Wolverine Neutral Newbie May 31, 2006 Share May 31, 2006 it's $5.25 Jon ....GST! ↡ Advertisement Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie May 31, 2006 Share May 31, 2006 Another victim ....i feel for you ...it's easy to come up with a box and say it's gonna do magic ....it works you know why? Now CARS are getting CHEAPER right? More Ghin Nah Kids getting cars right? These gin nah no money right? These gin nah like to watch Initial D and 2F2F? These gin nah Ego small small? Give them a chance to UPGRADE performance at below $100 will they GIAN? Simple ..... if it's just a circuit and capacitors you can easily replicate ...nothing to it ...nothing propriety hohoho sorry Jon-i Jon Jon Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie May 31, 2006 Share May 31, 2006 Hey Jon use your real nick leh .... Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie May 31, 2006 Share May 31, 2006 Since we are at it ...anyone wants instant POWER!!? This simple, yet effective unit will help boost the power output of your cars engine, without sacrificing reliability or comfort. It consists of a small electronic resistance device that is inserted between your cars air sensor and the ECU. This is also know as a 'piggy back' device as it is external to the main processing unit (the ECU). You will feel the gain instantly, no fooling around or expensive tuning necessary. This unit will work with all cars vehicles equipped with electronic fuel injection. 99% of cars cars manufactured after 1988 are equipped with electronic fuel injection. Here is how it works : You have probably heard of performance eprom chips (Superchips, BBR Starchip etc). These chips consist of a stock computer program that has been altered to inject more fuel into the engine under acceleration. Timing curves are commonly also adjusted consequently. These chips can be found to be quite effective, but are also very expensive - costing normally from 600 up to 5000! they also require plenty of time, specialist tools and occassionally soldering to fit. Our 'piggy back' Power Mod on the other hand will alter the fuel and timing curves in a similar way to the eprom chip, but without even having to open the ECU. Our Power Mod fools your cars computer into thinking that your carss engine is sucking in air at a lower temperature, hence the timing is advanced. Timing advance helps produce more power by igniting the sparks sooner, providing more time for the fuel / air mixture to burn completely, increasing cylinder pressure, thus providing more power. PM ME NOW? If you belive in EZStab you will belive in this!!!! come come! We are taking orders !!! cost <$20 Link to post Share on other sites More sharing options...
Kklee 6th Gear May 31, 2006 Share May 31, 2006 U got pay $88? Link to post Share on other sites More sharing options...
Reliable Clutched May 31, 2006 Share May 31, 2006 you are doing DIY for it? but for certain car ECU, it will re-learn and over-ride just like some cars even if u mount SAFC it will still over-ride the settings after awhile. Link to post Share on other sites More sharing options...
Kanr 1st Gear May 31, 2006 Share May 31, 2006 hws sure are u,bro??? Link to post Share on other sites More sharing options...
Snookium 1st Gear May 31, 2006 Share May 31, 2006 "WOLF", You are rite, regarding the piggy back. My 1996 Honda Vti also running on Piggy back. However you really need a specialist to fine tune it. "Lean or Rich at different time curve or RPM". You send for before and after Dyno , you will definately feel it. As for the Ez stab, I know the inventor will curse and swear me if I expose his deed.. But no choice this is forum "freedom of speech" or "speech of freedom". I did not frame you just speak the TRUTH. If you think i am wrong just reply back. And the cost of one box The most obvious benefit of this(Ez stab) will be Easy engine start and nothing much i can imagine lesser alternator charge. You might as well get a higher capacity battery. Wat for go and buy Ez stab which is a MINI BATTERY with flashing light and serve not much purpose compare to a good high capacity battery. Link to post Share on other sites More sharing options...
Benboy78 Neutral Newbie May 31, 2006 Share May 31, 2006 (edited) Box ( which hard to buy in sg ) LED n Resistors( Red /Blue ) Red Cable ( Made in China ) Square Cap ?5 UF ?00 AC ( In AC ? Our batt DC mah )( Which can buy ARD ) No Screw ( Can let u open anytime u want ) No Heat-Gule ( If u got then its a bonus to u ) Where Got Circuit Broad inside And of cause FREE CABLE TIE Total Cost , i belive below $20 bucks Edited May 31, 2006 by Benboy78 Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 31, 2006 Share May 31, 2006 Putting a resistor to fool the voltage readings will advance the timing and there will be gains. But do you monitor the knock readings in the overall process? Otherwise, isn't this dangerous and might damage the engine? Link to post Share on other sites More sharing options...
Aimnfire 4th Gear June 1, 2006 Share June 1, 2006 bro you really lost my respect on you instead of promoting your cvs you tend to condemn your rivals tsk tsk tsk thats not the way to do business bro Link to post Share on other sites More sharing options...
Crv2004 Clutched June 1, 2006 Share June 1, 2006 Like that i think i will get one of r my new car also Link to post Share on other sites More sharing options...
Crv2004 Clutched June 1, 2006 Share June 1, 2006 Can go and consider already Link to post Share on other sites More sharing options...
Benboy78 Neutral Newbie June 1, 2006 Share June 1, 2006 (edited) Forum its open topic to talk mah bro Actally alot ppl know. But nobody want to talk to thats all. And i never say out the spec mah Some more got copyright. Who dare to copy his Rem DONT playplay with CopyRight Law As for your info. I quit CVS liao My parthner doing alone now. As parthnership problem lor. I doing ALone now ( even better ) Edited June 1, 2006 by Benboy78 Link to post Share on other sites More sharing options...
Aimnfire 4th Gear June 2, 2006 Share June 2, 2006 ok but at least for someone who knows electical/electronic circuit you dont have to step down on your rival. that is sheer underhand method. alot people knows but do they actually knows how the things works? i've seen the thing inside out and it is a simple thing that works but the million dollar question was, how come he realise it where no one bother to patent it and therefore making money? if other people thinks that it is worth less than $20 tell them to duplicate it and sell it out. no need to make so much noise. but of course in doing so you might be sue for copyright infridgement. the bottom line is he's making money on his discovery. nothing wrong with that. and the products does works Link to post Share on other sites More sharing options...
Kanr 1st Gear June 2, 2006 Share June 2, 2006 true,bro!!!thks for yr info,cheers!!! Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie June 2, 2006 Share June 2, 2006 Box ( which hard to buy in sg ) LED n Resistors( Red /Blue ) Red Cable ( Made in China ) Square Cap ?5 UF ?00 AC ( In AC ? Our batt DC mah )( Which can buy ARD ) No Screw ( Can let u open anytime u want ) No Heat-Gule ( If u got then its a bonus to u ) Where Got Circuit Broad inside And of cause FREE CABLE TIE Total Cost , i belive below $20 bucks For 1 YES ...think about MASS ordering .....with Lobang ...$5 -$8 Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie June 2, 2006 Share June 2, 2006 Discovery? Discovery channel i know ..... wa singaporean so gullible ah ...i am also starting my own ....i call it ummm... MCF-VS ......$10 with installation PM me if you want .... ↡ Advertisement Link to post Share on other sites More sharing options...
How to feedback on hospital service?
The ownself service car hobbyist! Pls come in Share your lobangs/parts hoot
Taobao Sure Can Buy List
National Service in Singapore
Bad service from Top93, ubi
