Tkseah Turbocharged May 28, 2007 Share May 28, 2007 This morning when i first started the car engine, it automatically rev up to ~2.5k rpm for about 5 sec before settling down to the normal idle of ~1k rpm.. 1st time i every encountered this.. anyone got idea what could have caused it and if it is anything to worry about?? ↡ Advertisement Link to post Share on other sites More sharing options...
DarkLord 1st Gear May 28, 2007 Share May 28, 2007 Sounds ok to me. Link to post Share on other sites More sharing options...
Tkseah Turbocharged May 28, 2007 Author Share May 28, 2007 Ok? Normally it will just go straight to idle at ~1.1k, without reving at ~2.5k for 5 secs.. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear May 28, 2007 Share May 28, 2007 dirty throttle body Link to post Share on other sites More sharing options...
Ccssgm 1st Gear May 28, 2007 Share May 28, 2007 Is Normal....If shoot up to 3.5K.....U need to worry.... Link to post Share on other sites More sharing options...
Lucien Neutral Newbie May 28, 2007 Share May 28, 2007 Hi, for accent this a normal problem. How i know, i experiment on this. I tried and able to repeat this for many times. HOHOHO This is cause by fast crank. Instead of u crank the car to start and hold it there for about 1 secs to let the car start, u did release the crank too fast. Thus, there is a current surge from your battery. Nothing to worry about. If problem persist, check if your throttle cable got problem or not. It should be free from any obstruction. Link to post Share on other sites More sharing options...
Tkseah Turbocharged May 28, 2007 Author Share May 28, 2007 Thanks guys.. now i can sleep easier without worrying that it'll burst into flames on me.. Next servicing is planned for 3 weeks time.. so hopefully they will spot if anything need tweaking.. Link to post Share on other sites More sharing options...
Loner911 Clutched May 28, 2007 Share May 28, 2007 what car you driving? Link to post Share on other sites More sharing options...
Lucien Neutral Newbie May 28, 2007 Share May 28, 2007 no worry no problem one. Link to post Share on other sites More sharing options...
Emils 2nd Gear May 28, 2007 Share May 28, 2007 Mine does that sometimes too. Haha. It's still working fine (at least on the surface). :P Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 28, 2007 Share May 28, 2007 (edited) Its perfectly normal for the ECU to run the car at fast idle during cold starts. If you ask me, 5secs is really short..... Mine on cold starts will run at ~ 2.5K for about 30 secs... then slowly gets lower at around 1.5K rpm by the 1st min. Then gets lower to about 1.2K rpm by the 2nd min. and finally around 900 at 3rd min.... it takes around 5 mins of warm up for it to get down to ~ 800 rpm idling, by which time the oil temp is like 75deg. Edited May 28, 2007 by Dwoon Link to post Share on other sites More sharing options...
Swmc Neutral Newbie May 28, 2007 Share May 28, 2007 Don't worry about it Link to post Share on other sites More sharing options...
Tkseah Turbocharged May 29, 2007 Author Share May 29, 2007 Normal ah.. guess i mountain tortise cos this is 1st time i encounter.. Usually mine will start idling at 1.1k and settle down to 0.9k after 1-2 mins.. Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 29, 2007 Share May 29, 2007 DIfferent car makes & models have their own programming for warm up. Like for mine, if I want to save petrol, then I just tap the throttle and the rpm drops immediately from 2K ought to about 1.2K rpm for the warm up. But for some other cars, the tapping of throttle does not do this. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 29, 2007 Share May 29, 2007 Bro, it's normal Once engine started to warm up, the rpm will naturally reduced If your RPM still remains at 2.5K RPM after it has been warmed up then you gonna start worry ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
All about smoking
All about smoking
Lets talk about fish!
All about springs and shocks(dampers)
Questions about Toyota Mark X
