myself... pulling parts apart has to be learned like all skills. for me, issue is with electrical / electronics - nvr done well in this field, not even during tertiary exams. ↡ Advertisement Link to post Share on other sites More sharing options...
Zmwang 1st Gear January 28, 2015 Share January 28, 2015 Don't need to waste money. There is no winter in Singapore. Just drive until it reaches your normal service mileage. Link to post Share on other sites More sharing options...
Anz1199 Neutral Newbie February 12, 2015 Share February 12, 2015 Does anyone know how much engine oil change is needed for a 2006 Nissan Cefiro 2.3. TIA. Link to post Share on other sites More sharing options...
Ahsiong Neutral Newbie February 13, 2015 Share February 13, 2015 I wud suggest a cheap mineral oil abt $15 plus $5 oil filter n labour $10-$15. Total sud b abt $35 only. Hi. Where can I buy cheap mineral oil and filter? And where can I bring my own oil and filter to change at a low labour cost? Thanks. Link to post Share on other sites More sharing options...
raga Neutral Newbie October 16, 2019 Share October 16, 2019 Service your car every 6 months, or like what you do, 10,000 km mileage. Earlier if you driving a older car as its better and safer that way. You can lookout for signs of breaking down, weird noises, unusual vibrations, lacking of proper combustion or power etc. https://www.motorist.sg/article/464/4-things-to-note-before-you-send-your-car-in-for-servicing Link to post Share on other sites More sharing options...
boonhat_91 6th Gear January 30, 2020 Share January 30, 2020 Just did 60K km servicing at tan chong.. they did the 'B' package. My question is, if I go outside workshop for future servicing, is the A/B/C packages a standardised thing across the board? e.g. if I do 80K km servicing outside, is the workscope the same as tan chong 'C' package? Link to post Share on other sites More sharing options...
Watwheels Supersonic January 30, 2020 Share January 30, 2020 10 minutes ago, boonhat_91 said: Just did 60K km servicing at tan chong.. they did the 'B' package. My question is, if I go outside workshop for future servicing, is the A/B/C packages a standardised thing across the board? e.g. if I do 80K km servicing outside, is the workscope the same as tan chong 'C' package? Nope. The outside workshop will only do what you ask of them. Aiya, the AD's packages add in their own set of services other than the usual engine oil replacement and engine oil filter. Eg. replace the aircon filter plus clean up the aircon ducts all that nonsense. It varies from AD to AD in terms of servicing"packages" Outside workshop will just do the essential oil change and filter change unless you have additional request. They might do random checks for leaks and check your brake pads. You go to outside workshop only when you are certain what to do at what mileage. Know when to replace parts like engine air intake filter, spark plugs and whatever. If you are clueless then leave it to the AD to service your car. Link to post Share on other sites More sharing options...
boonhat_91 6th Gear January 30, 2020 Share January 30, 2020 21 minutes ago, Watwheels said: Nope. The outside workshop will only do what you ask of them. Aiya, the AD's packages add in their own set of services other than the usual engine oil replacement and engine oil filter. Eg. replace the aircon filter plus clean up the aircon ducts all that nonsense. It varies from AD to AD in terms of servicing"packages" Outside workshop will just do the essential oil change and filter change unless you have additional request. They might do random checks for leaks and check your brake pads. You go to outside workshop only when you are certain what to do at what mileage. Know when to replace parts like engine air intake filter, spark plugs and whatever. If you are clueless then leave it to the AD to service your car. Thanks for the explanation! Link to post Share on other sites More sharing options...
jhmgk Neutral Newbie May 11, 2020 Share May 11, 2020 if I serviced my car in a workshop, can I switch back to the dealers? anyone has this experience? Link to post Share on other sites More sharing options...
oktaviatan Clutched May 11, 2020 Share May 11, 2020 I think you should do service when the service time comes because if you regular maintenance of the machine it doesn't break down quickly and long-term use is still good Link to post Share on other sites More sharing options...
Rickster 5th Gear May 11, 2020 Share May 11, 2020 58 minutes ago, jhmgk said: if I serviced my car in a workshop, can I switch back to the dealers? anyone has this experience? No problem, they'd only be too happy to take you back. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Battery warranty , must we service with distributor?
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Workshops with engine oil flushing machine
