Gbsm Neutral Newbie March 31, 2008 Share March 31, 2008 A good link on how to remove blindspot without blind spot mirrors.. Meant for Left hand drive.. Change accordingly for Right hand drive. http://pages.cs.wisc.edu/~gdguo/driving/BlindSpot.htm ↡ Advertisement Link to post Share on other sites More sharing options...
Stuka Neutral Newbie March 31, 2008 Share March 31, 2008 Useful. Thanks. Link to post Share on other sites More sharing options...
Fitvip Supersonic March 31, 2008 Share March 31, 2008 I have been using this method for the past few years after learning it from a forum Bro in A1Motoring forum. Link to post Share on other sites More sharing options...
So_nice 6th Gear March 31, 2008 Share March 31, 2008 hyperlinked http://pages.cs.wisc.edu/~gdguo/driving/BlindSpot.htm Link to post Share on other sites More sharing options...
Libox88 Neutral Newbie March 31, 2008 Share March 31, 2008 Is a longer rear mirror does the same as it can cover a broader back view behind. Link to post Share on other sites More sharing options...
Wt_know Hypersonic March 31, 2008 Share March 31, 2008 based on this method, the side mirror barely show my car backside. how to do parking ? Link to post Share on other sites More sharing options...
Rickster 5th Gear March 31, 2008 Share March 31, 2008 A good link on how to remove blindspot without blind spot mirrors..Meant for Left hand drive.. Change accordingly for Right hand drive. http://pages.cs.wisc.edu/~gdguo/driving/BlindSpot.htm Very useful thanks! Guess should put it up as a sticky. MODS! Link to post Share on other sites More sharing options...
Fitvip Supersonic March 31, 2008 Share March 31, 2008 The curve one will do the job, but must get used to the smaller images to judge the distance! Link to post Share on other sites More sharing options...
Fitvip Supersonic March 31, 2008 Share March 31, 2008 Add convex mirrors can liao! Link to post Share on other sites More sharing options...
Gbsm Neutral Newbie March 31, 2008 Author Share March 31, 2008 Bro , I am using this. Adjustment should be made upto the finest. Notice that in the links its mentioned that "just barely" is marked as bold.. Yes your car should not disappear from your mirror or show major portion of your car.. Just barely is the right adjustment. For Parking I also use one more technique esp when side of the car is close to the pillar.. I apply brake, the brake lamp is powerful to see the sides more clearly. Link to post Share on other sites More sharing options...
Coburn 1st Gear March 31, 2008 Share March 31, 2008 er... does this really work? the premise is that we will be able to see the car transiting from the rear mirror to side mirror view. But what about bikes? Aren't they small enough to still hide in the "blind spot"? Personally, I make it a point to turn my head to ENSURE there are no vehicles / bikes. I think it is safer that way Link to post Share on other sites More sharing options...
Libox88 Neutral Newbie March 31, 2008 Share March 31, 2008 Yeah I think also beside turning the head around, signal early is important. Link to post Share on other sites More sharing options...
Cactus Clutched March 31, 2008 Share March 31, 2008 i dont think this workable leh... if tilt far out till cannot see the car body, will tend to miss out those motorbikes that are trying to squeeze inbetween cars, dangerous also. either put those small blind spot mirrors or/and use a long long rear view mirror will do. Link to post Share on other sites More sharing options...
Testa_ross4 Clutched March 31, 2008 Share March 31, 2008 I am using a 400mm long very convex mirror, can see up to the front 1/2 left and right windows. Anything less than 400mm and not fully convex is no use. Link to post Share on other sites More sharing options...
Auron 2nd Gear March 31, 2008 Share March 31, 2008 yes it works. the rear and side mirror have to be adjusted so that there is literally no blind spot for the moto to hide. Link to post Share on other sites More sharing options...
Boyboy 1st Gear March 31, 2008 Share March 31, 2008 good point. for the diagram, a bike might still be able to be in the blind spot. even if u can see a BIT of the bike on each side, the brain might not register. i will still use my blind spot mirrors AND sometimes turn my head. esp when mirror is wet from rain Link to post Share on other sites More sharing options...
Melissa 1st Gear March 31, 2008 Share March 31, 2008 IMO,this link is good for Reference only. the best solution is still Signal Early and turn your head to check blindspot Visually. Link to post Share on other sites More sharing options...
Nirxe Clutched March 31, 2008 Share March 31, 2008 I don't find this piece of advice useful at all. So inconvenient and I think they forgot about the "how to park" part? ↡ Advertisement Link to post Share on other sites More sharing options...
Blind spot mirror?
Blind spot mirror?
Blind spot mirrors
Blind spot mirrors
Xiaomi cyberDog
Xiaomi cyberDog
TP measure kids on the spot to check height !
Are blind spot mirrors useful at all?
Spot the merlion
Spot the merlion
Roof blind
Roof blind
Spot the mistake
Spot the mistake
