Moeykf Neutral Newbie May 6, 2008 Share May 6, 2008 Hi Bros, Im using 225/50/R17 and dunno how much air to pump. I tried pumping in 280 at petrol kiosk. Anyone can advise what is the ideal pressure for the said size? ↡ Advertisement Link to post Share on other sites More sharing options...
Siyexcalibur Neutral Newbie May 6, 2008 Share May 6, 2008 a) Check your car manual. It depends a lot on the weight of the car. Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie May 6, 2008 Author Share May 6, 2008 my car comes with original 16" and i upgraded to 17". Weight of the car about 1.5Tons. Link to post Share on other sites More sharing options...
Iziz Clutched May 6, 2008 Share May 6, 2008 Check ur car manual. 280 sounds like it is waaaaayyyyy over the recommended. Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie May 6, 2008 Author Share May 6, 2008 ok thanks bro, i try to check the manual tonight. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 6, 2008 Share May 6, 2008 (edited) There's no ideal figure to give u. U have to judge for yourself. What the user manual states is the best COMPROMISE on grip in wet & dry conditions. Ppl always got the wrong conception that pumping over the recommended pressure the tire will burst. The tire will not burst even if u pump the maximum ALLOWABLE pressure. 4 or 5 times the max. pressure maybe it'll burst. I always overinflat 10% the recommended pressure to get better FC. 1 atmospheric pressure(normal air pressure) or 1 bar is 101.325 kPa. Our tire pressure is 2x or slightly more dan 2x of that. Dun let the big number scare u. Edited May 6, 2008 by Watwheels Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie May 6, 2008 Author Share May 6, 2008 ok thanks bro :) Link to post Share on other sites More sharing options...
Akula Turbocharged May 6, 2008 Share May 6, 2008 Think 220 - 230 kpa is abt right, this is after factoring +5-10%. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 6, 2008 Share May 6, 2008 My tyre size is 215/45R17 & the max i pump is 250 Think your 280 is a bit too high liao Link to post Share on other sites More sharing options...
Wreckwrx 1st Gear May 6, 2008 Share May 6, 2008 Hi Bros, Im using 225/50/R17 and dunno how much air to pump. I tried pumping in 280 at petrol kiosk. Anyone can advise what is the ideal pressure for the said size? I am using 225/45/R17 and my tire shop advised my to pump 32PSi which is prob around 250 (I think?). In any case, 280 is way too much already lah...... Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 6, 2008 Share May 6, 2008 as a guide for u: 255(warm taya)= 230(cold) 300(warm taya)= 265(cold) i pump to minimum 300 when taya is warm b4 going up NSH. Link to post Share on other sites More sharing options...
Keen 1st Gear May 6, 2008 Share May 6, 2008 i pump around 250 for 15 inch rim... Link to post Share on other sites More sharing options...
Fitvip Supersonic May 6, 2008 Share May 6, 2008 Most cars have an info sticker on the driver's door pillar. check it out there, plus up to 10% is OK! Link to post Share on other sites More sharing options...
Davidcks 1st Gear May 6, 2008 Share May 6, 2008 wah! I pump 235 already think abit high, u can go until 250!!! Not hard meh?? I mean will be bumpy leh. Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie May 7, 2008 Author Share May 7, 2008 ok thanks to all the bros here for ur advice. Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie May 7, 2008 Author Share May 7, 2008 i use 15" before and i know 250 is scary for 15"....usually i pump 200-220 for 15" 195/50/r15 Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 7, 2008 Share May 7, 2008 Stamford Tyre tell me pump 250 leh But i think ideally is 245, jus that i pump 250 to compensate cos tyres would be warmed up by the time i reach petrol kiosk Bumpy is a bit especially i'm running on aftermarket suspensions But already get used to it for more than 3.5 years liao Link to post Share on other sites More sharing options...
Auron 2nd Gear May 7, 2008 Share May 7, 2008 280kPa is not too high lar... my mz3 recommended rear tyres for full load is 310kPa. ↡ Advertisement Link to post Share on other sites More sharing options...
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
Tyre puncture
Tyre puncture
Continental closing Alor Setar plant
