KoreanLover 5th Gear September 29, 2015 Share September 29, 2015 Actually I do feel better driving with shell vpower nitro+ after i did my refueling with them last sunday ↡ Advertisement Link to post Share on other sites More sharing options...
Jayy25 6th Gear September 29, 2015 Share September 29, 2015 marketing folks need to eat also. don't break their rice bowl la. that my friend you do not need to worry because most of the customers and consumers purchased stuff based on what the marketing dept tell them so... their rice bowls are solid.... only certain group of folks tend to research and compare before getting the best value for a fraction of the dough. Link to post Share on other sites More sharing options...
Carnoob Supercharged September 29, 2015 Share September 29, 2015 Simple... pump Vpower to clean engine once a while and the rest of the time pump SPC 98 to save money, easy solution hahaa... 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic September 29, 2015 Share September 29, 2015 Simple... pump Vpower to clean engine once a while and the rest of the time pump SPC 98 to save money, easy solution hahaa... You really think V-Power can clean your engine.? Link to post Share on other sites More sharing options...
Wt_know Hypersonic September 29, 2015 Share September 29, 2015 (edited) msia siham chut pattern liao when is spore siham take action? Edited September 29, 2015 by Wt_know Link to post Share on other sites More sharing options...
Carnoob Supercharged September 30, 2015 Share September 30, 2015 You really think V-Power can clean your engine.? No but it is a cheaper option (mentally) than sending the car to do engine flush. Link to post Share on other sites More sharing options...
ER-3682 Supersonic September 30, 2015 Share September 30, 2015 No but it is a cheaper option (mentally) than sending the car to do engine flush. Flushing an engine is not the same,flushing is to remove the dirt,in the oil passage,which modern engine form very little if you use 100% Syn oil when the car is new,petrol usually helps the intake clean,now all petrol came with additives to combat it. 2 Link to post Share on other sites More sharing options...
Xanavi 4th Gear September 30, 2015 Share September 30, 2015 Flushing an engine is not the same,flushing is to remove the dirt,in the oil passage,which modern engine form very little if you use 100% Syn oil when the car is new,petrol usually helps the intake clean,now all petrol came with additives to combat it. Aiya, why u burst my bubbles. After i pump vpower, I always feel that my engine very clean and can deliver more power. The feel good factor makes me smile behind the wheels one leh. But yah, it is the truth I always denied. Link to post Share on other sites More sharing options...
flashbang Turbocharged September 30, 2015 Share September 30, 2015 Aiya, why u burst my bubbles. After i pump vpower, I always feel that my engine very clean and can deliver more power. The feel good factor makes me smile behind the wheels one leh. But yah, it is the truth I always denied. Bro, you happy can liao 1 Link to post Share on other sites More sharing options...
Maskedrider 4th Gear September 30, 2015 Share September 30, 2015 Pump V power fuel will not clean engine .... Because V power didn't put in small people to clean your engine like what caltex did 4 Link to post Share on other sites More sharing options...
Herz22 1st Gear September 30, 2015 Share September 30, 2015 There are only 3 fuel suppliers in Singapore. Shell, Esso and SPC. SPC has joint venture with Chevron aka Caltex. I personally changed from SPC to Shell not because of butt feel but Shell gives better mileage on my car. I used to pump every 8 days but with Shell, I pump every 10 days with extra 50km. Which I have been consistently monitoring. Link to post Share on other sites More sharing options...
Solar Turbocharged September 30, 2015 Share September 30, 2015 i usually use spc (ron98) with posb everyday card, best for discounts. once a while, like 1/month, switch to vpower to feel the shiokness. Want the shiokness, try techron concentrate. half bottle for each full tank Link to post Share on other sites More sharing options...
shuttlecock 1st Gear September 30, 2015 Share September 30, 2015 After so many pages, it is down to: 1. Pricing. 2. Each preference of brand. Link to post Share on other sites More sharing options...
Solar Turbocharged September 30, 2015 Share September 30, 2015 Ah lian..................I very like like..............pump............petrol lah............dont think salah............. Tiko Peh can try caltex lol If I don't recall wrong the one along upper thomson got prc ah lian at the counter.. But if u sway to see auntie dun blame me.. She might not be on shift ;-) 2 Link to post Share on other sites More sharing options...
Carnoob Supercharged September 30, 2015 Share September 30, 2015 Flushing an engine is not the same,flushing is to remove the dirt,in the oil passage,which modern engine form very little if you use 100% Syn oil when the car is new,petrol usually helps the intake clean,now all petrol came with additives to combat it. Sure, thank you for the technical information. Link to post Share on other sites More sharing options...
Swifter78 2nd Gear October 1, 2015 Share October 1, 2015 Caltex also got 'little men' inside their petrol to clean the engine. Hehe...power of marketing. Link to post Share on other sites More sharing options...
ER-3682 Supersonic October 1, 2015 Share October 1, 2015 Sometime i find it strange,if a good petrol can remove carbon in the intake,can we says "If" a new car,from the 1st day,till it's last days using V-Power,means what.? No carbon ever form on the intake.?As we knew,anything burnt,sure leave some carbon behind,right.? Link to post Share on other sites More sharing options...
azaouogh 2nd Gear October 1, 2015 Share October 1, 2015 Want the shiokness, try techron concentrate. half bottle for each full tank Watch this ↡ Advertisement Link to post Share on other sites More sharing options...
RM1.99 RON95 starts on Sept 30 for all Malaysians.
Ron95 petrol, NGV off limits to foreign registered vehicles
Servicing car at Shell station
Be one of 10 lucky winners to win a $10 petrol voucher!
Shell x UOB Umbrella Redemption
