Pinkpan 1st Gear May 2, 2017 Share May 2, 2017 Looks like water temp higher than previous ride. Consistently at 92/93 degree while my old ride at 86/88 degree normal and will exceed 90 in a jam. I use centre aircon vent aiming to rear. Compressor look super small don't know how long it can last. so compressor can change bigger one? haha ↡ Advertisement Link to post Share on other sites More sharing options...
Pinkpan 1st Gear May 2, 2017 Share May 2, 2017 found a thread written by someone, not sure how accurate or true, but just for sharing Firstly, the noise itself:is a vibration, it travels thru any medium (absent in vacuum due to absence of medium). Noise could travel through air (noise), hit a solid object such as metal car body (vibration), pass through it, and keep traveling through air again inside the saloon (noise).Most of the traditional, old fashioned sound-proofing relies on simply dealing with the very last part of this process - it attempts to dampen the noise inside the car by trying to reflect / absorb sound waves coming off the vibrating car body.In recent decade there has been major improvement in soundproofing industry, beginning with the realization that to deal with noise - it's just as effective to deal with vibrations of the car body, in fact more so.Today, soundproofing of a car can obtain as much as 80% noise reduction.You are correct about the sources of the noise - engine, tires on the road, air rushing past (mostly over the side view mirrors), rain, and other airborne outside (mostly traffic) noise.Personally, i would not trust small brands - the quality of materials are... just not there, there are massive international brands that deliver the quality, even though may be more expensive than the 'local' brands (i personally just don't like melting rubber in the car)For example Standartplast (StP) offers a huge variety of materials that deal not only with sound absorption / reflection but a lot more of vibration damping.Different cars have different issues, some have built-in soundproofing. However none of the currently manufactured cars offer anything that deals with vibrations specifically.For example, if you are looking to deal with road noise specifically - you have to realize that road noise (from the tires on rough tarmac or gravel) travels into the saloon of the car primarily as vibration. To deal with that issue - you have to deal with vibrations in the wheel arches primarily. There are materials and methods for that specifically, there are 2 types of materials here - some simply dampen vibrations by adding mass, others increase rigidity, which in turn shifts vibrations into higher frequency where it's far easier and more effective to 'kill' them with traditional soundproofing methods.If you are looking to reduce noise from the rain, which we all know usually completely overrides music volume in the car - there is no point dealing with wheel arches - you have to address the roof of the car primarily, once again there are materials specifically for that purpose.Engine noise travels into the saloon, once again, primarily via vibrations. Car bonnet should have sound reflecting materials, the firewall needs vibration absorption layered with sound absorption.One of the things a lot of people do not realize as well - is that a lot of soundproofing materials out there also double up as a heat-absorption materials, which basically means your car is going to be cooler in the wonderful 40 degrees in a traffic jam in the middle of the day. Sure, doing full soundproofing may not be as cheap as 100 bucks, and will add weight to the car (unless of course you're planning on racing in Singapore), but the level of modern noise reduction (up to 80%) and simple increase in resulting comfort is worth i Link to post Share on other sites More sharing options...
999 3rd Gear May 2, 2017 Share May 2, 2017 so compressor can change bigger one? haha Can put a portable unit behind, so cold enough one. Link to post Share on other sites More sharing options...
Pinkpan 1st Gear May 2, 2017 Share May 2, 2017 Can put a portable unit behind, so cold enough one. put fan? hahaha Link to post Share on other sites More sharing options...
Slowpoke 3rd Gear May 2, 2017 Share May 2, 2017 I just realized the front grille may not look that easy to install by one self becoz of the bumper design. Not sure if it's clip on or screw one type. Maybe it's worthwhile to pay MI extra to install it. if the design of the front bumper is anywhere like the design of the Levorg\WRX then you have to remove the entire bumper to change the grill...... Link to post Share on other sites More sharing options...
Pinkpan 1st Gear May 2, 2017 Share May 2, 2017 If any bro hear from their SE that new shipment arrived update here ok? Think will be faster than my SE. Haha Link to post Share on other sites More sharing options...
999 3rd Gear May 2, 2017 Share May 2, 2017 Anybody know how to set aircon using voice command. Video at 6.14 showed having this feature. Link to post Share on other sites More sharing options...
999 3rd Gear May 2, 2017 Share May 2, 2017 Yeah...found out the voice commands for air con settings as well as radios etc. Link to post Share on other sites More sharing options...
Victor68 Turbocharged May 2, 2017 Share May 2, 2017 How come these 2 guys mumble and seem to be talking to themselves? Am I the only one feeling frustrated listening to them? haha Link to post Share on other sites More sharing options...
Enqvist Clutched May 2, 2017 Share May 2, 2017 (edited) If any bro hear from their SE that new shipment arrived update here ok? Think will be faster than my SE. Hahamy collection suppose to be last weekend, SE called to say will be delayed till next week!!! What e...! But he gave a favourable news, seems like MI 'bid' no. plate for me.. can't wait to collect!! Edited May 2, 2017 by Enqvist Link to post Share on other sites More sharing options...
999 3rd Gear May 2, 2017 Share May 2, 2017 my collection suppose to be last weekend, SE called to say will be delayed till next week!!! What e...! But he gave a favourable news, seems like MI 'bid' no. plate for me.. can't wait to collect!!SLN4444X Link to post Share on other sites More sharing options...
Enqvist Clutched May 2, 2017 Share May 2, 2017 SLN4444XSLN xi xi xi xi J. Huat Ahh!! Link to post Share on other sites More sharing options...
LT66 Neutral Newbie May 3, 2017 Share May 3, 2017 my collection suppose to be last weekend, SE called to say will be delayed till next week!!! What e...! But he gave a favourable news, seems like MI 'bid' no. plate for me.. can't wait to collect!!My car already registered but still no news when to collect. Very very angry Liao , Link to post Share on other sites More sharing options...
jg2000 4th Gear May 3, 2017 Share May 3, 2017 https://www.youtube.com/watch?v=lGqAYtRvblQ Link to post Share on other sites More sharing options...
Enqvist Clutched May 3, 2017 Share May 3, 2017 My car already registered but still no news when to collect. Very very angry Liao ,We're on the same boat. Already registered but still need such a long time to deliver to us. So many order on their hand meh? But so far I have been very patience. Hah.. Link to post Share on other sites More sharing options...
Imaginative_Zany Clutched May 3, 2017 Share May 3, 2017 My car already registered but still no news when to collect. Very very angry Liao ,Usually will be less den 4 days after registration. If u lucky the next day van collect. Link to post Share on other sites More sharing options...
LT66 Neutral Newbie May 3, 2017 Share May 3, 2017 We're on the same boat. Already registered but still need such a long time to deliver to us. So many order on their hand meh? But so far I have been very patience. Hah..I told them yesterday ,I have no patience to wait . Waiting game??? Already waited so Long ↡ Advertisement Link to post Share on other sites More sharing options...
2015 Forester 2.0
2015 Forester 2.0
MAZDA 6
MAZDA 6
Honda City 4th Gen
Honda City 4th Gen
2026 8th Generation Lexus ES
