Vroomvroom 2nd Gear August 1, 2006 Share August 1, 2006 Hi, I had VS&Grounding installed in my ride recently, for a moment immediately after I get the installation done, the car response was faster and everything seems better.. but after awhile, with no further mod added, I experienced a obvious loss in power and extreme slugginess in my car gear change (Auto tranny). Had any bro experience something like this before? Any advices to share? Noobie here. Thanks ppl. ↡ Advertisement Link to post Share on other sites More sharing options...
Chogokin 1st Gear August 1, 2006 Share August 1, 2006 Hi, Care to share what is yr ride and VS brand you had installed? I also thought of installing but since u bring up this problem I have to do a consideration . Thanks Chogokin Link to post Share on other sites More sharing options...
Limws1 1st Gear August 1, 2006 Share August 1, 2006 Previously I installed grounding wires on my Hyundai Accent and experienced the same effects as you. Most likely, the ECU got reset during the installation so you feel your car perform better immediately after the installation. After a few days, your ECU reset itself to factory default setting and everything goes back to normal. Nothing much you can do. Maybe you want to uninstall all your mods and see if things remain the same. Link to post Share on other sites More sharing options...
Evildoer Neutral Newbie August 1, 2006 Share August 1, 2006 hey, i faced similiar prob too... a clown did grounding for me and my ride couldnt go above 100km/h...i remove grding and ride back to norm.... i suggest u remove the grounding pt at the batt and testdrive if the prob is still there...do the same for the VS but with grounding active...see which one is causing the prob... Link to post Share on other sites More sharing options...
Machspeed Neutral Newbie August 1, 2006 Share August 1, 2006 can try out what 'evildoer' suggested or it could simply be a case that you've gotten used to the way your car response now.. You will adapt to your car's new found power after awhile so you'll feel like the car is not as responsive as compared to the first time you drive it after the mod.. seems like u gotta mod more to satisfy the thirst for power man.. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 1, 2006 Share August 1, 2006 I have VS & grounding done on my ride but i do not experience such effects Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear August 1, 2006 Share August 1, 2006 check the wiring. grounding should be one from the batt to the box and the rest to the chassis, engine etc. there should be no other wired other than ground wires touching any of the grounding kit wires. Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie August 1, 2006 Share August 1, 2006 Hi, I had VS&Grounding installed in my ride recently, for a moment immediately after I get the installation done, the car response was faster and everything seems better.. but after awhile, with no further mod added, I experienced a obvious loss in power and extreme slugginess in my car gear change (Auto tranny). Had any bro experience something like this before? Any advices to share? Noobie here. Thanks ppl. So sumthin must have happened in between the time when the installation gave u improvement and the point when u feel it's sluggish .... see what happened then ....go smell the VS ...is the capacitor barbecued? Link to post Share on other sites More sharing options...
Dfx16 6th Gear August 1, 2006 Share August 1, 2006 (edited) Cant go above 100KM/H Is it possible? Sound serious Edited August 1, 2006 by Dfx16 Link to post Share on other sites More sharing options...
Chogokin 1st Gear August 1, 2006 Share August 1, 2006 Hi Mazda3, Wat VS are you using? Thanks Chogokin Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 1, 2006 Share August 1, 2006 Hi Bro I'm on Pivot VS (The blue one) as well as the transparent one for audio. Besides these, my ride is grounded using Pivot Earth Wire Link to post Share on other sites More sharing options...
Tann Clutched August 5, 2006 Share August 5, 2006 FYI Most of our car now running on ECU which is electronic control and is also sensitive to any gadget that you install. - some of the VS in the market are user friendly to our ECU that why you may find that intial state when you first install it was ok and after that the ide effect come, all you need to do was like some of them that says is to remove the +ve point of the Vs and test your car - Why after Install Grounding cable the car become sluggish, cost some of the cable are fitted to wrong point that causes it. If you have cable that connected to throttle body, spark plug coil try to remove them and run you car and see what happen (some other position may also cause it to sluggish too) Tann/theme8 Link to post Share on other sites More sharing options...
Landoff Neutral Newbie August 10, 2006 Share August 10, 2006 Same here. I just removed my old VS. I've installed my old VS 6 mths ago. For the first few days everything seems normal never felt any real improvement or deterioration. However after which my headlamps seems dimmer and my car seems alot more sluggish during acceleration. I thought I must have gotten too used to the car..... However, today I went to the workshop to have order a pair of fog lamps. Upon opening up my bonnet, the mechanic almost shake his head off his shoulders. He indicated that the cables were not connected properly and alot of short cuts were taken. The so-called "Korean" VS is actually an OEM. He pulls off a whole box of thrown VS and several of them look exactly like mine with different brand on it. Mine is "Super". After showing me his other customer's car, i decided to change my VS to the Japanese "Raijin" one and rewired all the electrical cables with Pivot Cables. The moment I start my engine, the first thing that greeted me was the lost feeling of my engine purring to life again. My ICE also pumps out music that were much more familar when I first gotten the car. I tested it alittle on the way home, the head lamps were much brighter and the car is back to its usual self and is more responsive than ever. My advice for VS is, do not go to any tom, dick and harry shop like I first did. Go to somewhere more trustworthy... Do not step away when they install it. Look at how they connect it up. It should be well run, and not those all over your engine cover like leftover noodles. Was so happy with the mechanic that I also bought a SUMMIT front tower strut bar from him. hehe... Link to post Share on other sites More sharing options...
Dennisk Clutched August 10, 2006 Share August 10, 2006 how come? Link to post Share on other sites More sharing options...
Dennisk Clutched August 15, 2006 Share August 15, 2006 how come? "If you have cable that connected to throttle body, spark plug coil try to remove them and run you car and see what happen (some other position may also cause it to sluggish too) " Link to post Share on other sites More sharing options...
Blackmafia Neutral Newbie August 15, 2006 Share August 15, 2006 So where is this good mechanic you went to? How much did he charge? Link to post Share on other sites More sharing options...
Landoff Neutral Newbie August 17, 2006 Share August 17, 2006 Chuan Lee Hin They are located at No.50 Bukit Batok St23 Midview Building #02-01 Look for Ah Meng. Tel 68968986 The new Pivot Raijin VS and Pivot cables with installation cost me $140. Lately just installed my fog lamps, spoiler and front strut tower bar there also. Link to post Share on other sites More sharing options...
Orixy 2nd Gear August 21, 2006 Share August 21, 2006 Bro, can share share which are the points you gounded? ↡ Advertisement Link to post Share on other sites More sharing options...
Tool to change Spark Plug
Wheel Spacer Installation DIY
Change Disc Rotors
Change Disc Rotors
X for twitter change request
BreadTalk Will Delist Company On 5 Jun After Posting $5.8 Million Loss In 2019
