Mivec9 1st Gear May 21, 2007 Author Share May 21, 2007 Hmm...what is OBD port? ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 21, 2007 Share May 21, 2007 Did u see if they put in plugs with the same heat range as the old plugs or the gaps were too close or wide? Or maybe a plug is loose which may b causing the high temps. Get it checked just in case. If it is the cause, then your solution will b real cheap & easy. Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 21, 2007 Author Share May 21, 2007 will pop by to their place after my trip...was busy last weekend Link to post Share on other sites More sharing options...
Jchuacl Clutched May 21, 2007 Share May 21, 2007 On board diagnostics. Once a warning code is generated it will stay there till it is manually cleared. Recently I observed a 5-6 degrees abnormal temp increase for both the water and atf temp. In the end using the OBD readouts and the warning code, the issue was narrowed down to a faulty radiator fan (I've 2 fans and the faulty fan could not be seen easily as I've a tight engine compartment). Link to post Share on other sites More sharing options...
Flight_skoda Neutral Newbie May 21, 2007 Share May 21, 2007 (edited) Just got high temperature yesterday. After top up, car back to normal..with fan cutting in at the slightly more half mark of the temperature. But when drive long period, the high temp came back. I did a reflush of the coolant suspecting it could be too dilute. Now still monitoring...what could be the problem?? Check your radiator water level, is it dropping very fast. If it is, then there is likely to be a leak somewhere. That was what happened to my previous old Sutuki Swift. Edited May 21, 2007 by Flight_skoda Link to post Share on other sites More sharing options...
Dumb 4th Gear May 21, 2007 Share May 21, 2007 Just got high temperature yesterday. After top up, car back to normal..with fan cutting in at the slightly more half mark of the temperature. But when drive long period, the high temp came back. I did a reflush of the coolant suspecting it could be too dilute. Now still monitoring...what could be the problem?? Could it be a case of air in the system since you flush your radiator. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 22, 2007 Share May 22, 2007 Could it be a case of air in the system since you flush your radiator. ========================= Yes. This cud b one of the causes too. I got rid of any air after flushing or any work done on the rad by driving up & down a steep slope after the car is fully warmed up. Cause all the air bubbles/pockets to flow to the rad where I can then just top-up the coolant. Link to post Share on other sites More sharing options...
Dumb 4th Gear May 22, 2007 Share May 22, 2007 Could it be a case of air in the system since you flush your radiator. ========================= Yes. This cud b one of the causes too. I got rid of any air after flushing or any work done on the rad by driving up & down a steep slope after the car is fully warmed up. Cause all the air bubbles/pockets to flow to the rad where I can then just top-up the coolant. --------------------------- Don't remember that way of getting rid of air. Did my own flushing 20 years ago. Not forgot how to Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 25, 2007 Share May 25, 2007 will pop by to their place after my trip...was busy last weekend ======================= So Sam. Have u settled your overheating problem yet. Keep us informed please. Good luck. Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 7, 2007 Author Share June 7, 2007 was overseas..just came back..will go for medical checkup soon Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 17, 2007 Author Share June 17, 2007 Thanks for your recommendation. My high temperature problem is finally solved. He took out radiator and get another workshop to clean it. Also he corrected the activation of the radiator fan cut in at half mark rather than at more than half mark. Link to post Share on other sites More sharing options...
