StrikeX 1st Gear September 19, 2020 Share September 19, 2020 Worth to use Ruthenium spark plug? A set smelly 110. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 19, 2020 Share September 19, 2020 Only know copper, platinum, iridium. What's good about this new one? 1 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic September 19, 2020 Share September 19, 2020 13 minutes ago, StrikeX said: Worth to use Ruthenium spark plug? A set smelly 110. NPNT. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic September 19, 2020 Share September 19, 2020 the craze over ruthenium https://www.bobistheoilguy.com/forums/threads/ngk-ruthenium-spark-plugs.329037/ Link to post Share on other sites More sharing options...
Mkl22 Supersonic September 19, 2020 Share September 19, 2020 (edited) Waste money. Stock best. If a lousy spark plugs makes so much difference, then automotive engineers no need to spend so much effort to eek out power and all that. bottomline it is just another product to squeeze money from consumers. Edited September 19, 2020 by Mkl22 2 2 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear September 19, 2020 Share September 19, 2020 8 hours ago, Volvobrick said: Only know copper, platinum, iridium. What's good about this new one? Cu BEST sia ...... NGK, Denso ......4 for $16. 40kkm hor. 110 -16 = A Few Roast Duck sia !! Link to post Share on other sites More sharing options...
Kb27 Supersonic September 19, 2020 Share September 19, 2020 a spark is a spark. whether it's produced by a copper, iridium, platinum, ruthenium, etc. the engine doesn't know the difference and doesn't care as long as there's a spark at the right time and space for ignition. the push is for longevity vs cost between the different material. i heard people justify iridium on a flat engine like subaru, bcuz it's harder to change a plug there or the labour cost is higher. for most people, they don't care, copper is cheap and good, it works fine. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 19, 2020 Share September 19, 2020 2 hours ago, Apple-Tree said: Cu BEST sia ...... NGK, Denso ......4 for $16. 40kkm hor. 110 -16 = A Few Roast Duck sia !! Iridium lasts almost forever. Probably never have to change. I replaced mine last year with iridium plugs. Old one (probably original set) still good at 80k km. Won't be changing for the next 9 years or till car is sold. 3 Link to post Share on other sites More sharing options...
Kb27 Supersonic September 19, 2020 Share September 19, 2020 i used to spend a lot of time, energy and money on "enhanced" performance stuff, like iridium, platinum plug, redline water wetter, the best synthetic oil, etc. Until i got a beat up VW van. It is when you're dealing with high engine temp, coolant leaking, that makes you realize, you don't need the top of the performance stuff. You don't need water wetter, you don't need high pressure radiator cap, you just need a working thermostat. None of those so-called performance stuff will help the car, when you have a real problem that need to be fixed. 2 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic September 19, 2020 Share September 19, 2020 What's water wetter? Link to post Share on other sites More sharing options...
inlinesix Hypersonic September 19, 2020 Share September 19, 2020 30 minutes ago, Volvobrick said: What's water wetter? https://www.redlineoil.com/waterwetter Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 19, 2020 Share September 19, 2020 31 minutes ago, Volvobrick said: What's water wetter? Redline water wetter Amazon review https://www.amazon.com/gp/customer-reviews/R4QHC7TB6O40V/ref=cm_cr_arp_d_viewpnt?ie=UTF8&ASIN=B000CPI5ZK#R4QHC7TB6O40V 5.0 out of 5 stars This stuff is MAGIC. Reviewed in the United States on January 3, 2019 Size: 12 Ounce BottleVerified Purchase I love this Water Wetter stuff. I use it on my Turbo Miata to help with cooling, because everyone knows how hot a Miata engine bay gets.. now imagine with a turbo! It's not lying, I used the correct amount of Redline as per instruction and my coolant temperature across the board dropped by around 20 degrees F. Using mostly coolant concentrate and some water, my car would overheat. Stupid. I then drained and did a 50/50 mix and still the same so I went and got this Water Wetter. Now I run about 15-20% coolant and the rest distilled water, with the proper Redline mixture. Temps went from 217ish to 194 steady. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 19, 2020 Share September 19, 2020 A car has a very good cooling system but motorcycles do not have good cooling systems so they need very good coolant. So I put a motor cycle coolant in my car and I use Maxima cool aid 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 19, 2020 Share September 19, 2020 Why do we use good coolant and not plain water? As someone here said when your radiator is leaking you have real problems. Radiators leak when its rusty and water helps radiators to rust. Good coolant contain rust inhibitors so your radiator won't rust in the first place. And then you wont get real problems. Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 19, 2020 Share September 19, 2020 Which spark plug is the best? If you can change it yourself then its copper. If you drive a boxer or a Latio then its iridium as its hard to access the plugs to change them. 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 19, 2020 Share September 19, 2020 Which oil is the best? The one that you change often according to specs If you drive and never change engine oil then its the longest life synthetic oil. Like Motul, M1, Castrol, Redline and Amsoil. Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear September 19, 2020 Share September 19, 2020 2 hours ago, Volvobrick said: Iridium lasts almost forever. Probably never have to change. I replaced mine last year with iridium plugs. Old one (probably original set) still good at 80k km. Won't be changing for the next 9 years or till car is sold. I ever use Iridium once. 60 odd kkm, the Misfire already become unbearable lor. At normal time, typical misfire is less than 10 times ba. Usually, 2~5 times is normal lor. When it reach around 30 times, I usually change lor. For that Iridium, the plug, no carbon, slightly yellowish and clean. And the gap size is out lor .....2mm compare to 1mm ?? Can't remember lor. Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear September 19, 2020 Share September 19, 2020 1 hour ago, Jamesc said: A car has a very good cooling system but motorcycles do not have good cooling systems so they need very good coolant. So I put a motor cycle coolant in my car and I use Maxima cool aid Car STOCK Coolant from Factory BEST. My car 3 years already, still green green. Why change if it isn't broken .......heeee ↡ Advertisement Link to post Share on other sites More sharing options...
The end of human race.
Lobang to change toilet sink faucet
What do you call the cloth covers used for SAF ID tags?
Selling one year old Piano
Testing of tags
Testing of tags
Devon conger eel close to record
Would you buy a Tag Grand Carrera when you already have 2 other Tags?
