ConnorMcLeod 2nd Gear July 11 Share July 11 On 7/10/2026 at 6:50 AM, ER-3682 said: Maybe can try 225/45-17....I don't can can fit 225/55-17,this size is even bigger than Camry using only 215/55-17. @ER-3682 you are right. I didn't mean wider tyre. I only wanted a "taller" tyre with the same width as current. On 7/10/2026 at 8:19 AM, ER-3682 said: Can consider 215/50-17 also. didn't know got such profile. Will take a look. On 7/10/2026 at 10:38 AM, inlinesix said: Ppl want thicker sidewall la @inlinesix yes. the motivation of my question is that, I suffered several times wheel bearing damages due to hitting rocks / whatever things on the road. Also the car park turn at my place is tight and many times to avoid scratching the rims, I would have to reverse a bit half way going into the turn, to recover space from front left wheel from kerb. Therefore I was thinking if a thicker sidewall can help in my case. alternatively is to change to 16in rim which probably is more effective just pay a little bit more for the rims (maybe can go for used ones to save a bit). But then no one would pay for my scratched 17" so I create junk for myself. ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 11 Share July 11 @ConnorMcLeod Comfirmed have 215/50-17,my Rover 75 used this size before. 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 15 Share July 15 @ConnorMcLeod ↡ Advertisement 1 Link to post Share on other sites More sharing options...
BZ4x 2026 part 2
BZ4x 2026 part 2
2022 Toyota bZ4X
2022 Toyota bZ4X
Toyota Land Cruiser Mini
Nissan QashQai 2014 Part 2
Is this Altis bodykits optional??
