Pinang Neutral Newbie November 8, 2017 Share November 8, 2017 My old Lafesta having the same problem. Bypass it is the best solution. No point to spend $380 hi Philippe, how to bypass it? ↡ Advertisement Link to post Share on other sites More sharing options...
aimotorholdings Neutral Newbie November 8, 2017 Share November 8, 2017 A little surprised that car horns can break down. I mean, my Sylphy is coming to 9 years old only. I was told by the workshop that it is a common problem to Nissan cars. It's not the horn but the contact on the steering wheel that's worn. Appreciate fellow motorists in this forum can advise where to find distributors who supply the "pad" (to be mounted on steering wheel) for the horn. Perhaps, what is a reasonable price to replace the horn? Thanks! Also, looking for manual air horn to save cost. Hahaha! Looking for the reliable workshop? We are doing reliable, excellent and hassle free services. Your Trusted One Stop Workshop located @160, Sin Ming Drive, Sin Ming AutoCity #05-12 Singapore 575722 We are doing - Engine & Gearbox Specialist - Spray Painting - Car Servicing & Repair - Free Towing Service - Motor Insurance & Accident Claims - Parts And Accessories Call us: 87509310 Link to post Share on other sites More sharing options...
Philippe Neutral Newbie November 8, 2017 Share November 8, 2017 Run one wire from batt positive (fuse box) to a relay (get it from Sim Lim Tower). Connect the other end to horm (cut the original supply wire) If you are not sure the wire location, you might want to get it done by workshop. JB could be a cheaper choice. It is a simple job. Link to post Share on other sites More sharing options...
Kklim Supercharged November 9, 2017 Share November 9, 2017 My Sylphy's horn still ok but airbag light is flashing. Any way to fix this? Thanks. Link to post Share on other sites More sharing options...
Pinang Neutral Newbie November 10, 2017 Share November 10, 2017 Run one wire from batt positive (fuse box) to a relay (get it from Sim Lim Tower). Connect the other end to horm (cut the original supply wire) If you are not sure the wire location, you might want to get it done by workshop. JB could be a cheaper choice. It is a simple job. Thank you Philippe. This would be helpful! Link to post Share on other sites More sharing options...
Steve-u-obd January 19, 2018 Share January 19, 2018 maybe the electric circuit is damaged Link to post Share on other sites More sharing options...
SWong 1st Gear February 22, 2018 Share February 22, 2018 (edited) I confirm China version (taobao) is the same, cost me less than $100. Just that signal auto spring back might not work as well.To make sure that it's a clockspring problem, I turned my steering wheel all the way to the side and pressed the horn. It worked. But when the steering wheel is back in it's original position, it doesn't work. I asked a few workshops and they said the original Nissan clockspring is $200+, no way am I willing to pay so much for a worn wire or switch part! So I sourced my own cheap clockspring online from AliExpress and went to a recommended workshop to change. Total cost is around $70, including parts and labour cost. (Do note as the above poster mentioned, as it is not an original product, the signal at times would not automatically spring back after you make a turn. But having saved at least $200, I can live with that.) Do pm me if anyone needs more info! Edited February 22, 2018 by SWong Link to post Share on other sites More sharing options...
QQDreamer 4th Gear February 22, 2018 Share February 22, 2018 sadly, sg workshop really mark up alot on the parts and labor. some wprkshop charge parts one price and labor charges separately. sg labor cost is getting higher and higher. car is there and labor job charges on different jobs are being charge separately. Link to post Share on other sites More sharing options...
regyhl Neutral Newbie October 25, 2018 Share October 25, 2018 Thank you mavwong for the clock spring pin out diagram posted at : https://www.mycarforum.com/topic/2700701-old-sylphy-car-horn-doesnt-work/?p=5829162 My Nissan Grand Livina uses the same clock spring as Sylphy. When the horn stopped working, I bought and installed a cheap compatible clock spring from China. It lasted about a year. The clock spring wires for the driver airbag failed. Fortunately, I kept the original clock spring and decided to repair it. I used a wire wrap tool to connect the horn pins to the adjacent working unused pins. Success, my horn works. Attached photos show the wire wrap connections. Link to post Share on other sites More sharing options...
Mavwong 2nd Gear October 25, 2018 Share October 25, 2018 Glad it work out for you guys. I almost repair everything in this car except the main engine lolz. But now it’s time to move on. Link to post Share on other sites More sharing options...
Kklim Supercharged January 22, 2020 Share January 22, 2020 On 5/22/2016 at 11:29 AM, Mavwong said: Those who experience same problem in luck now. Check out the pin out below. What you need to do is have the pin swap to another working pin. You got ur horn back. Most pin not use unless you have both audio control and cruise control install which most don't have. So you don't need to change the whole clock spring. Know where I can have this done? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
2018 Nissan Serena e-POWER
Nissan N7
Nissan N7
Nissan QashQai 2014 Part 2
