Sabian Turbocharged December 21, 2014 Share December 21, 2014 Workshop shd value add. ie: provide services that cannot be easily replicated. ↡ Advertisement Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear December 21, 2014 Share December 21, 2014 i had some vibration problem... my WS said is EM... but I worry is something else... the vibration is very bad when the car is cold (morning start or restart the car when stationary >3hr)... the vibration slowly gone when the car being driven for 20~30min.... can anyone suggest where should i look at? car 7 YO and Lancer EX. Link to post Share on other sites More sharing options...
Marcostan 4th Gear December 21, 2014 Share December 21, 2014 i had some vibration problem... my WS said is EM... but I worry is something else... the vibration is very bad when the car is cold (morning start or restart the car when stationary >3hr)... the vibration slowly gone when the car being driven for 20~30min.... can anyone suggest where should i look at? car 7 YO and Lancer EX. My 7 years old LS460 had same as what you stated. After I change EM the car just like brand new. Why the vibration gone after warm up, because the heat of the engine turn the rubber softer a bit therefore it can absorb more vibration. Rubber harderness is one of the reason why need to change the EM. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged December 21, 2014 Share December 21, 2014 i had some vibration problem... my WS said is EM... but I worry is something else... the vibration is very bad when the car is cold (morning start or restart the car when stationary >3hr)... the vibration slowly gone when the car being driven for 20~30min.... can anyone suggest where should i look at? car 7 YO and Lancer EX. throttlebody dirty? Link to post Share on other sites More sharing options...
Dafansu Turbocharged December 22, 2014 Share December 22, 2014 throttlebody dirty? if vibration gone after some time might not be engine mount, could be throttle body like what chucky had mentioned Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear December 22, 2014 Share December 22, 2014 Hey guys, my Axio also have this Engine vibration going on for 1-2 secs when car is in STOP position. When moving no such problem. TB has been cleaned. So could be EM problem? Link to post Share on other sites More sharing options...
Marcostan 4th Gear December 22, 2014 Share December 22, 2014 (edited) Hey guys, my Axio also have this Engine vibration going on for 1-2 secs when car is in STOP position. When moving no such problem. TB has been cleaned. So could be EM problem? What is the mileage, usually EM need to change +/- 100,000 km. I dun think it is EM problem with your Axio. EM gone, the vibration is always there, it will not go away after 1-2 seconds. But it will gone if transmission is in N position, cause the RPM is higher so you will not notice the vibration. Edited December 22, 2014 by Marcostan Link to post Share on other sites More sharing options...
Dafansu Turbocharged December 22, 2014 Share December 22, 2014 Hey guys, my Axio also have this Engine vibration going on for 1-2 secs when car is in STOP position. When moving no such problem. TB has been cleaned. So could be EM problem? put your gear to neutral, off the aircon also. does your car vibrate, if yes likely to be engine mount. you can also check the engine mount visually, on the left of your axio holding on to your engine. check that there's still a gap between the mount and engine bracket Link to post Share on other sites More sharing options...
Jeffrey4783 1st Gear December 22, 2014 Share December 22, 2014 a stockist is one that sells spare parts for one or more brands. in your case, you may purchase engine mounting from a Kia stockist like Min Ghee Auto or Fong Tat Motor. Thanks bros. Have purchased from Chin Hon motor and Trading. Was like cheapest between 60-100 among. Now need to source labour. Minimize repair, as upcoming Sept coe die liao... Link to post Share on other sites More sharing options...
Ahbao999 1st Gear December 22, 2014 Share December 22, 2014 Morning start can feel the extreme vibration. most likely is engine mounting. After change, garranty feel the different like new car. Another advise is if wanna change engine mounting, one shot change all. Some car need 3 pieces and some 4piece. One shot change all can save your labour fees and purchase parts at a better price. Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 26, 2014 Share December 26, 2014 i saw a guy and a lady attempting to replace engine mountings for a Civic FD at the carpark in AMK street 21 yesterday. power 1 Link to post Share on other sites More sharing options...
TVT Supercharged December 26, 2014 Share December 26, 2014 i saw a guy and a lady attempting to replace engine mountings for a Civic FD at the carpark in AMK street 21 yesterday. power What they use to jack up or support the engine block, when they replacing the mounts? Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear December 26, 2014 Share December 26, 2014 What they use to jack up or support the engine block, when they replacing the mounts? they utilised some concrete slabs and jacks. should have taken a picture. Link to post Share on other sites More sharing options...
Kippei 3rd Gear December 26, 2014 Share December 26, 2014 I also planning to buy jack stand and jack ups to replace myself. haahhaa it quite a easy job once you have the service manual Link to post Share on other sites More sharing options...
Viper76 2nd Gear December 26, 2014 Share December 26, 2014 I also planning to buy jack stand and jack ups to replace myself. haahhaa it quite a easy job once you have the service manual Leave to motor workshop expert, can't imagine the whole engine dropped, how to call tow truck and how to take out the engine? Link to post Share on other sites More sharing options...
Kippei 3rd Gear December 27, 2014 Share December 27, 2014 Leave to motor workshop expert, can't imagine the whole engine dropped, how to call tow truck and how to take out the engine? the mount wont drop . 3 mount usually changed one by one not all together. so still got another 2 to hold it up. Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear December 28, 2014 Share December 28, 2014 Where to buy engine mount for nissan latio Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear December 28, 2014 Share December 28, 2014 thanks... i did both the EM change and the throttle body clean.. .now the vibrations are gone.... ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Any recommended tyre shop
Discussion for Honda N-Van (JJ2)
