Genie47 1st Gear February 27, 2004 Share February 27, 2004 Actually any oil can do. In the BITOG forums, there is this guy that dared to use RP 5W30 in his WRX. The subsequent UOA showed that it had very wear signifying that the oil has done its job. Mind you, that is a very light oil that many people complain of having thinning issues. Many were befuddled and concluded that RP oil can be good too if used on structurally very strong engines. Then finally there was this unifying theory by the oil gurus who came out in unison saying any engine oil can be used as long as you change it at the regular intervals. Bad oil happens only when it is not changed regularly. ↡ Advertisement Link to post Share on other sites More sharing options...
Magfocus 5th Gear February 27, 2004 Share February 27, 2004 My thoughts exactly... Link to post Share on other sites More sharing options...
Maz75 Neutral Newbie February 27, 2004 Share February 27, 2004 Helloithere, Saw u inquiring about Shell Helix Ultra for your Mazda 323 Link to post Share on other sites More sharing options...
Genie47 1st Gear February 27, 2004 Share February 27, 2004 I'm in the cheap oil camp. Firstly was on HDDEO. Damn cheap. Then on RP 5W30. Change every 5k. Can afford it without the "I want to stretch it to make my money's worth" syndrome. Link to post Share on other sites More sharing options...
Zombie Neutral Newbie February 27, 2004 Share February 27, 2004 kah motor also use it..... so far i haven't been using other oil for my car, thus can't have a feel of the difference. Link to post Share on other sites More sharing options...
Maz75 Neutral Newbie February 27, 2004 Share February 27, 2004 This is just a personel opinion of mine, i used to use Shell Helix Ultra 5W 40 proposed by Mazda svc centre, its priced at $86.50.I am not saying the oil is no good but after i changed to mobil 5w 50 priced at $69 is even working better for my car since the last oil change. Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie February 27, 2004 Share February 27, 2004 Then finally there was this unifying theory by the oil gurus who came out in unison saying any engine oil can be used as long as you change it at the regular intervals. Bad oil happens only when it is not changed regularly. ------------------------------------- Good one. I am from this camp. I will take a relatively inexpensive synthetic that meets all the ACEA and API standards and change it out every 5,000km over an overpriced synthetic and change out every 10,000km. Link to post Share on other sites More sharing options...
Soya Supersonic February 27, 2004 Share February 27, 2004 ahem...onli ah peks can b considered model citizen. coz the younger ones are model tag heuer. Link to post Share on other sites More sharing options...
Yansen Neutral Newbie February 27, 2004 Share February 27, 2004 why is it that the unadvertised brands need to be changed at shorter intervals than those advertised brands? afterall, aren't we comparing across the same synthetic oils, just that there is advertising for one n none for the other? thanks for enlightening Link to post Share on other sites More sharing options...
Genie47 1st Gear February 27, 2004 Share February 27, 2004 ONe thing I know is that the advertised big oil want to keep themselves special and keep hyping on the extended drain interval to make the product unique. They make these claims so as to challenge the consumer to try or sue them when it fails. They can afford it anyway. As for small to medium oil blenders, they cannot afford all that. They will not give any extended drain nos like XXXXXXX miles but usually say that the oil has extended drain capability. So many of us who buy such cheap oil go for the safe 5k-7.5k km OCI to be safe. Link to post Share on other sites More sharing options...
Limws1 1st Gear February 27, 2004 Share February 27, 2004 Hi ppl!Juz want to ask if Shell Helix Ultra is good Anyone use it before? To know if a particular oil is good or not, you need to obtain the Material Safty Data Sheet (MSDS) for that oil. The data sheet will tell you what is the flash point of the oil. The higher the flash point the better. A high flash point indicates that the base oil is of good quality. Minimum, the flash point should be at least 400 degrees Fahrenheit. There are other specifications to look out for. The link below will give you some information on engine oil. http://www.vtr.org/maintain/oil-overview.html Link to post Share on other sites More sharing options...
Soya Supersonic February 27, 2004 Share February 27, 2004 like your conspiracy theory. but could it be maybe the big boys simply hv more $$ to do advanced R&D hence oil can last longer? Link to post Share on other sites More sharing options...
En0203 2nd Gear February 27, 2004 Share February 27, 2004 Pls ppl... only ppl like me with slow cars are model citizens no car can be slower than mine Link to post Share on other sites More sharing options...
Genie47 1st Gear February 27, 2004 Share February 27, 2004 Lube R&D isn't rocket science. Until now, sperm whale oil is used on the space shuttle due to its great capacity to keep its lube quality w/o being fried to a crisp. If the whole world ain't lookin' I arm meeself with thees arrpoon and go whalin' Ar Ar Ar! Link to post Share on other sites More sharing options...
Konspire Neutral Newbie February 27, 2004 Share February 27, 2004 i felt that Shell Ultra Helix isa bit thinner.......i dunno if thinner is good or not but ride wise, i felt SPC fully synth isa bit smoother.... Link to post Share on other sites More sharing options...
Soya Supersonic February 27, 2004 Share February 27, 2004 ahem....a sperm whale powered starlet?? Link to post Share on other sites More sharing options...
Genie47 1st Gear February 27, 2004 Share February 27, 2004 (edited) Cannot be powered lah. Sperm whale oil lubed. Anyway, got to smell the stuff when down in the whaling station in Albany. Much more pleasant compared to the syn oil we use. Not toxic also. Forgot to say, the official name is spermaceti. Edited February 27, 2004 by Genie47 Link to post Share on other sites More sharing options...
Cool_jazz Neutral Newbie February 27, 2004 Share February 27, 2004 Hi Yansen, it is NOT that non-advertised brands need to be changed at shorter intervals. BUT, as they are cheaper, you would not feel the pinch of changing them at shorter intervals. eg. Most big names who are into F1 sponsorship sell their oil for about S$85 +/- per 4L bottle. Equally good fully synthetic oil from companies who are not into F1 sell their 5L bottle for about S$55. Do the maths. You must understand that besides lubricating moving parts within the engine, the oil must trap all the dirt and dust from your air intake that the air filter missed. So the longer you keep the oil in your car, the less effective it is. Try listening to the engine after an oil change, at 5000km after oil change and at 8000km after oil change. Infact you should be able to feel the difference by the seat of your pants. Check out the attached link if you have not already read it. http://www.chris-longhurst.com/carbibles/i...eoil_bible.html ↡ Advertisement Link to post Share on other sites More sharing options...
Servicing car at Shell station
Shell x UOB Umbrella Redemption
Xiaomi 13 Ultra
Xiaomi 13 Ultra
Shell? Esso? Mobil? Caltex? SPC
Shell @ Yishun Ring Road is Closing Down
Join the Sgcarmart Stick It To Win It Contest now!
Shell x Monopoly 2021
