Philipkee Twincharged May 1, 2013 Share May 1, 2013 In Jan this year, my low oil pressure indicator came on. I sent my car for servicing, everything was back to normal. Today, 5000 plus km later, the low oil pressure indicator came on again. I am sure there is nothing wrong with the oil pressure. What could be the cause? The indicator flickers on and off sometimes, not frequently ↡ Advertisement Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged May 1, 2013 Share May 1, 2013 In Jan this year, my low oil pressure indicator came on. I sent my car for servicing, everything was back to normal. Today, 5000 plus km later, the low oil pressure indicator came on again. I am sure there is nothing wrong with the oil pressure. What could be the cause? The indicator flickers on and off sometimes, not frequently check your oil level.... there should be leakage somewhere. If confirm no leakage, then your oil pressure sensor is faulty. Link to post Share on other sites More sharing options...
Yogi 1st Gear May 1, 2013 Share May 1, 2013 What car are you driving? Link to post Share on other sites More sharing options...
Philipkee Twincharged May 1, 2013 Author Share May 1, 2013 Avante Link to post Share on other sites More sharing options...
5936 1st Gear May 1, 2013 Share May 1, 2013 Dun jump into conclusion first.This one can be Big$$$ or small. If there is no external signs of leaks, have u experienced drop in engine power or noisy lifters? How is the EO colour? brownish or black?Low EO level is definitely one of the causes.Poor circulation can also contribute to this problem, and can be resolved with cleaning of oil pump intake screen. Link to post Share on other sites More sharing options...
Philipkee Twincharged May 4, 2013 Author Share May 4, 2013 went to spc speedy care. there is oil leak. costly repair Link to post Share on other sites More sharing options...
ChickenMob 6th Gear May 4, 2013 Share May 4, 2013 Oil leak at the gaskets? which part oil leak bro? Link to post Share on other sites More sharing options...
Philipkee Twincharged May 4, 2013 Author Share May 4, 2013 Oil leak at the gaskets? which part oil leak bro? they have to check.cos there are droplets of oil at various places. so they need to remove the mountings to see. will take half a day Link to post Share on other sites More sharing options...
ChickenMob 6th Gear May 4, 2013 Share May 4, 2013 Wow try to get a 2nd opinion, think its not gonna be cheap if they need to remove the mountings too. Hope its a minor leak at the gasket with lesser damage cost, Link to post Share on other sites More sharing options...
Philipkee Twincharged May 4, 2013 Author Share May 4, 2013 Wow try to get a 2nd opinion, think its not gonna be cheap if they need to remove the mountings too. Hope its a minor leak at the gasket with lesser damage cost, A triple check of dip stick shows it is dry. I tot there was oil cos there was oil in he dipstick but when engine was shut off, it became dry. Dun feel safe driving to another workshop Link to post Share on other sites More sharing options...
Kb27 Supersonic May 4, 2013 Share May 4, 2013 Maybe someone forgot to tighten the oil plug during your servicing. In the mean time, get some cheap carl-be and pour in. Link to post Share on other sites More sharing options...
ChickenMob 6th Gear May 4, 2013 Share May 4, 2013 Last time when my engine oil went missing is that i got a top block gasket leaking. Hope you get it solved soon, my friend Grandis engine oil top gasket leak result in the radiator dried up and a top overhaul. Hate it when our car gives problems. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 4, 2013 Share May 4, 2013 Without car problems, all the mechanics will be driving taxis Link to post Share on other sites More sharing options...
ChickenMob 6th Gear May 4, 2013 Share May 4, 2013 Hahahhahaaaa....money need to circulate to make the Earth rotate. Link to post Share on other sites More sharing options...
Joe8688 Neutral Newbie May 4, 2013 Share May 4, 2013 Avante Which year is your avante and mileage? I am also driving an avante. Link to post Share on other sites More sharing options...
Philipkee Twincharged May 4, 2013 Author Share May 4, 2013 Which year is your avante and mileage? I am also driving an avante. 2009 avante. Mileage 65000. Mine is OPC Link to post Share on other sites More sharing options...
Joe8688 Neutral Newbie May 4, 2013 Share May 4, 2013 2009 avante. Mileage 65000. Mine is OPC Mine is also 2009 but normal plate,mileage is on the high side.So far so good, only change alternator and some wear and tears. Link to post Share on other sites More sharing options...
Philipkee Twincharged May 4, 2013 Author Share May 4, 2013 The flywheel oil seal was broken so it was changed. Total damage $480 [bigcry] ↡ Advertisement Link to post Share on other sites More sharing options...
Low Engine Oil Warning
HSA recalls 3 brands of high blood pressure drugs
Tyres pressure for 225/45/R17
Speed warning device for Vans/Lorries
Clown offer money to students to follow him
Town Council Issued with Fire Hazard Abatement Notices (FHAN) by SCDF
How useful is higher pressure radiator cap?
Formula 1 Singapore GP Diary (Warning: Pics Intensive)
