Tomsss Neutral Newbie February 26, 2015 Share February 26, 2015 Hi, thought I would reuse this thread. I noticed my temperature gauge started to go above the halfway mark today while idling at the traffic light. It seemed to improve when I switched the aircon off. Once the car is on the move again the temperature drops back to the halfway mark. Today is the first time this happened. The water pump was replaced in November. Could it be due to a lack of coolant? Or perhaps the fan belt is slipping? If the fan is working fine, no leaks found and coolant level ok, you might wanna try bleed the coolant system again, to remove any residue air that is causing the reduced cooling efficiency. ↡ Advertisement Link to post Share on other sites More sharing options...
Kklee 6th Gear February 26, 2015 Share February 26, 2015 Hi, thought I would reuse this thread. I noticed my temperature gauge started to go above the halfway mark today while idling at the traffic light. It seemed to improve when I switched the aircon off. Once the car is on the move again the temperature drops back to the halfway mark. Today is the first time this happened. The water pump was replaced in November. Could it be due to a lack of coolant? Or perhaps the fan belt is slipping? If your car have two fans for the engine, maybe one of the fan is not working. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 28, 2015 Share February 28, 2015 If the fan is working fine, no leaks found and coolant level ok, you might wanna try bleed the coolant system again, to remove any residue air that is causing the reduced cooling efficiency. Most of the transverse engines mounted in cars with aerodynamic bonnets tend to trap air bubbles in the cooling systems highest points and hardly they can be removed via the bleeding screw. The best and fastest way for the mech to 100% free the cooling system from air bubbles is to use this simple device - see video. ↡ Advertisement Link to post Share on other sites More sharing options...
Are You A Big Spender For A High End Bed Mattress?
ACS boy dies during high adventure course
High-rise littering
High-rise littering
HSA recalls 3 brands of high blood pressure drugs
How to tell if someone is high or low class?
High mercury fish to avoid
Would you buy a high mileage E200K (W211) ?
