Rrrobt Neutral Newbie April 12, 2006 Share April 12, 2006 wats the Correct tyre pressure for my harrier 17' inch ? thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie April 12, 2006 Share April 12, 2006 The answer lies on the side of your driver's door frame .....GO AND USE YOUR EYES OPEN BIG BIG !aahhahaha Link to post Share on other sites More sharing options...
Clubace Clutched April 12, 2006 Share April 12, 2006 tyre pressure do not change with size...and its all stated at the plate at the frame of the driver's door. Link to post Share on other sites More sharing options...
Burgerdog Neutral Newbie April 12, 2006 Share April 12, 2006 is there any case whereby the profile and the type of tyres are not suitable for the recommended tyre pressure stated at the side of the door? Or can we always assume the tag at the door is always rite? Even after we change rims and tyres? Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie April 12, 2006 Share April 12, 2006 how far can it deviate from 220-230 ....stick to that lor ... Link to post Share on other sites More sharing options...
Clubace Clutched April 12, 2006 Share April 12, 2006 I have consulted some of the forumers here when i changed my profile.....the general concensus is that there is no change in tyre pressure required. In after thoughts, i think this is correct as the weight of vehicle did not change. I guess u will have to look to those more knowledgeable on the tyres to answer you. Link to post Share on other sites More sharing options...
Genie47 1st Gear April 12, 2006 Share April 12, 2006 It does. Add 2psi above the stock tire for every inch increase in rim size. Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie April 12, 2006 Share April 12, 2006 yes and that becomes significant if you upgrade from a 13" to a 100" Link to post Share on other sites More sharing options...
Genie47 1st Gear April 12, 2006 Share April 12, 2006 Please lah, there is no 100" for road going cars. The most at 17" it is 36psi if the stock is 30psi for 13". Link to post Share on other sites More sharing options...
Burgerdog Neutral Newbie April 12, 2006 Share April 12, 2006 think what wolverine is trying to say is that it does not really deviate much from the stock tyre pressure unless you have a LARGE change in tyre size... Link to post Share on other sites More sharing options...
Contax 1st Gear April 12, 2006 Share April 12, 2006 wats the Correct tyre pressure for my harrier 17' inch ? thanks As a general thumb of rule , 230 is sufficient . Underinflat , you will have better road holding especially during wet days but your FC will suffer. Overinflat , you ride will be more bouncy and have that "floating feeling".You will lost traction easily plus your tyres will wear out faster and may explode easily. Link to post Share on other sites More sharing options...
Genie47 1st Gear April 12, 2006 Share April 12, 2006 There will be a problem with underinflation. Experienced it myself with an inch increase in size. Tire wear became uneven. Between 13 and 14 inches, nothing much happens but somehow, bigger rims will usually mean lower profile tires. There is some relationship in this, I forgot. Usually this happens for those 15" and above. Link to post Share on other sites More sharing options...
Soya Supersonic April 12, 2006 Share April 12, 2006 eh, he got 2ltr v-tek wor. his car always so fast can jiak everyone so maybe needs 100" rim to handle all that power. Link to post Share on other sites More sharing options...
Burgerdog Neutral Newbie April 12, 2006 Share April 12, 2006 Really? But how did you arrive at the figure of 2psi per inch increase in rim size? Is it proven or studied? Sorry for the questions, but I just wanna really make sure... Thanks Link to post Share on other sites More sharing options...
Genie47 1st Gear April 12, 2006 Share April 12, 2006 (edited) Its not really a rule of thumb but they are figures you can use to start off. As long as the tire sizes are different from stock. Confirm you cannot use back the stock tire pressures. 2psi difference is enough to make car a completely different creature. One way to find out is to pump the tire pressure you sort of need like lets say 32psi because you upgraded to 15" and the stock was 14" at 30psi. Take the car out for a spin around. I really do mean spin. Go round and round in a circle clockwise and then anticlockwise. Have a sort of feel on the handling. From there, reduce pressure or increase pressure. When it comes to tires, comfort is not the important part. Handling is. Want comfort, stick to the stock tire sizes. Another way to arrive at figures for front and back tire pressure is to take the vehicle weight in lbs/100 +2psi all round but add 2psi more for the heavy end. Edited April 12, 2006 by Genie47 Link to post Share on other sites More sharing options...
Burgerdog Neutral Newbie April 12, 2006 Share April 12, 2006 Thanks for the info... Will bear this in mind the next time I pump the tires... Thank again for the advice... Link to post Share on other sites More sharing options...
Kiatmobile 1st Gear April 12, 2006 Share April 12, 2006 wats the Correct tyre pressure for my harrier 17' inch ? thanks I saw a Harrier with 17" type and he pump pressure at 300psi... I was shock!!! Link to post Share on other sites More sharing options...
Soya Supersonic April 12, 2006 Share April 12, 2006 the extra 2 psi is recommended to bolster sidewall support as upsizing usually results in a lower profile aka less rubber. ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Old WW2 Relic disposals
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
