Kklim Supercharged February 20, 2017 Share February 20, 2017 Got a 2009 Sylphy 1.5 (non-CVT). Been having intermittent erratic idling when stationary and engine hesitation when accelerating; CEL light didn't come on. Spark plugs and air filter are newish and I clean the MAF sensor with CRC cleaner regularly. Brought to workshop (ex-Tan Chong staff) for checking but no fault codes surfaced. Swapped MAF sensor, filter, PCV valve but couldn't pinpoint the problem. What else could it be? Clogged injectors, faulty crankcase positioning sensor? Thanks for any help. ↡ Advertisement Link to post Share on other sites More sharing options...
Adrianli Hypersonic February 20, 2017 Share February 20, 2017 Fuel system? Fuel pump, fuel filter and fuel injectors got check? Link to post Share on other sites More sharing options...
RadX Moderator February 20, 2017 Share February 20, 2017 fuel pump or filter Link to post Share on other sites More sharing options...
3pinplug 1st Gear February 20, 2017 Share February 20, 2017 Got a 2009 Sylphy 1.5 (non-CVT). Been having intermittent erratic idling when stationary and engine hesitation when accelerating; CEL light didn't come on. Spark plugs and air filter are newish and I clean the MAF sensor with CRC cleaner regularly. Brought to workshop (ex-Tan Chong staff) for checking but no fault codes surfaced. Swapped MAF sensor, filter, PCV valve but couldn't pinpoint the problem. What else could it be? Clogged injectors, faulty crankcase positioning sensor? Thanks for any help. also check ignition coils. Link to post Share on other sites More sharing options...
Uranium2k 1st Gear February 20, 2017 Share February 20, 2017 Potentially ignition coil. I experienced the same thing previously. Changed out all 4 and issue resolved. 1 Link to post Share on other sites More sharing options...
Kengheng450 2nd Gear February 20, 2017 Share February 20, 2017 O2 sensor lah o Link to post Share on other sites More sharing options...
Itsec 2nd Gear February 20, 2017 Share February 20, 2017 mine is ignition coil Link to post Share on other sites More sharing options...
Watwheels Supersonic February 20, 2017 Share February 20, 2017 (edited) By right what ppl mentioned here should trigger a fault code. Things related to fuel like fuel injector, fuel pump and fuel filter you should have some trouble starting up the engine (fuel starvation) but you didn't mention so all these can be ruled out. There should be intermittent stalling too. If ignition coil there should be symptoms like bad fuel consumption stalling, misfiring....should be quite obvious and confirm trigger error code. Same as fuel starvation. If no fuel or unable to ignite starting up is a glaring issue. But yours isn't the case. So comes down to vacuum leak. It will also give the same symptoms you are facing. But how come no fault code? Could be small leaks on the vacuum hoses or gasket (on the throttle body). Edited February 20, 2017 by Watwheels Link to post Share on other sites More sharing options...
Beng2 5th Gear February 20, 2017 Share February 20, 2017 throttle body problem? Link to post Share on other sites More sharing options...
Agalvilaku 2nd Gear February 20, 2017 Share February 20, 2017 By right what ppl mentioned here should trigger a fault code. Things related to fuel like fuel injector, fuel pump and fuel filter you should have some trouble starting up the engine (fuel starvation) but you didn't mention so all these can be ruled out. There should be intermittent stalling too. If ignition coil there should be symptoms like bad fuel consumption stalling, misfiring....should be quite obvious and confirm trigger error code. Same as fuel starvation. If no fuel or unable to ignite starting up is a glaring issue. But yours isn't the case. So comes down to vacuum leak. It will also give the same symptoms you are facing. But how come no fault code? Could be small leaks on the vacuum hoses or gasket (on the throttle body). Mine too had ignition coil issue but no error code when checked. Anyway, mine is Honda City, but, the symptom seems to be ignition coil to me. Link to post Share on other sites More sharing options...
Uranium2k 1st Gear February 20, 2017 Share February 20, 2017 Mine had no error code triggered too. Same symptoms and was eventually narrowed down to faulty ignition coil. Link to post Share on other sites More sharing options...
Kklim Supercharged February 21, 2017 Author Share February 21, 2017 (edited) Thanks, guys. Did throttle body cleaning and workshop checked for vacuum leaks (none found) but problem came back after a while. EGR and PCV valves also ok. Guess it's ignition coil problem. The stuttering happens open after a drive and when car is stationary. Is the part number 22448-JA00C ? Thinking of getting an OEM set. Edited February 21, 2017 by Kklim Link to post Share on other sites More sharing options...
Winning 1st Gear February 24, 2017 Share February 24, 2017 Previously mine was fuel pump caused ... better check ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan QashQai 2014 Part 2
Nissan N7
Nissan N7
Would You Buy a Nissan...
Nissan's Secret CHEAP Electric Car - Nissan Sakura
