Soft99 Products Rock!
Leonknapp
Yup...Dupont has a change of heart but its not convincing.
I think it is the other stuff they put into the product that is doing
the work but bcos Teflon is so well know and it is a trademark..they
can get money whenever people use it...they want to stretch the
Does Fusso cover the swirl and fine lines in the paintwork?
how u know I 02 wks neber wash??? sweatdrop.gifdizzy.gif... I just did mine this afternoon...
I think u are right about the stretching the value of teflon thingy. quite pathetic actually cos they are such a big company. anyway with regards to ur fusso query no it does not cover swirls. Even if it does its very insignificant. Fusso is marketed as a pure sealant. if u looking for something that covers swirls u have to look at this product: kizu_da.gifhttp://www.soft99.co.jp/products/car/03wax/kizu_wax_w.html A new product that covers swirls and provides a sealant protection also. Or this one: kizu_r_da.gif This one is a "Specially formulated urethane resin fills and eliminate shallow scratches and swirls". Quite cool same as the one above but this one requires a cure time of 24hours and an additional coat of wax or sealant. Cheers!
Edited by Leonknapp
Hi Leonknapp,
Personally I used a cheap Soft99 cleaner wax ($9.70), and it is rubbish.So people, pls skip this item. After one wk , no more water beading.Wax gone under our tropical environment.
Hope u can keep us updated on the durability of the Fusso products u hv used.
If it is beading water, that's means the sealant/wax is there.
Appreciate yr after 3 wks, after 5 wks update (till 9 mths? 3 mths I am happy already).
hmmm... never used any of the waxes but if it's a cleaner wax, perhaps it's not meant for protection (hence only 1 week and no more beading)... wink.gif cleaner wax as far as i understand is only meant to remove previous layers of wax and to cover the swirl marks and other imperfections. generally you need to top it with other products for lasting protection. thumbsup.gif
maybe you should have added a layer of the the other Fusso (sealant/pure wax) on top of the cleaner wax for the protection part wink.gifnod.gif ..
Best stuff to remove birt sh*t is the quick detailer.
Just spray on the spot and wait for 30 secs, then just wipe off!!nod.gifthumbsup.gif
Cannot lah! Must save the quick detailer. See poo, add water + tissue. Wait or maybe don't wait. Wipe off then spray a little quick detailer. If straight away spray quick detailer, wasteful lah!
btw... in case people don't know... CAS Sin Ming actually sells Meguair's Quik Detailer at about $10+... cheapest I have found.. not sure about the other CAS though..
So is it not better to use QD straight away?
