Heelntoe 1st Gear September 10, 2007 Share September 10, 2007 Hello Frens, Anyone know if reverse light not working can pass inspection? rgds ↡ Advertisement Link to post Share on other sites More sharing options...
Thefear Clutched September 10, 2007 Share September 10, 2007 Ey.... y don u just fix it b4 goin? Change bulb only mah Link to post Share on other sites More sharing options...
Osiris 1st Gear September 10, 2007 Share September 10, 2007 yah, change bulb only. not expensive at all if fail, still have to pay for reinspection Link to post Share on other sites More sharing options...
Sony 1st Gear September 10, 2007 Share September 10, 2007 one fail or 2? Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 10, 2007 Share September 10, 2007 the sane one will pass u but will tell u 2 chge it asap.Tis is a small issue they will overlook Link to post Share on other sites More sharing options...
Apollo 1st Gear September 10, 2007 Share September 10, 2007 aiya.. get ur mechanic to service ur car and ask him arrange inspection lah. he can change lamp for u. pay $$$ problem solved. tail light lamp beri e-chee to change mah Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear September 10, 2007 Share September 10, 2007 so far i've never seen inspectors inspect the rear lights before... should be no prob... 1 Link to post Share on other sites More sharing options...
Sony 1st Gear September 10, 2007 Share September 10, 2007 you must see what car, you know. Not all cars are those with a flip down access panel and you stick your hand in, dig out, change and stick back. Link to post Share on other sites More sharing options...
Apollo 1st Gear September 10, 2007 Share September 10, 2007 wat car? Link to post Share on other sites More sharing options...
Bearbear1494 Clutched September 10, 2007 Share September 10, 2007 As mentioned, I've yet to see an inspector check all the lighting, except for headlight & brakelights. Though I've been warned by an inspector before that my 3rd brakelight was too glaring (48 LED aftermarket) & that I should adjust the angle so that it doesn't affect roadusers behind me. Link to post Share on other sites More sharing options...
Sony 1st Gear September 10, 2007 Share September 10, 2007 my car lor Link to post Share on other sites More sharing options...
Apollo 1st Gear September 10, 2007 Share September 10, 2007 wat car is tat wor... Link to post Share on other sites More sharing options...
Sony 1st Gear September 10, 2007 Share September 10, 2007 astra lor Link to post Share on other sites More sharing options...
York Clutched September 10, 2007 Share September 10, 2007 light bulb ...cheap cheap nia...why wanna risk a re-inspection... Link to post Share on other sites More sharing options...
Simnon Clutched September 10, 2007 Share September 10, 2007 Went for the inspection at STA in Ayer Rajah, they do not check the reverse light, but check the intensity of the head lamps and back lamps under high beam only. My car failed the lamp intensity test and they still issue me the pass certificate as the critical ones such as brakes and exhaust levels passed. Link to post Share on other sites More sharing options...
Sony 1st Gear September 10, 2007 Share September 10, 2007 Tell it to the TS. Only he can tell you why... Link to post Share on other sites More sharing options...
Heelntoe 1st Gear September 10, 2007 Author Share September 10, 2007 To all, Thanks for all your opinions. It's actually the reverse light switch on my gbox that is spoilt. I got a replacement switch, but the switch is designed w a threaded body which screws onto the gbox. the threads are seized, so cannot take out. To Simnon: Yah I did my prev inspection at ayer rajah too but can't rem if they check reverse light. will try my luck at ayer rajah again. once again, thank you ALL! Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 10, 2007 Share September 10, 2007 I reckon - no,it is not practical and not safe to put the transmission into rever gear as there are other cars in the Q. ↡ Advertisement Link to post Share on other sites More sharing options...
Vicom Annual Car Inspection
Reverse/backup camera with dashcam recording function
Vehicle Inspection Failed due to Tinting
Cyclops Rear Light - Who came up with it first?
Used Car, what STA Inspection grade then can buy?
Car inspection questions
Car fails to reverse out of HDB car park lot after 12 tries
