Kklee 6th Gear March 24, 2018 Author Share March 24, 2018 With all this info I start to think: - my regular station is 1-2 km from office which I pump on way home in evening - non regular station is Just down the road from home in morning - it is possible I under inflat at my regular station (higher amb temp n longer drive ) Anyway I just use butt sensor to feel the diff in ride quaLity n decide which is better choice Morning, depending on what time, the ambient temp will be lower. The tyres will follow the ambient temp temperature. Evening, depending on what time, the ambient will be higher than morning. The tyres will follow the combination of ambient and surface temperature. In your scenario, maybe that explains why when you pump at the non regular (nearer to your home) will indicate lower initial pressure. ↡ Advertisement Link to post Share on other sites More sharing options...
Kklee 6th Gear March 24, 2018 Author Share March 24, 2018 I guess best to try out tpms to monitor the tyre pressure for u. Been using it for a while, tells me hw the tyre pressure change during idle, normal, hot and cold temperature affects the reading. Am using orange p series internal tpms. So far so good. They are other internal and external tpms out there which also works the same. Just sharing that its good to hve but not necessary. You guys can search and read up on too low or much pressure affects wat. Cant rem also. I just pump to what specs written at side of my cardoor. It is the timing that the tyres are pumped. TPMS have tolerance. My TPMS gives the same reading when the tyre is pumped from 226 kPa to 235 kPa. Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear March 29, 2018 Share March 29, 2018 It is the timing that the tyres are pumped. TPMS have tolerance. My TPMS gives the same reading when the tyre is pumped from 226 kPa to 235 kPa. Is the specification stating +/-5kPa or even wider tolerance? if so, they delivered their stuff. I guess best to try out tpms to monitor the tyre pressure for u. Been using it for a while, tells me hw the tyre pressure change during idle, normal, hot and cold temperature affects the reading. Am using orange p series internal tpms. So far so good. They are other internal and external tpms out there which also works the same. Just sharing that its good to hve but not necessary. You guys can search and read up on too low or much pressure affects wat. Cant rem also. I just pump to what specs written at side of my cardoor. i never considered TPMS although I see the benefits of it especially when travelling on highway. Does each TPMS needs its own 'button' battery, and that the system warns of low battery soon enough before the reading becomes inaccurate due to low battery output voltage? Link to post Share on other sites More sharing options...
Kklee 6th Gear March 30, 2018 Author Share March 30, 2018 Is the specification stating +/-5kPa or even wider tolerance? if so, they delivered their stuff. i never considered TPMS although I see the benefits of it especially when travelling on highway. Does each TPMS needs its own 'button' battery, and that the system warns of low battery soon enough before the reading becomes inaccurate due to low battery output voltage? Should be within specification. So far, the main benefit for me is under pressure during first start of the day during early morning. I take reference from that and the remaining of the day, I should be slightly inflated. Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear May 10, 2018 Share May 10, 2018 Is it possible to adjust the tone n volume of the factory fitted horn? It sounds whimpy n like blocked nose. Else if go to autobac change any concern on warranty from BM? Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear May 10, 2018 Share May 10, 2018 Is it possible to adjust the tone n volume of the factory fitted horn? It sounds whimpy n like blocked nose. Else if go to autobac change any concern on warranty from BM? Factory horn is non adjustable. Consider aftermarket ones if you want louder sound. Autobacs prices are usually priced much higher. And yes, warranty may be affected Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear June 20, 2018 Share June 20, 2018 This morning noticed the car was jerky when Moving off slowly at car park n traffic lights. Just now noticed the Malfunction light is on. From manual thus is either ecu or transmission problem. Crap. I did only 25k km and drive mildly always. Anyone had this early failure ? Can I just drive to BM service center wo appt to get them check n work on the car ? Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear June 20, 2018 Share June 20, 2018 (edited) Which service centre has the equipment to check this sort of problem ? Pandan or ubi or leng kee? Edited June 20, 2018 by ConnorMcLeod Link to post Share on other sites More sharing options...
Kklee 6th Gear June 20, 2018 Author Share June 20, 2018 (edited) This morning noticed the car was jerky when Moving off slowly at car park n traffic lights. Just now noticed the Malfunction light is on. From manual thus is either ecu or transmission problem. Crap. I did only 25k km and drive mildly always. Anyone had this early failure ? Can I just drive to BM service center wo appt to get them check n work on the car ? If can feel the issue, best is to tow to the workshop. Their 24hrs road side assistance - 6631 1188 Which service centre has the equipment to check this sort of problem ? Pandan or ubi or leng kee? Eh.... don't bother, this one their job mah. Anyway you pay for it already when you buy the car. P.S. How many k km to the next servicing? 3k? Edited June 20, 2018 by Kklee Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear June 20, 2018 Share June 20, 2018 (edited) Was thinking just drive to the service centre tmr morning n hope it needs only a ecu reset. THis us one of the few weeks in the year i need the car n damn. Irritating. If can feel the issue, best is to tow to the workshop. Their 24hrs road side assistance - 6631 1188 Eh.... don't bother, this one their job mah. Anyway you pay for it already when you buy the car. P.S. How many k km to the next servicing? 3k? Next is the 2yr 40k km. Still 3 months away. I doubt bm provides courtesy car... Sigh. Sian. Bought new also like this. Edited June 20, 2018 by ConnorMcLeod Link to post Share on other sites More sharing options...
Kklee 6th Gear June 20, 2018 Author Share June 20, 2018 (edited) Was thinking just drive to the service centre tmr morning n hope it needs only a ecu reset. THis us one of the few weeks in the year i need the car n damn. Irritating. Next is the 2yr 40k km. Still 3 months away. I doubt bm provides courtesy car... Sigh. Sian. Bought new also like this. Adhoc servicing, just go early. If they need sometime, no harm to ask if they got courtesy car. I suggest you install some OBD scan tools. Very helpful to monitor the car parameters. Edited June 20, 2018 by Kklee Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear June 20, 2018 Share June 20, 2018 Adhoc servicing, just go early. If they need sometime, no harm to ask if they got courtesy car. I suggest you install some OBD scan tools. Very helpful to monitor the car parameters. I hope I don't need to read these code often Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear June 20, 2018 Share June 20, 2018 Adhoc servicing, just go early. If they need sometime, no harm to ask if they got courtesy car. I suggest you install some OBD scan tools. Very helpful to monitor the car parameters. You mean no harm or no point ? Ha ha Link to post Share on other sites More sharing options...
Kklee 6th Gear June 20, 2018 Author Share June 20, 2018 I hope I don't need to read these code often Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear June 20, 2018 Share June 20, 2018 You are already reading some of the parameters codes e.g. coolant. You just get the actual numbers e.g. 90 degrees celcius. Qoo10 ones can ? Actually I want the projected speedo display thingy. Link to post Share on other sites More sharing options...
Kklee 6th Gear June 20, 2018 Author Share June 20, 2018 Qoo10 ones can ? Actually I want the projected speedo display thingy. Qoo10 ones are which? If Android, you can try Torque. It can project HUD. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear July 4, 2018 Share July 4, 2018 Anyone here driving the latest facelift Altis with the GPS Headunit? Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear July 5, 2018 Share July 5, 2018 90988. First 50 units only. Altis standard ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota bZ4X (2026) Part 2
Toyota Land Cruiser Mini
2022 Toyota bZ4X
2022 Toyota bZ4X
Nissan QashQai 2014 Part 2
