Quantum 5th Gear February 12, 2007 Share February 12, 2007 Hi all, after parking my car, occasionally touched my front Disc brake plate, wow lau! very hot, but the rear drum brake just was sightly warm. is it something wrong for my Disc brake?? ↡ Advertisement Link to post Share on other sites More sharing options...
Herong Neutral Newbie February 12, 2007 Share February 12, 2007 wah!!! u still can touch ar? Link to post Share on other sites More sharing options...
Watwheels Supersonic February 12, 2007 Share February 12, 2007 (edited) U forgot to mention u had been driving for quite some time b4 parking ur car. Edited February 12, 2007 by Watwheels Link to post Share on other sites More sharing options...
Russ 1st Gear February 12, 2007 Share February 12, 2007 Good thing you didn't burn yourself. Braking is all about friction and dissipation of kinetic energy into heat energy. When you brake, a large proportion of the car's weight goes to the front (that is why you should never brake whilst taking a corner at speed - braking can lower the rear grip and then you lose traction behind) and the front brakes generally do most of the work. So, what you felt was normal - thank goodness you didn't just have a bout of hard braking or you would have burnt your fingers. In F1, the brake discs can turn RED HOT and reach temperatures of close to 1,000 degC. Keep your hands away from those discs until they cool down. Link to post Share on other sites More sharing options...
Quantum 5th Gear February 12, 2007 Author Share February 12, 2007 even if I had been driving some time, why was the temperature of disc and drum brake so different? Link to post Share on other sites More sharing options...
Genie47 1st Gear February 12, 2007 Share February 12, 2007 That is because brakes convert the energy that is flinging your car forward to heat energy. Link to post Share on other sites More sharing options...
Liquidh 1st Gear February 12, 2007 Share February 12, 2007 luckily your finger didn't melt... Link to post Share on other sites More sharing options...
Quantum 5th Gear February 12, 2007 Author Share February 12, 2007 thanks for your valuable reply, I learned alot Link to post Share on other sites More sharing options...
Watwheels Supersonic February 12, 2007 Share February 12, 2007 In such a case u should be asking "Why are the brake disc in ur car hotter dan the drum brakes?" Link to post Share on other sites More sharing options...
Ah_liang Clutched February 12, 2007 Share February 12, 2007 Foot brake does to the front, hand brake goes to the rear ... were u drifting? Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 12, 2007 Share February 12, 2007 Wah.... the skin on your finger tips must be real thick & seasoned. Link to post Share on other sites More sharing options...
Quantum 5th Gear February 12, 2007 Author Share February 12, 2007 I tot foot brake implement to all wheels, hand brake goes to the rear only Link to post Share on other sites More sharing options...
Quantum 5th Gear February 12, 2007 Author Share February 12, 2007 nvm, my fingers are made of metel Link to post Share on other sites More sharing options...
Liquidh 1st Gear February 12, 2007 Share February 12, 2007 pity your gf... Link to post Share on other sites More sharing options...
Quantum 5th Gear February 12, 2007 Author Share February 12, 2007 gf too Link to post Share on other sites More sharing options...
Liquidh 1st Gear February 12, 2007 Share February 12, 2007 oh.... Link to post Share on other sites More sharing options...
Tarzan666 2nd Gear February 12, 2007 Share February 12, 2007 wah lau ehh.. nex time touch the exhaust too..can post ask y 2moro. Link to post Share on other sites More sharing options...
Liquidh 1st Gear February 12, 2007 Share February 12, 2007 How about open the coolant tank, RIGHT after parking... heh. ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone missing a car plate?
Change Disc Rotors
Change Disc Rotors
Get a new car plate number for used car
Clear your plates or kena orh gong ah
