ER-3682 Turbocharged May 14 Share May 14 23 minutes ago, Axela525 said: DTM look. Link to post Share on other sites
ER-3682 Turbocharged May 14 Share May 14 Owner should Drill some Holes in the Bonnet...helps Engine Cooling.🤣 4 Link to post Share on other sites
Inlinefour Twincharged May 14 Share May 14 might as well drill the whole car looks even more garang 1 Link to post Share on other sites
inlinesix Supersonic May 14 Share May 14 49 minutes ago, ER-3682 said: Owner should Drill some Holes in the Bonnet...helps Engine Cooling.🤣 Vios not very hot le 1 Link to post Share on other sites
Kopites Supersonic May 14 Share May 14 8 minutes ago, inlinesix said: Vios not very hot le Only if it is a turbo charge Vios. 2 Link to post Share on other sites
Yoongf 4th Gear May 14 Share May 14 Akan Datang... The new sakti black vios.. Work in progress Link to post Share on other sites
Mkl22 Twincharged May 14 Share May 14 Wanted some free coasters for his dining table. 😂 6 Link to post Share on other sites
ER-3682 Turbocharged May 14 Share May 14 1 hour ago, Phang said: cheap trick to look fierce I am selling Holesaws,if you need can find me. 2 Link to post Share on other sites
Phang 6th Gear May 14 Share May 14 1 minute ago, ER-3682 said: I am selling Holesaws,if you need can find me. you are the cutting expert 😁 Link to post Share on other sites
Phang 6th Gear May 14 Share May 14 I watch this from start to finish last month it is madness 2 1 1 Link to post Share on other sites
Comage 4th Gear May 14 Share May 14 2 hours ago, Axela525 said: Because the Toyota plastic bumper design is one hollow pocket there, so without holes there "will be drag" - so he go and drill holes thinking it will allow air through the bottom go the vehicle and "decrease drag". Link to post Share on other sites
D3badge 5th Gear May 14 Share May 14 13 hours ago, Axela525 said: Planning to murder his rear passenger, reduce the safety from bumper. 1 3 Link to post Share on other sites
Optramagnum 6th Gear May 15 Share May 15 Will it go faster? It's a Vios after all. Link to post Share on other sites
Mkl22 Twincharged May 15 Share May 15 1 hour ago, D3badge said: Planning to murder his rear passenger, reduce the safety from bumper. On jap cars bumpers are just for covering and decoration. Nothing beats the bumpers of the old w116. 1 Link to post Share on other sites
Etnt Supercharged May 15 Share May 15 Planning 1 exhaust pipe from each hole Link to post Share on other sites
Vid Hypersonic May 15 Share May 15 Just a sticker lah ↡ Advertisement 1 Link to post Share on other sites
