Friendstar Supercharged April 26, 2008 Share April 26, 2008 Hey there, i heard auto gearbox cost between 4-6k to replace. Can i know what is the expected lifespan of an auto gear box? THanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear April 26, 2008 Share April 26, 2008 Some are more than 4K~6K I.e Mine will cost almost 12~13K jus for the gearbox without labout charges chucked in if it is carried out at the agent's premises I think with regular changing of ATF, it should last more than 7 years Link to post Share on other sites More sharing options...
Nirxe Clutched April 26, 2008 Share April 26, 2008 (edited) 5 years will be a safe gauge. Edited April 26, 2008 by Nirxe Link to post Share on other sites More sharing options...
Friendstar Supercharged April 26, 2008 Author Share April 26, 2008 u mean after 5 years.... all auto owners must spend 12k for auto gearbox?!?!? Link to post Share on other sites More sharing options...
Friendstar Supercharged April 26, 2008 Author Share April 26, 2008 gauge by mileage or time frame? Link to post Share on other sites More sharing options...
Friendstar Supercharged April 26, 2008 Author Share April 26, 2008 manual cars will NEVER have such problems right? or will they also kana gearbox replacement? Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear April 26, 2008 Share April 26, 2008 (edited) I think it's hard to gauge between the 2 My towkay's previous 98 Lancer had almost 200K in mileage with regular shifting between 'N' & 'D' at traffic junctions still work well when he sold it off at it's 5th year Furthermore, he did not flush his ATF before but jus drain & top up niah Generally, manual gearbox would not have such a problem cos they are running on clutch, clutch plate, disc .. etc & definately much much cheaper as compared Edited April 26, 2008 by Mzrmazda3 Link to post Share on other sites More sharing options...
Zanter 3rd Gear April 26, 2008 Share April 26, 2008 I would say depends on the make & the frequency the ATF oil is changed. 200k is possible with good makes & regular oil changes. Must remember in SG the auto box is stressed. We dont do a lot of long distance driving which is better for the boxes. Link to post Share on other sites More sharing options...
Qpik Supercharged April 26, 2008 Share April 26, 2008 (edited) 1 of my fren's proton auto gear box died during 7th, quoted replacement cost 10k for potong part. another 1, audi auto just after 3rd yr, died. was quoted 14k for the box exclude labour. not sure was it the high mileage that killed it faster. mine, a coe manual after 15yrs still ok but fan coil died. even if u are someone who send the car in for regular servicing so hard to say. bright side is jap car got potong parts. Edited April 26, 2008 by Qpik Link to post Share on other sites More sharing options...
Contax 1st Gear April 26, 2008 Share April 26, 2008 I was driving a corona CD(SBH plate) with auto box in year 1999-2003 when it was registered in 1989.It was still working perfectly fine when I have to deregistered it at the 15th years due to our local COE systems A fine example of over engineering Link to post Share on other sites More sharing options...
inlinesix Hypersonic April 26, 2008 Share April 26, 2008 Hey there, i heard auto gearbox cost between 4-6k to replace. Can i know what is the expected lifespan of an auto gear box? THanks! Auto gearbox can be rebuild. No need 2 replace. Check out Khang website. Link to post Share on other sites More sharing options...
Route88 2nd Gear April 26, 2008 Share April 26, 2008 I intend to replace my ATF every 20K, i dont want to do flushing Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear April 26, 2008 Share April 26, 2008 I also change my ATF every 20K Link to post Share on other sites More sharing options...
Sonicmood Neutral Newbie April 26, 2008 Share April 26, 2008 (edited) gauge by mileage or time frame? the auto gear box was scrap together with my last 2 cars... no problem...just do regular ATF change... & don't chiong from standstill at traffic junction... Edited April 26, 2008 by Sonicmood Link to post Share on other sites More sharing options...
Ivanpaseo 2nd Gear April 26, 2008 Share April 26, 2008 I think it should be able to last 10 years till the COE ends with regular maintainence... Uncle once own a proton saga 5 years of age and until the 13th year than the gearbox gave way... Link to post Share on other sites More sharing options...
Kieran1975 1st Gear April 26, 2008 Share April 26, 2008 (edited) do you change your ATF Filter for every ATF oil change? Fyi, ATF filter + gasket not cheap (ard $70) and labour cost ($40) is more than ATF drain & top up ($15).... Edited April 26, 2008 by Kieran1975 Link to post Share on other sites More sharing options...
Keen 1st Gear April 26, 2008 Share April 26, 2008 the atf u using is mineral or synthetic? Link to post Share on other sites More sharing options...
Friendstar Supercharged April 26, 2008 Author Share April 26, 2008 OMG u mean AD will cheat meh? ↡ Advertisement Link to post Share on other sites More sharing options...
MALAYSIA TIPS - Long Distance Driving Trips
Reputable like Lye Design in Amk Auto-point
Avatar : The Last Airbender
Bad Auto Dealer - Salesman!
