Jemig Clutched August 13, 2007 Share August 13, 2007 it happened when i crank my engine after refuel at petrol station. loud "POMP" heard n when i tried to crank again it juz wun fired up. popped my hood n fumes seen oozing out from the battery. upon checking further the battery was ripped open on one side. both battery terminals still intact with cables connected to it. no short-cct between the terminals. i'm trying to figure out wat causes it n hope if anyone with similar experience can share their findings n preventive measures taken. devices connected to my battery: 1. z-stab - installed 3 yrs ago n have no problems b4 this. it's still working after this mishap. 2. 5-pt grounding - juz installed abt 2 weeks ago. 4 pts connected to various places n 1 pt terminated at the negative end of battery terminal. appreciate input from u guys. :) cheers!! ↡ Advertisement Link to post Share on other sites More sharing options...
Shox87 4th Gear August 13, 2007 Share August 13, 2007 hey bro wad car are u driving man? seems pretty serious. ur car still under warranty? Link to post Share on other sites More sharing options...
Nolicense Turbocharged August 13, 2007 Share August 13, 2007 what battery is it? MF or not? Link to post Share on other sites More sharing options...
Highwaycode Neutral Newbie August 13, 2007 Share August 13, 2007 Walau-eh! Think probably some Hydrogen gas bubbles got trapped inside the battery plates and blocked vent-hole. Just a thought. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 13, 2007 Share August 13, 2007 Is it Varta? Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 14, 2007 Share August 14, 2007 Looks like a localised electrical component short circuited - if it's a battery explosion yr ride bonnet will be seriously damaged and logically fire will follow with all the electrical cable isulation burnt. Link to post Share on other sites More sharing options...
Highwaycode Neutral Newbie August 14, 2007 Share August 14, 2007 more stories on car battery explosion.... http://rayvaughan.com/battery_safety.htm Link to post Share on other sites More sharing options...
Apollo 1st Gear August 14, 2007 Share August 14, 2007 yup.. bleve.. breakup and build up of hydrogen gas combined with oxygen gas can b explosive Link to post Share on other sites More sharing options...
Apollo 1st Gear August 14, 2007 Share August 14, 2007 (edited) neber cover the battery top so the gas can escape properly, as there r small pin holes for gas to escape. in any case, i strongly recommend u quickly do an engine wash asap by a professional workshop so tat the corroding acids does not attack other parts of ur engine bay. or the liquid spread fr parts to parts. Edited August 14, 2007 by Apollo Link to post Share on other sites More sharing options...
Zeus73 Neutral Newbie August 14, 2007 Share August 14, 2007 I encounter once before... On my slightly more than 1 year old KIA Sephia... Happened at night in HDB Carpark... Very loud... Stock battery... Zero mod on car... I think it's a MF battery... Cos no liquid flow out after the side of battery rip open... Best part is, car and battery just past 1 year... And battery only got one year warranty... Link to post Share on other sites More sharing options...
Ikeehc Clutched August 14, 2007 Share August 14, 2007 scary Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear August 14, 2007 Share August 14, 2007 Wa Lau Bro, the battery water is corrosive hence you goonna clean it thoroughly Link to post Share on other sites More sharing options...
Watwheels Supersonic August 14, 2007 Share August 14, 2007 You did not top up the distill water in your wet batt? Link to post Share on other sites More sharing options...
Hoppie24 1st Gear August 14, 2007 Share August 14, 2007 maybe the Z-stab gave way and shorted both terminal when u crank? Link to post Share on other sites More sharing options...
Contax 1st Gear August 14, 2007 Share August 14, 2007 what 'type' of battery is it ? Link to post Share on other sites More sharing options...
Yuan 6th Gear August 14, 2007 Share August 14, 2007 it happened when i crank my engine after refuel at petrol station.loud "POMP" heard n when i tried to crank again it juz wun fired up. popped my hood n fumes seen oozing out from the battery. upon checking further the battery was ripped open on one side. both battery terminals still intact with cables connected to it. no short-cct between the terminals. i'm trying to figure out wat causes it n hope if anyone with similar experience can share their findings n preventive measures taken. devices connected to my battery: 1. z-stab - installed 3 yrs ago n have no problems b4 this. it's still working after this mishap. 2. 5-pt grounding - juz installed abt 2 weeks ago. 4 pts connected to various places n 1 pt terminated at the negative end of battery terminal. appreciate input from u guys. :) cheers!! Could it be your Z stab and/or your 5 pt grounding? Link to post Share on other sites More sharing options...
Watwheels Supersonic August 14, 2007 Share August 14, 2007 I dun think a bunch of capacitors in the z-stab can cause that. If that's the case u should stay away from your TV set cos inside also have a bunch of capacitors. It must be his wet batt dried up to cause the explosion. Link to post Share on other sites More sharing options...
Tarzan666 2nd Gear August 14, 2007 Share August 14, 2007 2day while riding 2 work..saw 1 fire engine, TP bike, patrol car, 1 CD firebike around 1 bus in bedok...they spraying some solution around the SBS bus battery area...seems quite serious..white solution all on the ground... ↡ Advertisement Link to post Share on other sites More sharing options...
Amaron Battery
Amaron Battery
My EV journey to the i4
Battery for Honda Vezel
