inlinesix Hypersonic June 4, 2021 Share June 4, 2021 1 hour ago, DOBIEMKZ said: Which model of Michelin are you using now? Michelin PS4. ↡ Advertisement Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 4, 2021 Share June 4, 2021 1 hour ago, Mkl22 said: depends on if you go by manufacturer advise or the street advice. manufacturer claims that tires can easily last 10years. some street advice says 2years from Date of manufacture. https://www.michelin.com.sg/auto/tips-and-advice/advice-auto/when-should-i-change-my-car-tyres @inline6 will you follow michelin advice? since you biased towards michelin. 😁 michelin also claims that using till wear indicators for wet is ok, but other manufacturers says 3mm. https://www.automotiveworld.com/news-releases/michelin-changing-tyres-3mm-unnecessary-costly-harmful-environment/ I will not follow their advice. Even though my mileage is low, I will change after 3 years of use. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 4, 2021 Share June 4, 2021 I change tyres every 3.3 years because of COE. I also change batt every 2.5 years. 10 years split by 3 and 4. Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged June 4, 2021 Share June 4, 2021 27 minutes ago, inlinesix said: Michelin PS4. Does the PS4 means Pilot Sport 4 or Primacy Sport 4 ? Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 4, 2021 Share June 4, 2021 2 minutes ago, DOBIEMKZ said: Does the PS4 means Pilot Sport 4 or Primacy Sport 4 ? Pilot Sport 4. Primacy is just Primacy. No sport hor Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged June 4, 2021 Share June 4, 2021 35 minutes ago, inlinesix said: Pilot Sport 4. Primacy is just Primacy. No sport hor Oh okie. It's an SUV/CUV tyre. So your car is SUV/CUV? Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 4, 2021 Share June 4, 2021 41 minutes ago, DOBIEMKZ said: Oh okie. It's an SUV/CUV tyre. So your car is SUV/CUV? PS4 is performance tyre. I am driving Mini Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged June 4, 2021 Share June 4, 2021 1 hour ago, inlinesix said: PS4 is performance tyre. I am driving Mini Okie. :) Link to post Share on other sites More sharing options...
RachelKim 1st Gear June 7, 2021 Share June 7, 2021 Any recommendations for 18" rim and tyre combo? Considering to upgrade from my current 16" for Mazda 3. Would prefer good FC and rolling, budget maybe 1.5 to 2k? Link to post Share on other sites More sharing options...
Shibadog Turbocharged June 7, 2021 Share June 7, 2021 39 minutes ago, RachelKim said: Any recommendations for 18" rim and tyre combo? Considering to upgrade from my current 16" for Mazda 3. Would prefer good FC and rolling, budget maybe 1.5 to 2k? if u want good FC, forget abt 18". Stay with 16 or go 17 at the most. Get a forged rim for better FC (lighter weight) but a new set of rims alone will be more than $2k. Perhaps try to find a good condition used set of rims with the right specs (PCD, width and offset) for your car and then put on a new set of tyres. by "rolling", do u mean low rolling resistance or low noise (when rolling)? although both might be co-related. 2 Link to post Share on other sites More sharing options...
Volvobrick Supersonic June 7, 2021 Share June 7, 2021 Good points. If want good FC and rolling resistance (both Sama Sama in my view since not much difference in aerodynamics for tyres), forget about wide, heavy, sporty tyres. Stick to original size. And check out the comparisons and decide for yourself. I used the recommended tyres (comfort) and very happy with it. https://www.tyrereviews.com/Article/Top-14-Summer-Tyres-for-2021.htm 1 Link to post Share on other sites More sharing options...
RachelKim 1st Gear June 7, 2021 Share June 7, 2021 47 minutes ago, Shibadog said: if u want good FC, forget abt 18". Stay with 16 or go 17 at the most. Get a forged rim for better FC (lighter weight) but a new set of rims alone will be more than $2k. Perhaps try to find a good condition used set of rims with the right specs (PCD, width and offset) for your car and then put on a new set of tyres. by "rolling", do u mean low rolling resistance or low noise (when rolling)? although both might be co-related. Honestly i am mainly changing for looks, i saw some rims (used probably) on carousel for around 600 to 800, SSW, Rayer etc (not sure which brands are good), so i thought 1.5k would be an acceptable price. Maybe i should just ignore FC and everything else haha 18 minutes ago, Volvobrick said: Good points. If want good FC and rolling resistance (both Sama Sama in my view since not much difference in aerodynamics for tyres), forget about wide, heavy, sporty tyres. Stick to original size. And check out the comparisons and decide for yourself. I used the recommended tyres (comfort) and very happy with it. https://www.tyrereviews.com/Article/Top-14-Summer-Tyres-for-2021.htm Would check it out, probably op for comfort too, thanks One question regarding compatibility issues. If my current rims are ET 45, would an aftermarket ET 42 fit? As most rims i see comes at ET 42. Also for 18 inch rims, do they usually comes in width 8? Was thinking if width 7.5 helps more in FC, as it is the stock spec of the higher end model of my car. Link to post Share on other sites More sharing options...
