Goldenvodka 2nd Gear January 20, 2020 Share January 20, 2020 (edited) Guys urgent question before the cny holidays. my vehicle idle speed has not been smooth since a couple of months ago. When engaged in reverse gear it’s vibrating badly. Today, vehicle starts normally however it stalls after a couple of seconds, rpm getting too low. Opened up the hood and disconnect the MAF sensor. It did not stall however check engine light is lited and the vehicle went into a limp mode. (Unable to engage over drive gear) Any ideas if this can conclude as a MAF sensor issue? Before I proceed with the repair cost of $330 ps, am on a road trip on the way back to SG. 1600km away 😞 Edited January 20, 2020 by Goldenvodka ↡ Advertisement Link to post Share on other sites More sharing options...
QQDreamer 4th Gear January 20, 2020 Share January 20, 2020 i guess you have no choice right? yes it is likely high chance the MAF sensor is fauilty. 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic January 20, 2020 Share January 20, 2020 Better go workshop and resolve now before they charge you CNY prices the next few days. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic January 20, 2020 Share January 20, 2020 It could simply be, your engine air intake is choked, throttle at idling is too small, not enough air gets in and the engine stalled. If you have change battery recently, an e-throttle car could have lost its memory and throttle position reset to default, but due to oil and grime in the throttle body, it blocks the air block at idle and engine stalled. If you have an engine with cable throttle, the throttle body just needs a cleaning. Link to post Share on other sites More sharing options...
Goldenvodka 2nd Gear January 20, 2020 Author Share January 20, 2020 8 hours ago, Kb27 said: It could simply be, your engine air intake is choked, throttle at idling is too small, not enough air gets in and the engine stalled. If you have change battery recently, an e-throttle car could have lost its memory and throttle position reset to default, but due to oil and grime in the throttle body, it blocks the air block at idle and engine stalled. If you have an engine with cable throttle, the throttle body just needs a cleaning. My battery is about 1 month old. have been travelling in very dusty environment for the past 400 500km thanks for the advice. Vehicle is a e throttle for sure. Link to post Share on other sites More sharing options...
mersaylee Supersonic January 21, 2020 Share January 21, 2020 Best to get live log reading with varying engine rpm or voltage reading with a multimeter before throwing money into unnecessary part/repair. Any shop can do it. I suspect TB or vacuum issue if the recent battery change was of the car specification. Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator January 21, 2020 Share January 21, 2020 I also suspect is TB or vacuum issues. Best is go and get it to fix. You save on repair and spend on petrol (I don't think your fc is good with the idling problem) also the same. Link to post Share on other sites More sharing options...
Rayleigh 6th Gear January 21, 2020 Share January 21, 2020 13 hours ago, Goldenvodka said: Guys urgent question before the cny holidays. my vehicle idle speed has not been smooth since a couple of months ago. When engaged in reverse gear it’s vibrating badly. Today, vehicle starts normally however it stalls after a couple of seconds, rpm getting too low. Opened up the hood and disconnect the MAF sensor. It did not stall however check engine light is lited and the vehicle went into a limp mode. (Unable to engage over drive gear) Any ideas if this can conclude as a MAF sensor issue? Before I proceed with the repair cost of $330 ps, am on a road trip on the way back to SG. 1600km away 😞 It could also be fuel pump problem. Yes better let workshop check. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear January 21, 2020 Share January 21, 2020 maybe for cheap start. can try to clean the MAF sensor first with contact cleaner such as using WD40 brand contact cleaner. But TS has no choice i guess he is in malaysia? Link to post Share on other sites More sharing options...
Goldenvodka 2nd Gear January 21, 2020 Author Share January 21, 2020 19 hours ago, StreamRSZ said: maybe for cheap start. can try to clean the MAF sensor first with contact cleaner such as using WD40 brand contact cleaner. But TS has no choice i guess he is in malaysia? I was in Phuket Thailand. Today just arrived back in Singapore. kudos to the Suzuki agent service center in Phuket. They reset the onboard computer of my vehicle to make the check light go away hence I am able to drive it back to Singapore. Surprising they are well conversed in English and very helpful when I approached them for assistance. I can’t be limping a car limited to 80KM/h back to Singapore. reseting it temporarily helps the car to drive normally: will get it check first thing tomorrow by my workshop. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear January 21, 2020 Share January 21, 2020 2 hours ago, Goldenvodka said: I was in Phuket Thailand. Today just arrived back in Singapore. kudos to the Suzuki agent service center in Phuket. They reset the onboard computer of my vehicle to make the check light go away hence I am able to drive it back to Singapore. Surprising they are well conversed in English and very helpful when I approached them for assistance. I can’t be limping a car limited to 80KM/h back to Singapore. reseting it temporarily helps the car to drive normally: will get it check first thing tomorrow by my workshop. glad that the suzuki agent over at thai help you to temporary solve the issue. What is most important is to drive safe. yes please get it checked. Link to post Share on other sites More sharing options...
Mkl22 Twincharged January 28, 2020 Share January 28, 2020 On 1/22/2020 at 4:25 AM, Goldenvodka said: I was in Phuket Thailand. Today just arrived back in Singapore. kudos to the Suzuki agent service center in Phuket. They reset the onboard computer of my vehicle to make the check light go away hence I am able to drive it back to Singapore. Surprising they are well conversed in English and very helpful when I approached them for assistance. I can’t be limping a car limited to 80KM/h back to Singapore. reseting it temporarily helps the car to drive normally: will get it check first thing tomorrow by my workshop. car fixed? confirmed MAF? Link to post Share on other sites More sharing options...
Goldenvodka 2nd Gear January 28, 2020 Author Share January 28, 2020 5 hours ago, Mkl22 said: car fixed? confirmed MAF? I Guess so. After replacing vehicle start the first time after every crank ↡ Advertisement Link to post Share on other sites More sharing options...
Swift Owners
Swift Owners
Any Swift 1.2 XG owner?
[Spyshots] 2023 Suzuki Jimny Long
Suzuki New Car in Japan (Landy)
Fuel Pump
Fuel Pump
Been using K&N drop-in air filter for 2 weeks
