Hachi 3rd Gear March 19, 2020 Share March 19, 2020 Last week when I went to.jb, after one hour or so, my air con is no longer cool. My radiator fan is operating and went to my mech just now. He suggested adding an additional fan in front of the condenser unit. My condenser unit is fixed in front of radiator and the radiator fan is doing the cooling for both which doesn't cover the whole area of radiator. Any advise? Cost? Thank you. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 19, 2020 Share March 19, 2020 What car and how old is the condenser. you can try chemical clean the condenser like what they do for home aircon. when the car is moving again the aircon is cold? maybe the radiator fan high speed is not working. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic March 19, 2020 Share March 19, 2020 Go to L & Kim Car Air-Conditioning 3023A Ubi Rd 1, #01-62, Singapore 408717 Look for boss Ah Khim. IMO no need to add what fan wan lah. Dont waste time and money. Go to this shop they will help you get it fixed. 3 Link to post Share on other sites More sharing options...
Airwaver 4th Gear March 19, 2020 Share March 19, 2020 44 minutes ago, Hachi said: Last week when I went to.jb, after one hour or so, my air con is no longer cool. My radiator fan is operating and went to my mech just now. He suggested adding an additional fan in front of the condenser unit. My condenser unit is fixed in front of radiator and the radiator fan is doing the cooling for both which doesn't cover the whole area of radiator. Any advise? Cost? Thank you. Been there, done that. It's useless, doesn't help. Best is to bring to aircon shops to let them diagnose the problem. 1 1 Link to post Share on other sites More sharing options...
Hachi 3rd Gear March 19, 2020 Author Share March 19, 2020 Suzuki Swift, 12 years old car. Not issue when travelling on road even under sunny day, the air con still cold. My radiator fan working. Even under hot sun, the coolant temp is about 80c of course during jam I do not know as I used the radiator cap with temperature gauge. Link to post Share on other sites More sharing options...
Airwaver 4th Gear March 19, 2020 Share March 19, 2020 1 minute ago, Hachi said: Suzuki Swift, 12 years old car. Not issue when travelling on road even under sunny day, the air con still cold. My radiator fan working. Even under hot sun, the coolant temp is about 80c of course during jam I do not know as I used the radiator cap with temperature gauge. Your's is 2 fan or single fan with Hi/Lo speed? Link to post Share on other sites More sharing options...
Watwheels Supersonic March 19, 2020 Share March 19, 2020 LoL...Adding another condenser fan is not going to make your aircon colder. Link to post Share on other sites More sharing options...
Hachi 3rd Gear March 19, 2020 Author Share March 19, 2020 1 hour ago, Airwaver said: Your's is 2 fan or single fan with Hi/Lo speed? Should be single fan because the fan keep going on and off.. Link to post Share on other sites More sharing options...
Hachi 3rd Gear March 19, 2020 Author Share March 19, 2020 44 minutes ago, Watwheels said: LoL...Adding another condenser fan is not going to make your aircon colder. I am not saying it will be cooler but during jam when there is not much air flow... Other than the jam I encountered that day it is working fine. Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 19, 2020 Share March 19, 2020 (edited) 56 minutes ago, Hachi said: I am not saying it will be cooler but during jam when there is not much air flow... Other than the jam I encountered that day it is working fine. Is your aircon filter clean? Original evaporator coil? Could be icing due to lack of airflow or low on gas. like the rest suggested Bring to aircon workshop to check. L & Kim used a borescope to check my evaporator and confirm it was clean and no oil leaks detected. Edited March 19, 2020 by Mkl22 1 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear March 19, 2020 Share March 19, 2020 10 hours ago, Watwheels said: Go to L & Kim Car Air-Conditioning 3023A Ubi Rd 1, #01-62, Singapore 408717 Look for boss Ah Khim. IMO no need to add what fan wan lah. Dont waste time and money. Go to this shop they will help you get it fixed. Just to add, the additional fan is facing the environmental elements like dust la, rain la... Peugeot in many model like that design one. My friend 5008, drive 5 years change 3 times lor. Fan spoil and the car computer detect fan fault, won't start wor. Aircon condenser is facing outward hence get cold air first, then the radiator get it. 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 19, 2020 Share March 19, 2020 7 hours ago, Apple-Tree said: Just to add, the additional fan is facing the environmental elements like dust la, rain la... Peugeot in many model like that design one. My friend 5008, drive 5 years change 3 times lor. Fan spoil and the car computer detect fan fault, won't start wor. Aircon condenser is facing outward hence get cold air first, then the radiator get it. Nothing to do with fan in front or behind. Main reason why spoil is because one word “French”. 3 Link to post Share on other sites More sharing options...
Watwheels Supersonic March 20, 2020 Share March 20, 2020 19 hours ago, Hachi said: I am not saying it will be cooler but during jam when there is not much air flow... Other than the jam I encountered that day it is working fine. I think everyone will face the same issue in the same situation. You are surrounded by other vehicles giving off heat. By adding another fan it will only draw in more heat from surrounding vehicles. You can try popping your hood to let heat escape as heat air rises. I have tried it before and it does cool the aircon a little better. Upon passing the customs find a safe place to stop and close back the hood. Link to post Share on other sites More sharing options...
Hachi 3rd Gear March 20, 2020 Author Share March 20, 2020 10 hours ago, Mkl22 said: Nothing to do with fan in front or behind. Main reason why spoil is because one word “French”. Hhahahaah... Mine only one fan behind the radiator and condenser... 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic March 20, 2020 Share March 20, 2020 It might work. My ex diesel van originally has 3 fans. Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear March 22, 2020 Share March 22, 2020 Last time hor, doing warmer season days, I just released the bonnet. Wind ma, cool down engine laaa, compressor, GB laa.. Now release bonnet, warning bell ring ring ring .....lor Link to post Share on other sites More sharing options...
JJ2020 Neutral Newbie April 24, 2020 Share April 24, 2020 On 3/19/2020 at 5:49 AM, Hachi said: Last week when I went to.jb, after one hour or so, my air con is no longer cool. My radiator fan is operating and went to my mech just now. He suggested adding an additional fan in front of the condenser unit. My condenser unit is fixed in front of radiator and the radiator fan is doing the cooling for both which doesn't cover the whole area of radiator. Any advise? Cost? Thank you. you should check cavity between radiators and clean it if necessary Link to post Share on other sites More sharing options...
Cpt35 Neutral Newbie January 21, 2024 Share January 21, 2024 On 3/19/2020 at 6:49 AM, Hachi said: Last week when I went to.jb, after one hour or so, my air con is no longer cool. My radiator fan is operating and went to my mech just now. He suggested adding an additional fan in front of the condenser unit. My condenser unit is fixed in front of radiator and the radiator fan is doing the cooling for both which doesn't cover the whole area of radiator. Any advise? Cost? Thank you. Could the air conditioner have run out of gas? ↡ Advertisement Link to post Share on other sites More sharing options...
Car aircon blows cold and hot air at the same time!!
Tomika Auto Air Con
Tomika Auto Air Con
Burnt PCB Air Con
Burnt PCB Air Con
A/C repair in JB
A/C repair in JB
Aircon Circulation Auto Turn Off
Bad service from Perfection Airconditioning & Engineering
