db597 1st Gear July 28, 2015 Share July 28, 2015 Hi Bros! Need some advise on where to change shock absorbers for my W169 A Class. My car shock absorbers are squeaky when I go over humps. Car has done around 80,000km. I brought to C&C for regular servicing and they want to charge me $180 to check the shock absorbers (just to check and not do anything!). They also said my undercarriage could be in bad condition and the shock absorbers could cost up to $10K to replace - naturally I declined, sounds way too expensive. Any suggestions on where else I can go? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Keithchue 5th Gear July 28, 2015 Share July 28, 2015 Hi Bros! Need some advise on where to change shock absorbers for my W169 A Class. My car shock absorbers are squeaky when I go over humps. Car has done around 80,000km. I brought to C&C for regular servicing and they want to charge me $180 to check the shock absorbers (just to check and not do anything!). They also said my undercarriage could be in bad condition and the shock absorbers could cost up to $10K to replace - naturally I declined, sounds way too expensive. Any suggestions on where else I can go? Thanks in advance. maybe try stockist for the shocks and do it outside, replacing the shock should be a fairly simple job for established garages..(correct me if im wrong) or else, grab a set of coilovers.. Link to post Share on other sites More sharing options...
evidence 2nd Gear July 28, 2015 Share July 28, 2015 (edited) Hi Bros! Need some advise on where to change shock absorbers for my W169 A Class. My car shock absorbers are squeaky when I go over humps. Car has done around 80,000km. I brought to C&C for regular servicing and they want to charge me $180 to check the shock absorbers (just to check and not do anything!). They also said my undercarriage could be in bad condition and the shock absorbers could cost up to $10K to replace - naturally I declined, sounds way too expensive. Any suggestions on where else I can go? Thanks in advance. if 10k i change car liao...i bought my shocks fr a stockist in jln pemimpin..... i tell u the parts r cheap n labour reasonable if u do outside...... see see really want people to si Edited July 28, 2015 by EvidenceProtocol Link to post Share on other sites More sharing options...
db597 1st Gear July 28, 2015 Author Share July 28, 2015 Thanks for the replies. Given the kind of prices I was quoted, I will be sending it outside. Is Autobacs ok, or any particular shop specializing in Mercedes that you guys recommend? Link to post Share on other sites More sharing options...
Kspchew 2nd Gear July 28, 2015 Share July 28, 2015 Check out Chip Soon (behind SAFRA Tampanies) or Autospritze Link to post Share on other sites More sharing options...
eightheory Neutral Newbie April 13, 2016 Share April 13, 2016 Hi, I'm a newbie and I am facing the same issue. Guess its wear and tear. Mine is serving its last year before i decide whether to scrap or continue coe by dec2016. Was thinking of 2nd hand but have no idea where i should look it up at. Any recommendation on whether i should change (new or recon)? If yes, how should i go about doing this? ↡ Advertisement Link to post Share on other sites More sharing options...
Mercedes Owners Thread
2016 Mercedes E-class (W213)
[Official] 2021 Mercedes-Benz S-Class (W223)
W212 owners, please check-in
