Spikedoll Clutched May 15, 2007 Share May 15, 2007 Recently my car had this weird noise when cold engine start.It sounds like some crushed ice or water from engine compartment.I could hear it clearly from inside of car.It lasted for few minutes then stop or when engine is warm. I sent it to TC and the mechanic couldn't diagnose what is the cause, and said never encounter that before.Then they told me the noise is gone when they removed heater.They removed the hoses and used rubber stopper to block it. Coolant been tampered coz I installed water temp & rpm gauges, so warranty considered void,moreover I didnt go back TC for servicing.So there's no charge except rubber stopper. SG weather does not require heater but will removal of heater cause any problem in future? TC mechanic told me no problem. They also drain out the air or something and told me to lookout tomorrow morning if coolant level drop then just top up, coz there is still air in the hoses. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Fitvip Supersonic May 15, 2007 Share May 15, 2007 What heater? Are you referring to the thermostat? If it is, then no problem removing it lor! Link to post Share on other sites More sharing options...
macrosszero Turbocharged May 15, 2007 Share May 15, 2007 (edited) If you remove the thermostat the thermal fans will be wired to run all the time instead of cooling the engine when it is needed. Although in tropical Singapore you will never run into the problem of overcooling an engine, you place unnecessary additional load on your electrical system to constantly power the fans. Edited May 15, 2007 by Macrosszero Link to post Share on other sites More sharing options...
macrosszero Turbocharged May 15, 2007 Share May 15, 2007 It sounds like they removed the problem instead of solving it. They should have returned you the parts that they have removed. You should then go to a workshop that can diagnose and fix the problem for you. Honestly I expect more from an AD's workshop than such flippant slipshod troubleshooting. Link to post Share on other sites More sharing options...
Spikedoll Clutched May 15, 2007 Author Share May 15, 2007 ehh..sorry I'm not tech-inclined in this..my understanding is they removed the hoses that connect to heater,and used rubber stopper to block it. I think it's heater hose that connect to coolant?They said don't use heater. Link to post Share on other sites More sharing options...
Spikedoll Clutched May 15, 2007 Author Share May 15, 2007 they did returned me the 2 hoses. I'm going monitor for next few days if the noise occur again.It seems TC mechanic cannot find the cause of problem. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear May 15, 2007 Share May 15, 2007 Its fine. The only effect you'll prolly ever see is that when you move your AC controls to hot, no hot air comes out. Link to post Share on other sites More sharing options...
Boyboy 1st Gear May 15, 2007 Share May 15, 2007 in SG, HOT air is the default when A/C is off Link to post Share on other sites More sharing options...
Watwheels Supersonic May 15, 2007 Share May 15, 2007 The only aftermath I can think of when heater is removed is that during rainy season balls will shrink to peanut size cos very cold. Your car will be alright though. Wear thicker underwear. Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear May 15, 2007 Share May 15, 2007 lol spikedoll is a missus. she has no balls.... Link to post Share on other sites More sharing options...
Silver_blade Turbocharged May 15, 2007 Share May 15, 2007 A potential problem is that the rubber stopper may crack overtime, cos of the great pressure and heat. Such mod was very popular among merc in the 80's...but most soon found out about this problem. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear May 15, 2007 Share May 15, 2007 trust me... not as hot as when the AC controls are turned to hot our air is "warm" in comparison Link to post Share on other sites More sharing options...
Furrynadz 5th Gear May 15, 2007 Share May 15, 2007 everyone has 4 round things 2 on the behind and the other 2 either on top or below Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear May 15, 2007 Share May 15, 2007 i think what the mech did was remove the hoses that runs from the engine to the heater and joined the 2 sections at the engine while blocking up the ports to the heater (which serves no real purpose anyway). Shouldnt be a prob if done that way as there's no pressure on the stoppers whatsoever. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged May 15, 2007 Share May 15, 2007 (edited) From understanding from the post...I believe there is a rubber stopped to block the coolant from going the route of the 'heater' which hose has been removed. Edited May 15, 2007 by Silver_blade Link to post Share on other sites More sharing options...
Spikedoll Clutched May 16, 2007 Author Share May 16, 2007 thanks all for the replies...I will continue monitor and check the rubber stopper if it wears out. I just hope removal of the hoses do not cause any aftermath problems.I don't use heater anyway. thank you thank you Link to post Share on other sites More sharing options...
Damn66 Neutral Newbie May 16, 2007 Share May 16, 2007 purposely removed mine 3 yrs back..so far no problems..aircon still running cold Link to post Share on other sites More sharing options...
Dalenico 1st Gear May 16, 2007 Share May 16, 2007 Toyota Altis doesn't come with heater anyway...so it should be fine ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Man who removed bus stop bench to check its dimensions for f
Dealer re-sell problem car
Family of three electrocuted to death at Taman Jurong
Discussion on Gout problem
