High Temperature
Mivec9
Just got high temperature yesterday. After top up, car back to normal..with fan cutting in at the slightly more half mark of the temperature.
But when drive long period, the high temp came back. I did a reflush of the coolant suspecting it could be too dilute. Now still monitoring...what could be the problem??
eh, u got the fever
does the water circulate in the cooling system, referring to water pump
thermostat switch?
fan weak?
too dilute a coolant will not increase temp,
u can run your car with just tap water and it will not overheat if everything is in order
my old civic also encountered this prob.Radiator leak, hoses leak due to the coolant "biting" the hoses as told by mechanic.He said I used bad coolant and never mix properly with water.I didn't know then, I poured whole bottle of coolant into it.
most likely water pump up lorry.
2nd is thermostat not working. did not spring open. try not to switch on aircon too early as the fan cooling may affet the thermostat cut in.
3rd - check engine oil level. make sure the oil dipstick is plant back properly.
If you do notice some rough idling or vibration, could be radiator water leaking into combustion chamber. If that need to do a top-overhaul...
Try to locate the leak....
Thanks all bros and sis replies.
I changed my water pump late 2005...not sure whether it should spoil so prematurely.
Oil level and dipstick ok.
Hoses no leaks.
The temp valve seems working perfectly..on the fan at slightly more half mark always.
Will keep monitoring and keep you guys update.
There is a "weep hole", for the water pump. Know where it is on your engine. Park overnight and see if there is any puddle of colored fluid beneath it. Look for encrusted colored crystals around the cooling system as well.
I did one around 1 year ago at my usual workshop (I think you know where....), it costs $750 cos other than top overhaul to solve water leaking into combustion chamber, I also did clutch replacement, and engine oil change, gear box oil change, radiator fluid change, replace gearbox oil seal and 1 main oil seal.
[sweatdrop] the price quite hefty bro..but with clutch replacment..at least it offset the price a bit.
Thks for info..
