Looking for Used Volvos Advice
OptiRed
4 minutes ago, OptiRed said:
Volvo now has 5 years warranty? I read earlier they only give 3 years.
Sorry its 3 years warranty and 5 years free servicing
can be nego if u want it enough
Older volvos is a hit and miss, some luck involved
My s60 never gave problems but my friend sold off his due to recurrent problems
unless you have lots of free time to look for parts and source around like some bros here, servicing would not be cheap
  • Praise 4
I see! How old is your s60 now? And which variant is it pls?
1 hour ago, car50 said:
Reasonable depre
Dont forget generally used car depre has been dropping due to lower coe
This is the s60 older model, if u buy and drive for next 6.5 years and car ok, then worth it
If you sell after a few years (e.g due to problems), and with an older model you will land up with deregistration price offer then and your depreciation wont be great
then might as well buy a brand new model and enjoy piece of mind with 5 years free servicing and warranty
Used cars still selling like $30k above scrap value, if buy already better  drive for a few more years, cos deprec is not straight line
On 2/21/2020 at 1:23 PM, Soya said:
I drove so many different SM courtesy cars home so many times that my neighbours thot I was either a big shot at SM or their salesman
That's not a good sign 🤐 😜
On 2/21/2020 at 10:23 AM, OptiRed said:
Hi there!
I am looking at used Volvos that are around 7-8yo as I saw that their depre quite ok. (About 9k to 10k)
I saw S60 T2, T4, T5 and S80 T4 (1.6L) and etc.
Will like to see your opinions which model is better to get in terms of maintenance and servicing for a used Vovlo?
And there are other things to take note of?
Thanks!
Volvos were well-known for safety but spare part pricing is expensive hence the attractive 2nd hand price relative to their original price. Make no mistake though, it reflects the poor fundamentals as a used car proposition. The cars you are looking at are probably traded-in at paper value and thus you should not expect to get anything substantial on top of paper value when you scrap or sell the car (whatever Volvo you buy) at the end of its 10 year lifespan.
On 2/21/2020 at 1:03 PM, Volvobrick said:
7.5yr old still go tor kor? At least double to triple the repair costs!
Yes avoid the Ford Dual Clutch transmission.
5 banger engine most robust, but all 9 year old already. Volvos should be reliable based on my own experience. Probably will keep mine beyond 10 year.
Source your own parts from the Sin Ming stockist or from overseas if you have time. Taobao/Aliexpress, eBay, Amazon etc. Most are very reasonable, sometime I bought so rediculously cheap too!
Went to most of the workshops that service bobo. All say this problem they cannot do. Must go back tok kor. Same like the TCU replacement. Need to go back for programming. Bo bian.
  • Praise 2
Walau.....these so-called bobo workshops onli know how to do oil change and grooming?
What exactly was the problem with the car that only AD can fix?
so far sent in twice back to tor kor. Once for replacement of TCU and once for this steering column locked.
Edited by Macluver
Was the steering column replaced or just reprogram with new immobilizer code?
I stand corrected on the new TCM - it requires reprogram to alert ECU there’s a new organ.
replaced plus reprogram. Same for TCM.
  • Shocked 1
bro get an S80 T5/T5 Drive E. depre 11k but u will feel much better driving it. it's basically a tank on steroids. don't bother with T4. underpowered and sluggish off the line.
Supersonic
The T badge on bobo used to signify performance models. It was simply T4 (4cyl S40), T5 (5cyl S60) and T6 (6 cyl S80).
The S40 T4 was a fast & furious TP pursuit car in Sg
Pity how the bobo marketeers hv degenerated the T4 badge to a lame badging exercise for underpowered models....
Used to mean 4, 5 and 6 cylinder engines with higher outputs. Now all 4 (or 3?) bangers with different turbos/tune.
Much like the Germans 2.0 also marketed as 350, or Audi with even higher numbers plucked from the air. It's rank inflation, everyone also called a director or CEO.....
In 2010 Volvo changed their engine branding nomenclature so that it is independent of engine size and number of cylinders. The letter "D" designates diesel and "T" petrol. Letters are followed by a number that dictate the level of power.
https://en.wikipedia.org/wiki/List_of_Volvo_engines
The association of the number after the T designation should no longer be associated with the number of cylinders for Volvo engine. The same can be said for BMW 318, 320, 325, 330 etc which the latter two numbers were used to designate the engine capacity.
It is the prerogative for the company to continue to use such designation. I do not see anything wrong with that.
S40 T4 fast and furious? More likely because they are traffic police cars that drivers give them the respect and/or obey the rules when waved to the road shoulder.
Underpowered is such a subjective word. T8 engine specs would be underpowered to a supercar owner, but for the mass consumers, that isn't the case.
Hi there!
Thanks!
Just an update, I did not get Volvo in the end as scared of maintenance issues.
What did get in the end?
I got a MB c180 in the end. 1.6L w204 FL.
  • Praise 3