Shibadog Turbocharged June 7, 2021 Share June 7, 2021 6 hours ago, RachelKim said: Honestly i am mainly changing for looks, i saw some rims (used probably) on carousel for around 600 to 800, SSW, Rayer etc (not sure which brands are good), so i thought 1.5k would be an acceptable price. Maybe i should just ignore FC and everything else haha Would check it out, probably op for comfort too, thanks One question regarding compatibility issues. If my current rims are ET 45, would an aftermarket ET 42 fit? As most rims i see comes at ET 42. Also for 18 inch rims, do they usually comes in width 8? Was thinking if width 7.5 helps more in FC, as it is the stock spec of the higher end model of my car. it's not just FC that is affected. Pick up speed (i.e. acceleration) will also be affected. changing from ET 45 to 42 usually is ok, assuming the rim width is the same. yes some 18s do come in 7.5 width too. 1 Link to post Share on other sites More sharing options...
D3badge 6th Gear June 8, 2021 Share June 8, 2021 (edited) On 6/4/2021 at 5:23 PM, DOBIEMKZ said: Oh okie. It's an SUV/CUV tyre. So your car is SUVs/CUV? there are PS4 sedan and PS4 SUV version. SUV will have PS4 SUV on tyre https://www.michelin.com.sg/auto/tyres/michelin-pilot-sport-4-suv (SUV) https://www.michelin.com.sg/auto/tyres/michelin-pilot-sport-4 (Sedan or sportcar) Edited June 8, 2021 by D3badge 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 8, 2021 Share June 8, 2021 7 hours ago, RachelKim said: Honestly i am mainly changing for looks, i saw some rims (used probably) on carousel for around 600 to 800, SSW, Rayer etc (not sure which brands are good), so i thought 1.5k would be an acceptable price. Maybe i should just ignore FC and everything else haha Would check it out, probably op for comfort too, thanks One question regarding compatibility issues. If my current rims are ET 45, would an aftermarket ET 42 fit? As most rims i see comes at ET 42. Also for 18 inch rims, do they usually comes in width 8? Was thinking if width 7.5 helps more in FC, as it is the stock spec of the higher end model of my car. What is current rim width and offset? What is prospective rim width and offset? Is current rim flush to body? If 18” rim + tyre heavier than 16”, FC confirm will be higher. Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged June 8, 2021 Share June 8, 2021 9 hours ago, D3badge said: there are PS4 sedan and PS4 SUV version. SUV will have PS4 SUV on tyre https://www.michelin.com.sg/auto/tyres/michelin-pilot-sport-4-suv (SUV) https://www.michelin.com.sg/auto/tyres/michelin-pilot-sport-4 (Sedan or sportcar) Thank You. :) Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged June 8, 2021 Share June 8, 2021 9 hours ago, inlinesix said: What is current rim width and offset? What is prospective rim width and offset? Is current rim flush to body? If 18” rim + tyre heavier than 16”, FC confirm will be higher. His car model has variants that uses 18" rim as stock, so maybe the fuel consumption will be close to the level of those 18" rim variants. Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged June 8, 2021 Share June 8, 2021 17 hours ago, RachelKim said: Honestly i am mainly changing for looks, i saw some rims (used probably) on carousel for around 600 to 800, SSW, Rayer etc (not sure which brands are good), so i thought 1.5k would be an acceptable price. Maybe i should just ignore FC and everything else haha Would check it out, probably op for comfort too, thanks One question regarding compatibility issues. If my current rims are ET 45, would an aftermarket ET 42 fit? As most rims i see comes at ET 42. Also for 18 inch rims, do they usually comes in width 8? Was thinking if width 7.5 helps more in FC, as it is the stock spec of the higher end model of my car. 8J rims can, but ET40, officially speaking. So if new rims of 8J has ET of 40 or less should be ok. ↡ Advertisement Link to post Share on other sites More sharing options...
Petlas Or Giti?
Petlas Or Giti?
Is this tyre good? Made in SG!! Giti tyres!
