Kelpie 2nd Gear January 15, 2007 Share January 15, 2007 Hi there, 1. Going for 50K servicing tomorrow, how much brake fluid do I need for a 1.6L car? 2. Last minute, no choice, may just go petrol station to buy the fluid. I guess it should still be cheaper than distributor one right? 3. Should I use DOT 4 only. Any advice bros, Thank you very much. Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Weihui Clutched January 15, 2007 Share January 15, 2007 1) 1 bottle of 1L should be enough? I changed my steel braided brake line and bled with Mintex DOT5.1, required only 1L. 2) Depending on what brand you get I guess. 3) DOT4 and DOT5.1 should both be fine. Anyway, brake fluid is recommended to changed every 20k. Correct me if I am wrong Link to post Share on other sites More sharing options...
Kelpie 2nd Gear January 15, 2007 Author Share January 15, 2007 1. Thank you. 2. Tomorrow morning 8am is the servicing appointment. So I can only go petrol shop to get the brake fluid. 3. What is the best DOT 4 that I can get from these petrol stations? I'm looking at Valvoline, which is 261C/172C. Any better one than this at petrol stations? Regards, Link to post Share on other sites More sharing options...
Weihui Clutched January 16, 2007 Share January 16, 2007 Paiseh, by the time I saw your reply, I guess you are already in the workshop. I am really not sure what brake fluid they offer in petrol station. Actually, if you are changing in the workshop and not the typical Borneo, Kah Motor kind of service center, the brake fluid should not be more expensive than what petrol station can offer. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 16, 2007 Share January 16, 2007 Go to AV spare part shops to buy Ate Super DOT 4 lah. It is really overspec'd to the point it is closer to DOT 5.1 than DOT 4. Link to post Share on other sites More sharing options...
Clubace Clutched January 16, 2007 Share January 16, 2007 Which part of AV? The end nearer to AIA building or the ikea? Link to post Share on other sites More sharing options...
Genie47 1st Gear January 16, 2007 Share January 16, 2007 The other side next to the tire shop. Yes, you can consider it to be on that small road leading out to Bt Merah Rd. Link to post Share on other sites More sharing options...
Clubace Clutched January 16, 2007 Share January 16, 2007 Okie...i do some hunting later on...i need to get the brake fluid change too. Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 16, 2007 Share January 16, 2007 Hi Genie, Is it OK to mix brake fluids? Last time they flush my system & I saw them use a yellow bottle of Lockheed brake fluid(Fluid was clear like water). Not sure DOT 4 or what? If I top up next time, can I just use DOT 5.1 or 4 or 3 even without any damage of safety issues? Thanks cos I need some expert advice here. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear January 16, 2007 Share January 16, 2007 Brake Fluid Come with Clear and Red Fluid......Check Properly than Buy ........ Link to post Share on other sites More sharing options...
Genie47 1st Gear January 16, 2007 Share January 16, 2007 4 and 3 are compatible. Ditto with 5.1 with the rest of them but the problem is that you will not get the maximum performance. In the case of BFs, its their wet and dry boiling points. DOT 4 for is good enough. If you can get Ate's Super DOT 4, better. It is the best DOT 4 around. Link to post Share on other sites More sharing options...
Clubace Clutched January 16, 2007 Share January 16, 2007 i thought as long as the specs are met then its suffice. Still need to bother about colour? Link to post Share on other sites More sharing options...
Thundragon Neutral Newbie January 16, 2007 Share January 16, 2007 But my brake fluid come with yellow fluid. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear January 16, 2007 Share January 16, 2007 Some Brake Fluid will Damage the........ Rubber Washer/gasket.......... Link to post Share on other sites More sharing options...
Ccssgm 1st Gear January 16, 2007 Share January 16, 2007 Use Back the Same Brake Fluid Better......Play safe..... Link to post Share on other sites More sharing options...
Genie47 1st Gear January 16, 2007 Share January 16, 2007 No they don't. DOT 4 is backwards compatible with DOT 3. Both are miscible. If materials are compatible with DOT 3, they will be compatible with DOT 4. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear January 16, 2007 Author Share January 16, 2007 Go to AV spare part shops to buy Ate Super DOT 4 lah. It is really overspec'd to the point it is closer to DOT 5.1 than DOT 4. 1. In the end, I bought the SPC DOT 4 brake fluid on my way to the workshop. I'm under the impression that distributor parts and liquid are always more expensive than outside even for the smae brand and spec. I would rather save a few bucks here and there. In the end, sian, I over bought! bought 3 x 0.5L at $10 each. They only used one bottle. Now left with 2 spares. 2. Thanks, I will get it later. How much is the ATE? Regards, Link to post Share on other sites More sharing options...
Genie47 1st Gear January 16, 2007 Share January 16, 2007 $12 for 1L tin. It is Super DOT 4. Borate ester base. Very high BP and even exceeds some of the DOT 5.1 in the market. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery warranty , must we service with distributor?
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Workshops with engine oil flushing machine
