Lotr 6th Gear August 24, 2014 Share August 24, 2014 Need some advice from the gurus of MCF. Thinking of getting EO from amazon, however, undecided whether to get 5w30 or 10w30. From my limited understanding, it seems that the number before 'w' is not relevant for local climate. In fact, more additive is added to the oil achieve 5 (from 10). Appreciate any comments/advice on this. Thank you. ↡ Advertisement Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear August 24, 2014 Share August 24, 2014 Need some advice from the gurus of MCF. Thinking of getting EO from amazon, however, undecided whether to get 5w30 or 10w30. From my limited understanding, it seems that the number before 'w' is not relevant for local climate. In fact, more additive is added to the oil achieve 5 (from 10). Appreciate any comments/advice on this. Thank you. looking at valvoline? get the cheaper one if both are of the same series. Not too much difference there. Link to post Share on other sites More sharing options...
Baal Supersonic August 24, 2014 Share August 24, 2014 Tink its 5 need more vi as the base oil thinner...so need more vi for 5....so that can reach 30. 10 base oil thicker so less vi needed to reach 30. Link to post Share on other sites More sharing options...
Quantum 5th Gear August 24, 2014 Share August 24, 2014 Need some advice from the gurus of MCF. Thinking of getting EO from amazon, however, undecided whether to get 5w30 or 10w30. From my limited understanding, it seems that the number before 'w' is not relevant for local climate. In fact, more additive is added to the oil achieve 5 (from 10). Appreciate any comments/advice on this. Thank you. 5w30 should give you better FC Link to post Share on other sites More sharing options...
Eyke Supercharged August 24, 2014 Share August 24, 2014 5w30 should give you better FC at normal operating temp, both are w30 so won't make much diff to FC. but 5w should be less viscous than 10w at start up temp (even though most we get is 20+) so may offer somewhat better protection... Link to post Share on other sites More sharing options...
Zyklon 5th Gear August 24, 2014 Share August 24, 2014 from: http://www.mycarforum.com/topic/2685094-time-to-buy-oil-again/?p=5254911 Yes, it is true that 5w-40 vs 10w-40, the 5w-40 is more watery at our ambient temperature. BUT this difference is so marginal that you can ignore it, unless your ambient is cold. At our type of climate, a 10w-30 is going to be even more watery than 0w-40 in the morning. On the other hand...if your morning is a cold 0 deg c...then 0w-40 will be more watery than 10w-30 in the morning... 0w-30, 5w-30, 10w-30 not going to be very different for our 30deg c days. 1 Link to post Share on other sites More sharing options...
Dafansu Turbocharged August 24, 2014 Share August 24, 2014 ignore the front digit, doesn't affect us as mentioned Link to post Share on other sites More sharing options...
Lotr 6th Gear August 24, 2014 Author Share August 24, 2014 Thanks for all comments. Think I'll just go ahead and order the 10w30. BTW it's the Pennzoil ultra platinum with free delivery 1 Link to post Share on other sites More sharing options...
Pms 3rd Gear August 24, 2014 Share August 24, 2014 (edited) I've read rave reviews about ultra platinum based on their used oil analysis. 0w30 is still too thick on cold start. If your car reaches operating temperature fast, 10w30 will be fine. Edited August 24, 2014 by Pms Link to post Share on other sites More sharing options...
Baal Supersonic August 24, 2014 Share August 24, 2014 5w30 should give you better FC between 5 & 10. Agree with u. Link to post Share on other sites More sharing options...
Wacko 1st Gear August 25, 2014 Share August 25, 2014 I've read rave reviews about ultra platinum based on their used oil analysis. 0w30 is still too thick on cold start. If your car reaches operating temperature fast, 10w30 will be fine. 0W-30 is thicker than 10W-30 at cold start temperature? Link to post Share on other sites More sharing options...
Quantum 5th Gear August 25, 2014 Share August 25, 2014 0W-30 is thicker than 10W-30 at cold start temperature? 10W thicker at cold start temperature Link to post Share on other sites More sharing options...
inlinesix Hypersonic August 25, 2014 Share August 25, 2014 0W-30 is thicker than 10W-30 at cold start temperature? What is Singapore cold start temperature? Link to post Share on other sites More sharing options...
Wacko 1st Gear August 25, 2014 Share August 25, 2014 What is Singapore cold start temperature? about 25C-30C 1 Link to post Share on other sites More sharing options...
Pms 3rd Gear August 25, 2014 Share August 25, 2014 (edited) http://www.bobistheoilguy.com/motor-oil-102/ There is 10 pages regarding engine oil and no one bother reading and keep asking the same questions over and over again? Edited August 25, 2014 by Pms ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Low Engine Oil Warning
Win FREE Servicing & Air-con Treatments. Exclusive for Sgcarmart & Mycarforum users! 40 Lucky Winners!
The ownself service car hobbyist! Pls come in Share your lobangs/parts hoot
Hybrid cars 0w8 engine oil
WIN attractive prizes worth $4,440! Submit reviews on any car tyres, lubricant or accessories now.
