Thrilltoe Neutral Newbie May 6, 2006 Share May 6, 2006 Was driving at lane 1 (uoter right lane) about 100km/h fr city towards jurong direction near to clementi ave 6, my car suddenly lose power for a few second and the engine check light lighted up, after that I quicky change to lane 3, (luckily not much car during that hour, about 8pm). while was cruising without any power fr the engine for a few second the light go off, the car power back to normal. btw I am driving an accent 1.3m, yr 05. Any idea wat happened to my accent ? ↡ Advertisement Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie May 6, 2006 Share May 6, 2006 Can't really tell what the problem is off-hand. But is this happening very frequently? How's your fuel level? Are you running low on petrol? Link to post Share on other sites More sharing options...
Aimnfire 4th Gear May 6, 2006 Share May 6, 2006 my friend matrix got the same problem as yours when he when to agent to check they found out 1 of his spark plug not firing so they change 1 but my friend ask to change all after that the problem solve Link to post Share on other sites More sharing options...
Thrilltoe Neutral Newbie May 6, 2006 Author Share May 6, 2006 1'st time , fuel level is about 3/4. gahment allow tis level to travel out of s'pore Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 6, 2006 Share May 6, 2006 better check ur batt and the alternator.. mine happened around 3rd gear once...tot was batt...in the end was alternator Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 6, 2006 Share May 6, 2006 hmmm...mine was batt light on.. so engine light on cld be the spark plugs...which can be easily resolved...best go back to ur mech Link to post Share on other sites More sharing options...
Ferrariz Neutral Newbie May 7, 2006 Share May 7, 2006 Was driving at lane 1 (uoter right lane) about 100km/h fr city towards jurong direction near to clementi ave 6, my car suddenly lose power for a few second and the engine check light lighted up, after that I quicky change to lane 3, (luckily not much car during that hour, about 8pm). while was cruising without any power fr the engine for a few second the light go off, the car power back to normal. btw I am driving an accent 1.3m, yr 05. Any idea wat happened to my accent ? could be because your airflow sensor not working fine.... leading to misfiring on 1 or more of your spark plugs (because of leaner air/fuel mix) etc go to a workshop or get a OBD-II reader to see your CEL error msg. Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie May 7, 2006 Share May 7, 2006 Is your car still under warranty? If it is, bring back to Komoco and let they do an OBD diagnosis check to locate the error code. Link to post Share on other sites More sharing options...
Kiatmobile 1st Gear May 7, 2006 Share May 7, 2006 Sent back to KMC to check... Does all KMC's car has such problems? Link to post Share on other sites More sharing options...
Thrilltoe Neutral Newbie May 8, 2006 Author Share May 8, 2006 so far the light never lighted up since last sat. will monitor it and bring it to kmc if lighted again, I dun think kmc can find any fault once the light go off. Link to post Share on other sites More sharing options...
Amokie Neutral Newbie May 8, 2006 Share May 8, 2006 just send to kmc for checking Link to post Share on other sites More sharing options...
Sky8807 1st Gear May 10, 2006 Share May 10, 2006 Suspects ; fuel, fuel pump, fuel filter, fuel lines, fuel tank. Link to post Share on other sites More sharing options...
Carstyle Neutral Newbie May 13, 2006 Share May 13, 2006 Yes, they can. The ECU has an error log, which the technician can read with his computer analyser. Link to post Share on other sites More sharing options...
Mok_ Neutral Newbie May 19, 2006 Share May 19, 2006 It's better to go for an OBD-II Diagnostic Scan. The code should still be stored in the ECU with the freeze frame sensor readings. By looking at the code and freeze frame readings, a trained mechanic will be able to pin point the fault. Anyway, how much does Komoco charge for a diagnostic scan? You can contact saaber if you want to do some DIY OBD-II scanning. Link to post Share on other sites More sharing options...
Branong Neutral Newbie May 22, 2006 Share May 22, 2006 thats scary.. thank god i read this good luck to the diagnostics Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie June 21, 2007 Share June 21, 2007 (edited) Actually,what is the ok level for engine oil.My usual shop always top till the 1/2 mark for me,car easy to rev,but like maciam dehydrated leh,engine very rough.Then I always top till 3/4.Ah,engine now more quiet and if ramp the throttle,also not so noisy. I attach a pic to show my engine oil level.Appeal to all shifu out there,any precious advices. The flash arrow shows my oil level Edited June 21, 2007 by Followthelaw Link to post Share on other sites More sharing options...
Rickster 5th Gear June 21, 2007 Share June 21, 2007 my friend matrix got the same problem as yourswhen he when to agent to check they found out 1 of his spark plug not firing so they change 1 but my friend ask to change all after that the problem solve I also had a similar problem before. My car's accleration will sometimes be disrupted with slight loss of engine power for a split second before going back to normal. Sent it back to agent to check and found out that 1 of the spark plus is not firing properly. They replaced it promptly and no problem liao Link to post Share on other sites More sharing options...
Doggies Neutral Newbie June 21, 2007 Share June 21, 2007 if yours is a/t, try check your solenoid. i had the same problem. it can be dangerous especially with tailgates. ↡ Advertisement Link to post Share on other sites More sharing options...
KIA K3 Owners check-in!
No More Cheques In Singapore come 2027 Jan and EDP (electronic deferred payment)
