inlinesix Hypersonic April 20, 2007 Share April 20, 2007 Yes, u can. Buy Toyota Celica Mk 7. There is 2 version, SS1 utilised d same engine as Toyota Altis which is basically VVT-i and SS2. SS2 engine 2ZZ-GE employs VVTL-i producing 180hp. By d way, VVTL-i means variable valve timing and lift - intelligent. Under 6k RPM, only VVT-i is in operation. After that, valve lift will come into pic. D major downside of tis side of this engine is valve lift starts from 6k RPM till 8.2k RPM (electronic cut-off). U got only 2k RPM to work on. D major diff wif I-VTEC is I-VTEC has SOHC VVT, whereby, 2ZZ-GE is dual VVT. So, @ low RPM, 2ZZ-GE has better torque curve. Sadly, Toyota Celica Mk 7 is EOL. So, can only buy used ka. Currently, Honda has developed A-VTEC which is similar to VVTL-i. ↡ Advertisement Link to post Share on other sites More sharing options...
Carfan Neutral Newbie April 20, 2007 Share April 20, 2007 hardcore siah... What'z your century sprint? 2nd gear can reach 160km/h? Link to post Share on other sites More sharing options...
Robin 4th Gear April 20, 2007 Share April 20, 2007 how to redline with an auto must try an sneak out tonight ... find a quiet road .... here I come red line .... but someone needs to explain .... put in the 2nd or 3rd gear ..... and rev ... if car sploit and need to take taxi back home then .... tomorrow wifey will nag nag .... so finally decided will not try just for now put in in L1 ... engage hold button. floor accelerator.. then let me know if u hit redline or not Link to post Share on other sites More sharing options...
Mivec9 1st Gear April 20, 2007 Share April 20, 2007 The original boyracer then were the suzuki gti...until the civic vtec sweeps all..even till now Link to post Share on other sites More sharing options...
Mivec9 1st Gear April 20, 2007 Share April 20, 2007 blur liao...kekekeke but then from the way you write...sounds like someone lei... Link to post Share on other sites More sharing options...
Falc 3rd Gear April 20, 2007 Share April 20, 2007 My ride DC5R. Type R "Racing" Rev to redline 9000 rpm 2nd gear at 160km/h. 2nd gear 160kmh U changed your final ratio is it? Probably FI as well. Link to post Share on other sites More sharing options...
Porker Turbocharged April 20, 2007 Share April 20, 2007 Didn't know the K20A can rev till 9,000rpm. Did you transplant your K and A to F and C respectively? Link to post Share on other sites More sharing options...
Apong1471 Neutral Newbie April 20, 2007 Share April 20, 2007 (edited) Post: The original boyracer then were the suzuki gti...until the civic vtec sweeps all..even till now _________________________________________ Yup....Agreed.....Suzuki GTI & Charade Turbo....& CRX. Those good old days of small speedy car..... But on the other hand....Civic Vtec has killed hundreds of young punk...rich boss son...ah beng ah seng....cos they don't know how to control those "open vtec" & crushed. Edited April 20, 2007 by Apong1471 Link to post Share on other sites More sharing options...
Espire 1st Gear April 20, 2007 Share April 20, 2007 I got both cars... vtec got pulling factor integrated. u can feel the car sudden surge and keep pulling away.. vvti to me like nothing.. nothing to experience. so its just a meaningless term to me.. cant feel anything. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear April 20, 2007 Share April 20, 2007 care to share which year of the two cars that you have? Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear April 20, 2007 Share April 20, 2007 Got. But, have to pay an arm or leg to have it.... http://en.wikipedia.org/wiki/Lotus_Exige Lotus exige costing over 200k in Singapore. At this price, s2000 is a much better deal. if iam not wrong,Lotus is using VVTL-I and not VVTI.similar to the Celica SS2 engine. correct me if iam wrong. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear April 20, 2007 Share April 20, 2007 if you noticed the mod list that he stated. it's no surprise that he can hit 9,000 RPM. Link to post Share on other sites More sharing options...
inlinesix Hypersonic April 20, 2007 Share April 20, 2007 VTEC of course got pulling factor due to sudden increase in power on high RPM. VVT-I is definely much smoother as power & torque is build up gradually as there is no sudden surge in power. Meaningful or not is dependant on individual. Link to post Share on other sites More sharing options...
inlinesix Hypersonic April 20, 2007 Share April 20, 2007 U r rite. That's d only 1. Wif that engine in Lotus, it should b veri nice drive. Link to post Share on other sites More sharing options...
Ls430 Clutched April 20, 2007 Author Share April 20, 2007 Yes, u can. Buy Toyota Celica Mk 7. There is 2 version, SS1 utilised d same engine as Toyota Altis which is basically VVT-i and SS2. SS2 engine 2ZZ-GE employs VVTL-i producing 180hp. By d way, VVTL-i means variable valve timing and lift - intelligent. Under 6k RPM, only VVT-i is in operation. After that, valve lift will come into pic. D major downside of tis side of this engine is valve lift starts from 6k RPM till 8.2k RPM (electronic cut-off). U got only 2k RPM to work on. D major diff wif I-VTEC is I-VTEC has SOHC VVT, whereby, 2ZZ-GE is dual VVT. So, @ low RPM, 2ZZ-GE has better torque curve. Sadly, Toyota Celica Mk 7 is EOL. So, can only buy used ka. Currently, Honda has developed A-VTEC which is similar to VVTL-i. are u a car engineer by any chance ... I have to read your reply 2-3times but finally got it ... lucky not that stupid. thanks Link to post Share on other sites More sharing options...
inlinesix Hypersonic April 20, 2007 Share April 20, 2007 I m not an engineer. I m juz a 'petrol head'. Which part u did not get it? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear April 20, 2007 Share April 20, 2007 What do you want out of each car??? The answer will bounce back and forth depending on how you like your drive to be like. I like performance and in this scenario, honda's vtec pulls it off better than toyota's vvt-i. can't we have the best of both worlds .... only can afford to buy one car Got! Audi's LeMans racer... good FC, massive torque (and super flat curve) for pulling, and good power. Link to post Share on other sites More sharing options...
Vesfreq Neutral Newbie April 20, 2007 Share April 20, 2007 (edited) Bro, read my post carefully leh. Did I say Lotus use VVTI? I replied to the other guy saying that got other car with vvtl-i, but will cost an arm or a leg. Edited April 20, 2007 by Vesfreq ↡ Advertisement Link to post Share on other sites More sharing options...
Income tax Evasion
Income tax Evasion
Retired Gurkha is better than Ip Man!
2 lanes turn right to 3 lanes - which lane to go?
Which brand of honey to buy?
Which airline is the best?