Freakman Neutral Newbie June 22, 2007 Share June 22, 2007 mine the radiator fan was set to ON always... so my temp is always low... unless kana stuck in those hot weather with traffic jam... anyway not sure whether set to ON always will damage anything or not... Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 23, 2007 Author Share June 23, 2007 I did search thru the forum then but didnt read carefully: this was from yong in jan 2002 - my prob was in Qn4: Sounds like a seriously clogged radiator to me. Maybe u would wan to check these out. These are from my past experience with old cars Q : 1. When your car overheat, does the radiator fan comes on? (with aircon off) 2. When your car overheat, try to press the top radiator hose (very hot!!) is it hard? 3. When your car is cold (morning), take out the radiator cap, start the engine, pull the throttle cable slightly, did u see coolant gushing out from the refilling hole? 4. When you go on high speed ie. >120km/h, does it overheat? A: 1. If No, fan dead or relay dead (smack the relay box if u know where and see if fan comes on) 2. If hose is hard - Thermostat is okie. If hose is soft, thermostat might be jammed 3. If no water gush out, even with full coolant level, u have a weak water pump 4. If overheat - Radiator is choked - sent radiator to radiator shop for flushing. I suggest u to do a minor cooling system overhaul. 1. Send radiator to clean (ask ur mechanic if u dunno, does the trick everytime) 2. Change a new Thermostat (less than $50 for R220) 3. Fan should not be weak or slow unless your car accident before. Its either dead or working It sounds like a clogged radiator to me. Nothing fancy, same experience before. Those flushing solution dun work, I suggest u give up. U need radiator specialist to tear out the top and bottom radiator head cover to remove all the rust with special tools. Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 23, 2007 Author Share June 23, 2007 my take is if u on the radiator fan, yes ur temp be low, ur fan life will be shortern. Also, cars are made to work optimumly at around 90 deg celcius or so, if you always on fan, i would say ur cars wont be functioning at its best. That's why when my mech did that bypass for me without my consent, next day i go back to kpkb Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie June 30, 2007 Share June 30, 2007 Hi all bros/sis out there,urgently need serious advices. Today when I drive at 1st and 2nd gear,the car jerk like nobody's biz,gotta ramp the acc to stop the car from jerking,stopped at the bus stop,opened the bonnet and looked everywhere,cannot c any leaking.But when open the coolant reservoir of my Proton Wira,my goodness, the coolant reservior almost drained out,but I confirm no leaking as I recently just changed the leaking radiator. So I quickly drove back to my car park and top with water,called a workshop at woodlands and asked for advise.The fellow told me to drive to Northlink. Damn scared,keep on monitoring the temp and max speed only 100km. Reached the workshop,the mechanic did a test round,when he came back with the car,water gashing out from the coolant reservior,not the radiator,the fellow tested and confirmed that my temp sensor behaving funny,sometime can activate fan,sometime cannot.He tried to fit in another spare bit cannot fit,thread different.Too bad sunday cannot find spare,must wait for monday. I would like to ask if the water temp sensor spoil,what are oher things I must check,what other parts may be damaged. I thgt of going to J to find spare but scared jam,die liao,water sure boil,cause fan cannot work properly Pls advice?????????????????? Link to post Share on other sites More sharing options...
Sevnrg Neutral Newbie July 1, 2007 Share July 1, 2007 my old civic also encountered this prob.Radiator leak, hoses leak due to the coolant "biting" the hoses as told by mechanic.He said I used bad coolant and never mix properly with water.I didn't know then, I poured whole bottle of coolant into it. water by itself is still has the BEST heat transfer properties (RL WW is an exception). "coolant" only acts as an antifreeze and antirust agent but also degrades the performance of the cooling system Link to post Share on other sites More sharing options...
Genie47 1st Gear July 1, 2007 Share July 1, 2007 Antifreeze improves overboil protection. It does not degrade the cooling performance. It only degrades the cooling performance if you go beyond 50%. Link to post Share on other sites More sharing options...
flashbang Turbocharged February 24, 2015 Share February 24, 2015 Hi, thought I would reuse this thread. I noticed my temperature gauge started to go above the halfway mark today while idling at the traffic light. It seemed to improve when I switched the aircon off. Once the car is on the move again the temperature drops back to the halfway mark. Today is the first time this happened. The water pump was replaced in November. Could it be due to a lack of coolant? Or perhaps the fan belt is slipping? ↡ Advertisement Link to post Share on other sites More sharing options...
Are You A Big Spender For A High End Bed Mattress?
ACS boy dies during high adventure course
High-rise littering
High-rise littering
HSA recalls 3 brands of high blood pressure drugs
How to tell if someone is high or low class?
High mercury fish to avoid
Would you buy a high mileage E200K (W211) ?
Honda Stream 2009 No Power and High fuel Consumption
